Template for Scrollbar and Trackbar + generated code for the messages.
Started by Stephane Fonteyne, November 03, 2011, 06:33:51 PM
Stephane Fonteyne
Can you please create an template when the user placed the component "scrollbar" or "trackbar" and his form. Then create the program the code for the "scrollbar" or "trackbar"
More designed properties for the scrollbar :
Min
Max
Value
Largechange
Smallchange
the same for the trackbar
Best regards
Stephane
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
Haakon Birkeland
The only property in your list "missing" is the SmallChange, not being present on the scrollers ...
As for templates, I for one, don't quite get what you're after. FF has plenty of wrappers to use for easily working with these controls. Especially the tracker has a significant list of FF functions a few clicks away in the Functions Library (F8).
Haakon 8o)
