Problem with Special Function
Started by Martin Francom, November 08, 2011, 12:55:52 AM
Martin Francom
I am converting a FF31/PB9 program to FF35/PB10 and have run into a local
variable the is defined as  PointApi  that is causing a problem.  Here's the code:
Function FORMDGMSG_LIST1_CUSTOM ( _
   Local rc   As Rect
   Local t    As Long
   Local itd  As Long
   Local pt   As PointApi
   Select Case wMsg
     Case %WM_KEYDOWN
        If wParam = %VK_SPACE Then                            'Respond to space bar
           t = SendMessage(hWndControl, %LB_GETCURSEL, 0, 0)             'get selected
           itd = Not SendMessage(hWndControl, %LB_GETITEMDATA, t, 0)     'get toggled item data
           Call SendMessage(hWndControl, %LB_SETITEMDATA, t, itd)        'set toggleded item data
           Call SendMessage(hWndControl, %LB_GETITEMRECT, t, VarPtr(rc)) 'get sel. item's rect
           InvalidateRect hWndControl, rc, 0 : UpdateWindow hWndControl  'update sel. item only
           Function = 0 : Exit Function                        'return zero
     Case %WM_LBUTTONDOWN
        If wParam = %MK_LBUTTON  Then                             'respond to mouse click
           pt.x = LoWrd(lParam) : pt.y = HiWrd(lParam)            'get cursor pos
           t = SendMessage(hWndControl, %LB_ITEMFROMPOINT, 0, MakLng(pt.x, pt.y)) 'get sel. item
           SendMessage hWndControl, %LB_GETITEMRECT, t, VarPtr(rc)       'get sel. item's rect
           rc.nLeft   = 2 : rc.nRight = 15                        'checkbox cordinates
           If PtInRect(rc, pt.x, pt.y) Then                       'if in checkbox
              SendMessage hWndControl, %LB_SETITEMDATA, t, itd              'set toggled item data
This is the statement causing the problem: PtInRect(rc, pt.x, pt.y)
attached is error message.
Hi Marty,
strange error description indeed.
What I can see is that your code has the parameters for the PtInRect  function wrong. You have 3 params where 2 are required. Both need to be structures. (See text from the Win32 helpfile below.)
Try this instead:
If PtInRect(rc, pt) Then
Quote from Win32 helpfile:
The PtInRect function determines whether the specified point lies within the specified rectangle. A point is within a rectangle if it lies on the left or top side or is within all four sides. A point on the right or bottom side is considered outside the rectangle.
BOOL PtInRect(
    CONST RECT *lprc,   // address of structure with rectangle
    POINT pt    // structure with point
Parameters
lprc
   Points to a RECT structure that contains the specified rectangle.
pt
   Specifies a POINT structure that contains the specified point.
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
David Kenny
Rolf is right, that is how it is described in the WinAPI help and at MSDN.  It is correct for the way PB defined it in the PB9 include files however.  If you look at WinUser.inc in Jose Roca's includes, you will find it is defined as having two parameters as Rolf stated.  You could probably call it like so: PtInRect(rc, pt).  But if you look at this excerpt from Winuser.inc (mentioned above) you can see the next function declaration below PtInRect is PtInRectXY:DECLARE FUNCTION PtInRect IMPORT "USER32.DLL" ALIAS "PtInRect" ( _
   BYREF lprc AS RECT _                                 ' __in CONST RECT *lprc
, BYVAL pt AS POINT _                                  ' __in POINT pt
) AS LONG                                              ' BOOL
' Same as above, but using x, y coordinates
DECLARE FUNCTION PtInRectXY IMPORT "USER32.DLL" ALIAS "PtInRect" ( _
, BYVAL x AS LONG _                                    ' __in x
, BYVAL y AS LONG _                                    ' __in y
) AS LONG                                              ' BOOL
Meaning you could just change your call to: PtInRectXY(rc, pt.x, pt.y)
Don't be afraid to just check Jose's includes to see what the correct parameters are.  He has done a great deal of work getting them to match the MicroSoft documentation.
David
Thanks for the hint, David. Good one. Nice wrapper of Josè (like so many he has created).
In case of using the wrapper I would suggest to define x, y vars as long and leave the pt structure out and use:
PtInRectXY(rc, x, y)
Rolf
(W. C. Fields)
Martin Francom
Rolf and David,
   Thanks for the help.  Some of this stuff is just
above my level of knowledge.
David changing the function call was what was needed.
That worked !
   That was the last correction I had to make to convert a rather
large FF31/PB90 programs to  FF35/PB10.  The program now
compiles with out any errors.  What a relief !
    2,082,480 bytes of compiled code.
Tomorrow I need to do some testing to make sure I don't
have any run-time problems.   But I am feeling good about it.
You're up late, Marty. Full moon bothering you?
Rolf
(W. C. Fields)
