AfxShell Include Compile Error
Started by Richard Kelly, November 25, 2011, 07:08:16 AM
Richard Kelly
The attached pic has the information. I know pi is a PB reserved word, so I patched that up and then the second error.
Rick kelly
I can't seem to find AFXSHELL.INC in my download of Jose's includes.... maybe I am not using the latest?
Richard Kelly
Quote from: TechSupport on November 25, 2011, 08:41:07 AM
I am using the latest version downloaded directly from Jose's forums.
Rick Kely
Latest version is 2.05 from Nov.3, 2011.
Lots of more wrappers!
Rolf
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Richard Kelly
Quote from: Rolf Brandt on November 25, 2011, 10:34:28 AM
Rolf
That's the version I'm using.
Rick Kelly
pi is not a reserved error. What happens is that you're must have defined it as a macro somewhere in your code and the compiler is trying to replace the parameter with 3.14...
Macros are a can of worms.
Richard Kelly
#6
Quote from: Jose Roca on November 25, 2011, 12:41:19 PM
OMG! You are always so spot on. It's in my date and time calculation routines.
' Credits - Calendrical Calculations Third Edition, Nachum Dershowitz and Edward M. Reingold
'           Astronomical Algorithms, Jean Meeus
' Written by: Rick Kelly, info@crooit.com
' Released into the public domain for private and public use without restriction
' Windows XP is minimum OS needed
' Include here for functions not found in PB standard WIN32API.INC
DECLARE FUNCTION TzSpecificLocalTimeToSystemTime LIB "KERNEL32.DLL" ALIAS "TzSpecificLocalTimeToSystemTime" _
            (lpTimeZoneInformation AS TIME_ZONE_INFORMATION, lpLocalTime AS SYSTEMTIME, lpUniversalTime AS SYSTEMTIME) AS LONG
MACRO J2000                         = 730120.5                          ' Jan 1, 2000 at 12:00PM
MACRO PI                            = 3.141592653589793##
MACRO DegreesToRadians(nDegrees)    = (nDegrees*0.0174532925199433##)
MACRO RadiansToDegrees(nRadians)    = (nRadians*57.29577951308232##)
MACRO MeanSynodicMonth              = 29.530588861##                    ' Mean time from new moon to new moon
MACRO EarthRadius                   = 6372000
MACRO VisibleHorizon                = .841314754398138##                ' Half diameter of the sun (16 minutes +
        ' 34.478885263888294 minutes for refraction)
        ' expressed in decimal degrees
I just changed it out to:
FUNCTION PI () AS EXTENDED
    FUNCTION = 3.141592653589793##
On the good side, your includes make putting an app shortcut on the desktop a snap.
Uses includes:
#INCLUDE "afxshell.inc"
#INCLUDE "wshom.inc"
Sub DesktopShortcut ()
' Create a shortcut to CTarget on the users desktop
Local pWsh          As IWshShell
Local pLnk          As IWshShortcut
    pWsh = NewCom "WScript.Shell"
    pLnk = pWsh.CreateShortcut(AfxGetDesktopFolder () + "\YourName.lnk")
' Set shortcut properties
   pLnk.Description      = App.LegalCopyright
   pLnk.WorkingDirectory = App.Path
   pLnk.IconLocation     = App.Path + "\" + App.EXEName + " ,0"
   pLnk.TargetPath       = App.Path + "\" + App.EXEName
   pLnk.WindowStyle      = %WSHNORMALFOCUS
' Save shortcut
    pLnk.Save
End Sub
Rick Kelly :-[
