Menu Bar Alignment
Started by Richard Kelly, November 27, 2011, 07:15:34 AM
Richard Kelly
If you want to right align in a menu bar as I've seen "Help" right aligned many times, the following will do the trick.
Function MAIN_WM_CREATE ( _
Local udtMenuItemInfo   As MENUITEMINFO
' Right align the menu Help item
    udtMenuItemInfo.cbsize = SizeOf(udtMenuItemInfo)
    udtMenuItemInfo.fmask = %MIIM_FTYPE
    GetMenuItemInfo (HWND_MAIN_TOPMENU, IDC_MAIN_MNUHELP, %FALSE, udtMenuItemInfo)
    udtMenuItemInfo.ftype = udtMenuItemInfo.ftype Or %MFT_RIGHTJUSTIFY
    SetMenuItemInfo (HWND_MAIN_TOPMENU, IDC_MAIN_MNUHELP, %FALSE, udtMenuItemInfo)
***Note posted to wrong forum :-[
Rick Kelly
Thanks for that one, Rick. I remember spending quite some time on that years ago until I got it achieved in VB6.
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Or you can call the AfxRightJustifyMenuItem wrapper function.
Richard Kelly
Quote from: Jose Roca on November 27, 2011, 01:02:04 PM
I have to find or start a list of your functions. I've already spent several hours just opening up your *.inc files and browsing through them. I must have missed that one or, at my somewhat advanced age, the memory bank is just overloaded.....
Rick Kelly :o
David Kenny
Jose,
Both the 2.05 API headers and the help file downloaded as .PHP files.  I simply changed the extension to .RAR and was able to open and extract both.
It's a problem of FireFly 8. Try right clicking the link and using Save link as, or use another browser.
Haakon Birkeland
QuoteFireFly 8
I want that update too! 8oÞ
Haakon 8o)
David Kenny
Well,  that's what I get for blindly clicking OK on an "update ready" message.  Sorry to bother you with a problem I caused myself.  :)
