Automatic scroll in TextBox
Started by David Chisholm, November 13, 2012, 02:59:26 PM
David Chisholm
I am using a TextBox to output the results of a rather long operation.  I want the text to automatically scroll up the screen one-line-at-a-time as it hits the bottom of the box.
I have tried checking the ES_AUTOVSCROLL within the (WindowStyles) but it does not seem to do anything.  I am updating the text box as per the example below by getting the text, appending to it and replacing all the text.  I did not see any kind of append command available.
Dim posn As Integer
    FF_TextBox_SetText(HWND_FORM1_TEXT1, "")
    For posn = 1 To 100
        FF_TextBox_SetText(HWND_FORM1_TEXT1, FF_TextBox_GetText(HWND_FORM1_TEXT1) & Str$(posn) & $CrLf )
    Next posn
By default the text disappears off the bottom of the box and the vertical scroll bar adjusts accordingly.
I want to be able to see the latest entry in the window without having to use the scroll bars.  I did try the scroll commands but I do not know how many lines will eventually be displayed and so my only workaround was to issue 10 or so (FF_TextBox_Scroll(HWND_FORM1_TEXT1, %SB_PAGEDOWN)) which is not very efficient and may not work if I get an extraordinary large number of output lines.
Any suggestions?
Thanks.
/Dave Chisholm
Hi David,
I am just getting home from my trip. I haven't tried any code to post for your problem but you can start by looking at the text in these two posts:
http://www.planetsquires.com/protect/forum/index.php?topic=2675.msg20200#msg20200
http://www.planetsquires.com/protect/forum/index.php?topic=2519.msg19297#msg19297
David Chisholm
Thanks.  I looked at the two examples.  The for loop example with scrolling one line based on the line count was too jittery on the screen.
I tried passing "%EM_SCROLLCARET" through the FF_TextBox_Scroll until I realized, by clicking on the Code tab, that it was being converted to:
"SendMessage HWND_FORM1_TEXT1, %EM_SCROLL, %EM_SCROLLCARET, 0"  ARGHHHHHH!  Once I figured that out the following worked great:
    Dim end_of_text As Long
    Dim posn As Integer
    For posn = 1 To 30
        end_of_text = Len(FF_TextBox_GetText(HWND_FORM1_TEXT1))
        FF_TextBox_SetSel(HWND_FORM1_TEXT1,end_of_text,end_of_text)
        SendMessage HWND_FORM1_TEXT1, %EM_SCROLLCARET, 0, 0
        FF_DoEvents
    Next posn
Maybe, in future releases, you could add FF_TextBox_ScrollCaret to your functions?
Thanks again for your quick reply and your help.
/Dave Chisholm
