Search scope
Started by Haakon Birkeland, June 07, 2004, 08:06:09 PM
Haakon Birkeland
I can't recall that an option to search project wide was there before or if I'm confusing it (most likely) with JF's ability. But when searching for a MsgBox text today, FF just wouldn't find it before I manually put the caret in the correct code part (frmMain part). It didn't even say it couldn't fin it, or where it had looked and not looked.
Please consider copying and pasting some search-goodie-code from JF to make FF "up to standard". - Your great standard!  :wink:
Righ, - now my notebok is empty for now, and I'll rest my case and go to bed. Happy coding Master.
I removed Project wide searching after the intial FireFly release. I intend to re-implement it as soon as I can.
Haakon Birkeland
So I wasn't loosing it..  :D  Good to hear.
