pb string equates
Started by Marc van Cauwenberghe, January 24, 2013, 01:07:56 PM
It seems there are a few string equate that are not define for the FF editor.
$DQ2                 Chr$(34,34)              Two Double-Quotes ("")
$SQ2                 Chr$(39,39)              Two Single-Quotes ('')
$QCQ                 Chr$(34, 44, 34)        Double-Quote, Comma, Double-Quote
$WHITESPACE     Chr$(32, 9, 13, 10)     Space, Tab, CR, LF
Would you mind adding them to the next version.
I can add them in the powerbasic.txt file under PBKEYWORDS can't I?
Marc
Thanks Marc - yes, you should be able to add them to the keywords file.
