Controls Disappear
Started by Dennis Allen, February 01, 2013, 05:12:50 PM
Dennis Allen
Hello,
It must be me, and I have looked for an answer. But cannot find one, so help would be appreciated.
When I create a control on a form, go do something so the control losses its grab handles (got to the Explorer or whatever), then come back and click on it with the CTRL key depressed (to select for a group adjustment), it disappears. Where does it go? The ID's are still there? How can I undo this?
thank you,
Ron
Heinz Grandjean
Ron,
I sometimes have this too. I get the control back after readjusting it's "top" and "left" -value.
Heinz Grandjean
Dennis Allen
Thank you Sir! Now they can be found.
And I thought I was the only one having things disappear.
I have a similar issue with FRAMES disappearing while the program is running and there is a WINDOWS POPUP like a warning for CAPS LOCK in a password field, all my FRAMES on the form disappear.
I wonder how one can rectify that in RUNTIME?
-Regards
Peter
