wMsg ??
Started by Douglas McDonald, February 04, 2013, 01:44:33 PM
Douglas McDonald
I'm trying tell id the mouse is over a button hovering. I assume the code would be something like
this:
Function ASTRCU_ASRELAYSOFFBNT_CUSTOM ( _
Select Case wMsg
      Case wparam
            %WM_NOTIFY
             If lparam = %nm_hover Then mousptr = 2     'I'm sure this is not correct
I guess what I'm really asking is how do I use CallBacks like PB's CB.MSG and the rest of CB.xxxxxx
Thanks
Doug
Doug McDonald
KD5NWK
www.redforksoftware.com
Rudolf Furstauer
I'm not sure whether you receive this message from a button.
I think you only get it from a ListView, but i'm not sure.
You could use this code in mousemove or in a timerevent.
    Local Pt                As PointApi
    Local hWnd              As Dword
    'query Handler under the mouse
    Pt.x = LoInt(GetMessagePos())
    Pt.y = HiInt(GetMessagePos())
    hWnd = WindowFromPoint(Pt)
    'Is it my button?
    Select Case hWnd
        Case HWND_FORM1_CMD(0)
            MousePtr 11
        Case HWND_FORM1_CMD(1)
            MousePtr 5
        Case Else
            MousePtr 1
Rudolf Fuerstauer
Robert Eaton
You may need to look at the WM_NCHITTEST message.
Douglas McDonald
I guess my main question is how to use PB's call backs in FF3. Do they go in the custom sections. Can I use CB.xxxx messages like in PB?
As you can see I'm stupid abut this. I'd guess it's simple, I just don't know how to use them with FF3
Doug
Doug McDonald
KD5NWK
You can't use the CB.xxxx style messages in FireFly. PB's callbacks are tied to the DDT engine that PB decided to use. It is not compatible with how the WinAPI / SDK style of programming works. Check out my source code for custom controls like the FireLink and you will see how I handle situations where a mouse cursor hovers over a control.
Douglas McDonald
Ok thank you Paul
Doug
Doug McDonald
KD5NWK
