CRC / LRC Calculator
Started by Stephane Fonteyne, June 10, 2013, 11:03:05 AM
Stephane Fonteyne
Hi all,
I try the FireFly project but it give res errors?
'CRC / LRC Checksum Calculator
'Created by John Waalkes
'This Code Is Public Domain. Enjoy.
'No warranties, express or implied. Use At your own risk.
'Dec 20, 2010
Function FORM1_CMDCALCCRCB_BN_CLICKED ( _
    Local Poly  As Word
    Local CRC   As Word
    Local MBStr As String
    MBStr = FF_TextBox_GetText (HWND_FORM1_TXTINPSTR)
    Poly = Val("&h" + FF_TextBox_GetText (HWND_FORM1_TXTPoly))
    If MBStr <> "" Then
        Call CRC16ComputeB (MBStr, Poly, CRC)             'This is the Binary (CRC) version
Function FORM1_CMDCALCCRCH_BN_CLICKED ( _
    Local Poly      As Word
    Local CRCErr    As Word
    Local CRC       As Word
    If MBStr <> "" Then
        Call CRC16ComputeH (MBStr, Poly, CRC, CRCErr)     'This is the HEX (CRC) version
Function FORM1_CMDCALCLRC_BN_CLICKED ( _
    Local LRC       As Word
    If MBStr <> "" Then
        Call LRCCompute (MBStr, LRC, CRCErr)     'This is the LRC (HEX only) version
Sub CRC16ComputeB (ByVal MBStr As String, ByVal Poly As Word, ByVal CRC As Word)   'calculate the CRC treating each character as one byte (Binary).
    Local tCRC  As Word
    Local b     As String
    Local i     As Integer
    If MBStr = "" Then Exit Sub                    'Not too much that we can do with an empty string.
    tCRC = &hFFFF                                  'Seed tCRC with -1
    Do While MBStr <> ""
        b = Left$(MBStr,1)                         'Grab a character.
        MBStr = Right$(MBStr, Len(MBStr) - 1)      'Now remove it from MBStr$
        tCRC = tCRC Xor Asc(b)                     'Xor tCRC with the first byte
        For i = 1 To 8                             'If tCRC is an odd number, we need to shift it right on place and Xor it with the Polynominal (in this case, &hA001)
            If (tCRC And 1) = 1 Then
                Shift Right tCRC, 1
                tCRC = tCRC Xor Poly
            Else
                Shift Right tCRC, 1                'Otherwise, just shift it right one bit.
        Next i%
    Wend
    MBStr = Hex$(tCRC)                             'The result needs to be byte-swapped (little endian to big endian) for the Modbus world
    MBStr = Right$(MBStr, 2) + Left$(MBStr, 2)     'This gets the string swapped
    CRC = Val("&h" + MBStr)                        'And this gets you the actual value.
    FF_TextBox_SetText (ByVal HWND_FORM1_TXTMODBUSCRC,  ByVal MBStr)
End Sub
Sub CRC16ComputeH (ByVal MBStr As String, ByVal Poly As Word, ByVal CRC As Word, ByVal CRCErr As Word)   'calculate the CRC treating each character as two bytes (HEX).
        'include CRCErr since we have a couple of errors that occur here (non-HEX, and odd number of nibbles).
    Local tCRC As Word
    Local b    As String
    Local i    As Integer
    If Len(MBStr) Mod 2 = 1 Then
        CRCErr = 1  'Odd number of nibbles (keep in mind that each character in MBStr$ represents one nibble)
        Exit Sub
    MBStr = UCase$(MBStr) 'Transfer the string to upper case (for the Tally operation)
    i = Tally (MBStr, Any "1234567890ABCDEF")  'Tally up the number of legal characters in MBStr$, if it doesn't add up to the length of the string, then we have a problem.
    If i <> Len(MBStr) Then
        crcerr = 2  'A non-Hex character was found.
        Exit Sub
    tCRC = &hFFFF                                      'Basically the same as the binary version with the exception that each character will represent a HEX nibble.
        b = Left$(MBStr,2)                             'Grab two characters (to make up one byte)
        MBStr = Right$(MBStr, Len(MBStr) - 2)          'Shortem MBStr$ by two characters (which is why we make sure that MBStr$ has an even number of characters).
        tCRC = tCRC Xor Val("&h" + b)                  'By prepending b$ with "&h" we tell VAL that we are sending it a HEX value.
                Shift Right tCRC, 1
            Else
        Next i
    Wend
End Sub
Sub LRCCompute (MBStr$, LRC As Word, CRCErr As Word)                    'calculate the LRC treating each character as two bytes (HEX).
    Local tLRC As Word
    Local b    As String
    Local i    As Integer
        Exit Sub
        Exit Sub
    tLRC = 0
        tLRC = tLRC + Val("&h" + b )                  'By prepending b$ with "&h" we tell VAL that we are sending it a HEX value.
    Wend
    tLRC = &hFF - tLRC + 1
    MBStr = Hex$(tLRC)
    LRC = Val("&h" + MBStr)                           'And this gets you the actual value.
End Sub
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
John Waalkes
Hi Stephane,
You missed a change in the "Sub LRCCompute" declaration
This:  Sub LRCCompute (MBStr$, LRC As Word, ....
Should be: Sub LRCCompute (MBStr As String, LRC As Word, CRCErr As Word)
Also, keep in mind that I wrote this for Modbus RTU, which always works out to an even number of bytes. Modbus ASCII uses a LRC check (included in the program), and it can be of any length.
Also for use with Modbus RTU, the order of the CRC checksum has to be swapped. Which has been done for you in the program.
The LRC calculation is used for Modbus ASCII, and also has to have to have an even number of bytes. (Which BTW, was broken - oops!)
The "straight up" CRC16 calculation is just thrown in there for completeness (or in other words, I can't remember why I put it in there).
And finally, I apologize for not including the entire project as a zip file, I don't know what I was thinking/drinking!
Let me know if you need anything else.
