Handling right-click events in ListView column header
Started by Jean-pierre Leroy, February 20, 2015, 06:28:42 AM
Jean-pierre Leroy
I know how to handle right-clik events in a listview control with the WM_CONTEXTMENU message.
I would like to know if there is a solution to handle the right-click events specifically in the ListView column header.
My goal is to display two distinct menus: one menu when the user right-click on the ListView and a specific one when the user right-click on the ListView header.
Is-it possible to do that ?
Regards,
Jean-Pierre
Jean-pierre Leroy
Dear FF Users, finally I found an elegant solution for that.
Here is the code I put in the custom handler of the form containing the ListView; I hope that would be useful for other programmers.
Function FORM1_CUSTOM ( _
    Static hPopupMenu As Dword
    Local P_Info      As LV_HitTestInfo
    Select Case wMsg
        Case %WM_CONTEXTMENU
            If wParam = HWND_FORM1_LISTVIEW1 Then
                ' get screen position in screen coordinates
                P_Info.pt.x = LoWrd(lParam)
                P_Info.pt.y = HiWrd(lParam)
                ' convert to ListView coordinates
                ScreenToClient(wParam, P_Info.pt)
                ' Determines which list-view item or subitem is located at a given position
                ListView_SubItemHitTest(wParam, P_Info)
                ' on the ListView header
                If P_Info.iItem = - 1 And P_Info.iSubItem <> - 1 Then
                    If hPopupMenu Then DestroyMenu hPopupMenu
                    hPopupMenu = CreatePopupMenu()
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_HEADERMENU_OPTION1, "Save user column order"
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_HEADERMENU_OPTION2, "Restore user column order"
                    AppendMenu hPopupMenu, %MF_SEPARATOR, 0, ""
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_HEADERMENU_OPTION3, "Restore default column order"
                    TrackPopupMenu hPopupMenu, %TPM_LEFTALIGN Or %TPM_LEFTBUTTON, LoWrd(lParam), HiWrd(lParam), 0, hWndForm, ByVal %Null
                ' on the ListView content
                If P_Info.iItem <> - 1 Then
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_SINGLEROW_OPTION1, "Menu for selected row - Option1"
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_SINGLEROW_OPTION2, "Menu for selected row - Option2"
                    AppendMenu hPopupMenu, %MF_STRING, %IDC_POPUPMENU_SINGLEROW_OPTION3, "Menu for selected row - Option3"
