FF_STRINSERT
Started by Paul Squires, August 19, 2015, 01:37:34 PM
''  FF_STRINSERT
''  Insert a string at a specified position within another string expression.
''  Returns a string consisting of MainString with the string InsertString inserted
''  at nPosition. If nPosition is greater than the length of MainString or <= zero then
''  InsertString is appended to MainString. The first character in the string is position 1, etc.
Function FF_StrInsert( ByRef sMainString   As String, _
                       ByRef sInsertString As String, _
                       ByRef nPosition     As Integer _
                       ) As String
   Dim nLenMain   As Integer = Len(sMainString)
   Dim nLenInsert As Integer = Len(sInsertString)
   ' Try to avoid string concatentation as much as possible for speed consideration.
   ' Therefore, create the full buffer and insert by moving memory into the string.
   Dim s As String = Space(nLenMain + nLenInsert)
   ' If nPosition is greater than length of MainString or is <=0 then adjust so it appends.
   If nPosition > nLenMain Then nPosition = nLenMain + 1
   If nPosition <= 0 Then nPosition = nLenMain + 1
   MemMove( Strptr(s), Strptr(sMainString), nPosition - 1 )
   MemMove( Strptr(s)+nPosition-1, Strptr(sInsertString), nLenInsert )
   MemMove( Strptr(s)+nPosition+nLenInsert-1, Strptr(sMainString)+nPosition-1, nLenInsert )
   Function = s
