fixed buffer problem
Started by jermy, May 02, 2016, 05:16:14 PM
jermy
when I try to create a buffer, I cannot make it variable sized.
'Dim Buffer as String * 1024  ' this is oke
Dim i as Long
    i = 1024
Dim Buffer as String * i   ' this is not allowed
I' tried several times but I can't see to make it work
To create a variable size string buffer you would set the dynamic string to whatever number of blank spaces that you need.
Dim i As Long = 1024
Dim Buffer As String = Space(i)
You can not use the Dim Buffer As String * i because fixed length strings need to be defined at compile time rather than at runtime.
jermy
the program complies but crashes when i use this function below, so i cant use 'Dim Buffer As String = Space(i)'
translated from vb6
Public Function Read_(ByVal Bytes as Long = -1) as String
   On Error Goto ErrHandler
    Sleep(500)
    Dim tBytesR as Long
    Dim tBytesA as Long
    Dim tMsg as Long
    Dim i as Long, Result as Long
    Dim ReturnStr as String
    If Not mvarRunning Then Exit Function
       Result = PeekNamedPipe(pipeOut.hReadPipe, ByVal 0, ByVal 0, ByVal 0, @tBytesA, ByVal 0)
    If Result <> 0 And tBytesA > 0 Then
'  Dim Buffer as String * 1024
Dim Buffer as String = Space(tBytesA) ' crashes the program
           Result = ReadFile(pipeOut.hReadPipe, @Buffer ,IIf(Bytes = -1, SizeOf(Buffer), Bytes), @tBytesR, ByVal 0&)
        If Result  = 0 Then
           MessageBox (0,GetApiErrorInfo(GetLastError) & " ReadFile failed.", "GetLastError result",0)
          Goto ErrHandler
        ReturnStr = Left$(Buffer, tBytesR)
        Read_ = DOSDecode(ReturnStr)
    Else
       'Function =
                 MessageBox (0,GetApiErrorInfo(GetLastError) & " PeekNamedPipe", "GetLastError result",0)
          Goto ErrHandler
   Exit Function
ErrHandler:
   Terminate
'   Function = 0   ' change according to your needs
I am not 100% certain of the GPF, but because you are now using a variable size string variable you should not use SizeOf(Buffer) in your ReadFile function call. SizeOf will return the size of the variable string descriptor rather than the size of the string itself. You should probably use LEN() or simple tBytesA.
And pass *Buffer, not @Buffer.
