GdiPlus classes
Started by José Roca, August 01, 2016, 01:44:33 AM
I'm writing classes for GDI+ as close as I can to the C++ classes. GDI+ has a flat API that can be used with FB, but the problem is that almost all the code that you can find in the web uses the C++ or . NET classes. I have done about 2 thirds of the work. The problem is testing the more than 600 functions.
One of my main interests was to find the way to make it High DPI aware, without using the tedious way of multiply the values by the scale ratio.
Three of the more important classes, Graphics, Brushes and Pens have an ScaleTransform function that allows to do it by passing the scaling ratios, and the AdjustableArrowCap allows to do it calling the SetWidthScale function.
For example:
DIM graphics AS CGpGraphics = hdc
DIM rxRatio AS SINGLE = graphics.GetDpiX / 96
graphics.ScaleTransform(rxRatio, rxRatio)
DIM AS CGpAdjustableArrowCap myArrow = CGpAdjustableArrowCap(10, 10, true)
myArrow.SetWidthScale(rxRatio)
GDI+ is an important technology to work with graphics and images.
As you can see in the captured image, making the application High DPI aware and using scaling we get the same size that running it virtualized by Windows, but it is sharper.
#1
This is how it looks the code that produces the above capture, using the GDI+ classes and my graphic control.
' Microsoft Windows
' File: AdjustableArrowCapGetHeight.bas
' Contents: GDI+ - AdjustableArrowCapGetHeight example
#define UNICODE
#INCLUDE ONCE "Afx/CGdiPlus/CGdiPlus.inc"
#INCLUDE ONCE "Afx/CGraphCtx.inc"
USING Afx
CONST IDC_GRCTX = 1001
' The following example creates an AdjustableArrowCap, myArrow, and sets the height of the
' cap. The code then creates a Pen, assigns myArrow as the ending line cap for the Pen,
' and draws a capped line. Next, the code gets the height of the arrow cap, creates a new
' arrow cap with height equal to the height of myArrow, assigns the new arrow cap as the
' ending line cap for the Pen, and draws another capped line.
SUB Example_GetHeight (BYVAL hdc AS HDC)
   ' // Get the DPI scaling ratio
   ' // Set the scale transform
   ' // Create an AdjustableArrowCap with a height of 10 pixels.
   DIM myArrow AS CGpAdjustableArrowCap = CGpAdjustableArrowCap(10, 10, TRUE)
   ' // Adjust to DPI by setting the scale width
   ' // Create a Pen, and assign myArrow as the end cap.
   DIM arrowPen AS CGpPen = GDIP_ARGB(255, 0, 0, 0)
   arrowPen.SetCustomEndCap(@myArrow)
   ' // Draw a line using arrowPen.
   graphics.DrawLine(@arrowPen, 0, 20, 100, 20)
   ' // Create a second arrow cap using the height of the first one.
   DIM AS CGpAdjustableArrowCap otherArrow = CGpAdjustableArrowCap(myArrow.GetHeight, 20, TRUE)
   otherArrow.SetWidthScale(rxRatio)
   ' // Assign the new arrow cap as the end cap for arrowPen.
   arrowPen.SetCustomEndCap(@otherArrow)
   graphics.DrawLine(@arrowPen, 0, 55, 100, 55)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Initialize GDI+
   DIM token AS ULONG_PTR = AfxGdipInit
   ' // Creates the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "GDI+ AdjustableArrowCapGetHeight", @WndProc)
   pWindow.WindowStyle = WS_OVERLAPPED OR WS_CAPTION OR WS_SYSMENU
   pWindow.SetClientSize(400, 250)
   ' // Centers the window
   pWindow.Center
   ' // Add a graphic control
   pGraphCtx.Clear BGR(255, 255, 255)
   ' // Get the memory device context of the graphic control
   DIM hdc AS HDC = pGraphCtx.GetMemDc
   ' // Draw the graphics
   Example_GetHeight(hdc)
   ' // Shutdown GDI+
   AfxGdipShutdown(token)
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
    CASE WM_DESTROY
         PostQuitMessage(0)
#2
The FB headers for GDI+ are a mess, with several incompatibilities with the 32 and 64-bit versions. I will try to solve them adding some unions to AfxGdiPlus.inc.
For example, the 32-bit version has not defined a ColorMap structure, and the 32-bit application tries to use the one for GDI. So, if you intend to write a GDI+ application that works with 32 and 64-bit, you have to do:
#ifdef __FB_64BIT__
   DIM redToBlue AS ColorMap_
   redToBlue.oldColor.value = GDIP_ARGB(255, 255, 0, 0)
   redToBlue.newColor.value = GDIP_ARGB(255, 0, 0, 255)
#else
   redToBlue.from = GDIP_ARGB(255, 255, 0, 0)
   redToBlue.to = GDIP_ARGB(255, 0, 0, 255)
#endif
GDIP_ARGB is a function to solve another incompatibility between 32 and 64-bit.
I have defined the following union:
UNION GDIP_COLORMAP
   ' // For compatibility with GDI+
   TYPE
      oldColor AS COLORREF
      newColor AS COLORREF
   END TYPE
   TYPE
      from AS COLORREF
      to AS COLORREF
   END TYPE
END UNION
So, instead of the above mess, I can use:
DIM redToBlue AS GDIP_COLORMAP = (GDIP_ARGB(255, 255, 0, 0), GDIP_ARGB(255, 0, 0, 255))
with both compilers.
The following macros aren't defined in the headers for FB 32bit, so I have added them conditionally to CGdiPlus.inc.
' // Not defined in the FB headers for 32-bit
#ifndef __FB_64BIT__
#define GetImageDecoders(numDecoders, size, decoders) cast(GpStatus, GdipGetImageDecoders((numDecoders), (size), (decoders)))
#define GetImageDecodersSize(numDecoders, size) cast(GpStatus, GdipGetImageDecodersSize((numDecoders), (size)))
#define GetImageEncoders(numEncoders, size, encoders) cast(GpStatus, GdipGetImageEncoders((numEncoders), (size), (encoders)))
#define GetImageEncodersSize(numEncoders, size) cast(GpStatus, GdipGetImageEncodersSize((numEncoders), (size)))
#endif
#4
Another mess is that GpPoint is defined as Point in 64 bit and as Point_ in 32 bit.
   DIM pts(0 TO 2) AS GpPoint = {GDIP_POINT(-15, -15), GDIP_POINT(0, 0), GDIP_POINT(15, -15)}
'#ifdef __FB_64BIT__
'   DIM pts(0 TO 2) AS GpPoint = {(-15, -15), (0, 0), (15, -15)}
'#else
'   ' // With the 32-bit compiler, the above syntax can't be used because a mess in the
'   ' // FB headers for GdiPlus: GpPoint is defined as Point in 64 bit and as Point_ in 32 bit.
'   ' // Using the helper function GDIP_POINT, the same syntax can be used with both compilers.
'   pts(0).x = -15 : pts(0).y = -15 : pts(2).x = 15: pts(2).y = -15
'#endif
There are similar problems with GpPointF, GpRectF and GpRect, so I have added the following helper functions to AfxGdiPlus.inc.
' Fills a RECTF structure
PRIVATE FUNCTION GDIP_RECTF (BYVAL x AS SINGLE, BYVAL y AS SINGLE, BYVAL nWidth AS SINGLE, BYVAL nHeight AS SINGLE) AS GpRectF
   DIM rcf AS GpRectF
   rcf.x = x : rcf.y = y : rcf.Width = nWidth : rcf.Height = nHeight
   RETURN rcf
' Fills a RECT structure
PRIVATE FUNCTION GDIP_RECT (BYVAL x AS LONG, BYVAL y AS LONG, BYVAL nWidth AS LONG, BYVAL nHeight AS LONG) AS GpRect
   DIM rc AS GpRect
   rc.x = x : rc.y = y : rc.Width = nWidth : rc.Height = nHeight
   RETURN rc
' Fills a POINTF structure
PRIVATE FUNCTION GDIP_POINTF (BYVAL x AS SINGLE, BYVAL y AS SINGLE) AS GpPointF
   DIM pt AS GpPointF
   pt.x = x : pt.y = y
   RETURN pt
PRIVATE FUNCTION GDIP_POINT (BYVAL x AS SINGLE, BYVAL y AS SINGLE) AS GpPoint
   DIM pt AS GpPoint
   pt.x = x : pt.y = y
   RETURN pt
Also problems with GetAlpha, GetRed, GetGreen, GetBlue and Color, not defined in 32 bit and defined as member of a class in 64 bit.
So I have added the following helper functions to AfxGdiPlus.inc.
UNION GDIP_BGRA
   color AS COLORREF
   TYPE
      blue  AS UBYTE
      green AS UBYTE
      red   AS UBYTE
      alpha AS UBYTE
   END TYPE
END UNION
' Returns an ARGB color value initialized with the specified values for the alpha, red,
' green, and blue components.
PRIVATE FUNCTION GDIP_ARGB (BYVAL a AS UBYTE, BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE) AS COLORREF
   DIM clr AS GDIP_BGRA
   clr.alpha = a : clr.red   = r : clr.green = g : clr.blue  = b
   FUNCTION  = clr.color
PRIVATE FUNCTION GDIP_COLOR (BYVAL a AS UBYTE, BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE) AS COLORREF
' Returns an XRGB color value initialized with the specified values for the red, green,
' and blue components.
PRIVATE FUNCTION GDIP_XRGB (BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE) AS COLORREF
   FUNCTION = GDIP_ARGB(&HFF, r, g, b)
' Returns a BGRA color value initialized with the specified values for the  blue, green,
' red and alpha components.
PRIVATE FUNCTION GDIP_BGRA (BYVAL b AS UBYTE, BYVAL g AS UBYTE, BYVAL r AS UBYTE, BYVAL a AS UBYTE) AS COLORREF
   clr.blue  = b : clr.green = g : clr.red   = r : clr.alpha = a
' Returns an RGBA color value initialized with the specified values for the red, green,
' blue and alpha components.
PRIVATE FUNCTION GDIP_RGBA (BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE, BYVAL a AS UBYTE) AS COLORREF
   FUNCTION = GDIP_ARGB(a, r, g, b)
' Gets the alpha component of an ARGB color.
PRIVATE FUNCTION GDIP_GetAlpha (BYVAL argbcolor AS COLORREF) AS BYTE
   clr.color = argbcolor
   RETURN clr.alpha
' Gets the red component of an ARGB color.
PRIVATE FUNCTION GDIP_GetRed (BYVAL argbcolor AS COLORREF) AS BYTE
   RETURN clr.red
' Gets the green component of an ARGB color.
PRIVATE FUNCTION GDIP_GetGreen (BYVAL argbcolor AS COLORREF) AS BYTE
   RETURN clr.green
' The GetBlue method gets the blue component of an ARGB color.
PRIVATE FUNCTION GDIP_GetBlue (BYVAL argbcolor AS COLORREF) AS BYTE
   RETURN clr.blue
The classes are close to completion. It remains a couple of classes for metafiles and effects.
I also have more than 100 examples testing Caps, Brushes, Graphics, Matrices, Pens and Regions.
Many more examples are needed to test the other classes.
I also want to write a help file documenting the GDI+ flat API functions and the CGdiPlus classes.
I will write some examples using the flat API for comparison purposes, but using the classes makes GDI+ programming much easier.
