copy a project
Started by raymw, January 27, 2017, 01:38:25 PM
I would like to copy a project, with a new name only, in order to modify it, but still be able to refer/alter the original version. I thought it could be done by simply making a new project folder using the usual windows file explorer and drag and drop the sub directories, but that does not seem to work. Is it doable by creating a new project within ff, and then copying the files?
Best wishes,
Ray
It does work OK - I need new glasses - didn't see the ffp file
