Stupid question about compiler error
Started by Wilko Verweij, April 06, 2017, 03:19:18 PM
Wilko Verweij
Hi, After testing FB-IDE for some time, I concluded I was not satisfied and decided to test WinFBE. Works great. Now I am running into something I do not understand. I hace the following line of code:
COMMON SHARED hAppInst AS HINSTANCE
because I want to use the instance handle later. My WinMain looks like:
FUNCTION WinMain(BYVAL hInstance AS HINSTANCE, BYVAL hPrevInstance AS HINSTANCE, BYVAL szCmdLine AS ZSTRING PTR, BYVAL nCmdShow AS LONG) AS LONG
  hAppInst = hInstance
  FUNCTION = 1
This works. :)
Now I would like to move the line "COMMON SHARED hAppInst AS HINSTANCE" to a separate file. So I created COMMONS.BAS, moved the line to that module, and created the line
#INCLUDE "Modules\Commons.bas"
But that gives me the error:
error 14: Expected identifier, found 'HINSTANCE' in 'COMMON SHARED hAppInst AS HINSTANCE'
What an I doing wrong (yes I know it's a stupid question)... Yet any help is appreciated...
Wilko
Wilko Verweij
Forget it. File type needs to be set to 'Normal' rather than 'Module'... Now working
Hi Wilko,
Just as an aside, I never use COMMON because I don't compile my sources into separate object files (FB uses the term Modules which normally have a .bas extension). I use the traditional PB approach of simply #INCLUDE'ing the source files into the main file. Doing it that way you can just use SHARED for declaring global variables.
WinFBE allows you to compile your sources into object files. As you've seen, that's the issue that you encountered. By default, when WinFBE loads a .bas file (that is not the MAIN file) then it will set the file type to be Module.
