Floating toolwindows/childwindows
Started by ji_vildaasen, March 29, 2020, 07:48:18 PM
ji_vildaasen
Hi
I'm trying to make a program with one "main" window and a few other windows that should always be in front of the main window and clip to the main window.
Some time ago when testing out WinFBX I got it working with this code:
' Init Main Window
   dwStyle = WS_VISIBLE or WS_OVERLAPPEDWINDOW OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS or WS_MAXIMIZE
   dwExStyle = WS_EX_CONTROLPARENT OR WS_EX_CLIENTEDGE
   MainWindow.Create(NULL, "Main window", @MainWindow_WndProc, 50, 50, 1000, 800, dwStyle, dwExStyle)
   MainWindow.Brush = CreateSolidBrush(BGR(92, 92, 92))
   UpdateWindow MainWindow.hWindow
' Init Tool Window
   dwStyle = WS_VISIBLE or WS_CAPTION or WS_MAXIMIZEBOX or WS_CHILD or WS_SIZEBOX or WS_CLIPSIBLINGS or WS_HSCROLL or WS_VSCROLL
   dwExStyle = WS_EX_TOOLWINDOW
   ToolWindow.Create(MainWindow.hWindow, "Tool", @ToolWindow_WndProc, 300, 200, 800, 600, dwStyle, dwExStyle)
Is it possible to do the same in the WinFBE using the designer?
Hi,
Yes, creating such applications is pretty straight forward in WinFBE. I have attached a simple project that shows the basics of how to do it.
The popup window "frmTool1" set the BorderStyle to "FormBorderStyle.FixedToolWindow".
To display the popup tool window, you will want to display it modeless and make frmMain as the owner form.
frmTool1.Show( frmMain )
Note: The above displays the form as modeless. If you need to display a modal form, then you would use:
frmTool1.ShowDialog( frmMain )
Hope this helps!
ji_vildaasen
Thank you, that was easy =)
Is it also possible to add the default scrollbars with WS_HSCROLL / WS_VSCROLL on a window in the designer? I tried to make the Toolwindow a child window, but that didn't change anything, like when adding "WS_CHILD" will make the tool windows position relative to the parent window(plus clip the child window to the size of the parent).
Also before seeing your code, I tried:
frmTool1.Parent = frmMain.hWindow
frmTool1.Show
But this gives a compiler error for "No matching overload...Parent()". Should this have worked?
You set the "ChildForm" property to TRUE for frmTool1 and then display it as a child frmMain
   frmTool1.ShowChild( frmMain )
   Function = 0
The overload error occurs because Parent is not defined as an object but rather a pointer (because of some limitations with FB's ByRef).
The following two syntaxes should work:
   frmTool1.Parent = @frmMain
   frmTool1.hWindowParent= frmMain.hWindow
I don't think I built into the designer a way to add default scrollbars. I'll put that on my To Do list.
ji_vildaasen
When I try this, I get a child window placed on the main window(which is probably what most would want). I'm trying to create a movable child window like in this code(that follows and clips to the main window):
#define UNICODE
#INCLUDE ONCE "Afx\CWindow.inc"
USING Afx
declare FUNCTION MainWindow_WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
declare FUNCTION ToolWindow_WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
Dim shared MainWindow as CWindow
Dim shared ToolWindow as CWindow
' // Set process DPI aware
   AfxSetProcessDPIAware
   dim AS UINT dwStyle, dwExStyle
' Init Main Window
   dwExStyle = 0
   MainWindow.Create(NULL, "Main", @MainWindow_WndProc, 50, 50, 1000, 800, dwStyle, dwExStyle)
' Init ToolWindow
   dwStyle = WS_HSCROLL or WS_VSCROLL or WS_CHILD or WS_VISIBLE or WS_CAPTION
   ToolWindow.Create(MainWindow.hWindow, "Tool", @ToolWindow_WndProc, 300, 200, 500, 500, dwStyle, dwExStyle)
   ToolWindow.Brush = CreateSolidBrush(BGR(250, 250, 250))
   UpdateWindow ToolWindow.hWindow
   DIM uMsg AS MSG
' // Message loop
   WHILE .GetMessageW(@uMsg, NULL, 0, 0)
      ' // Processes accelerator keys for menu commands
      IF MainWindow.AccelHandle = NULL OR .TranslateAcceleratorW(MainWindow.hWindow, MainWindow.AccelHandle, @uMsg) = 0 THEN
      ' // Translates virtual-key messages into character messages.
         .TranslateMessage @uMsg
      ' // Dispatches a message to a window procedure.
         .DispatchMessageW @uMsg
   WEND
'____________________________________________________________________________________________________
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
       CASE WM_DESTROY
         ' // End the application
         PostQuitMessage(0)
   SELECT CASE uMsg
   CASE WM_COMMAND
            CASE IDCANCEL
   CASE WM_DESTROY
Hi,
Attached is a project that emulates the code that you posted. I had to modify the child form's styles in its Load event. I have also attached a screenshot of the running program.
ji_vildaasen
That's excellent! Nice to have such flexibility on top of the designer.
A few small notes/possible bugs(from a first time user):
- Unlike when selecting "FormBorderStyle.FixedToolWindow", selecting "FormBorderStyle.SizableToolWindow shows (in the designer) a form without a caption(but it shows up correctly when running the code).
- Is it correct behavior that when double clicking on the caption box of a "FormBorderStyle.FixedToolWindow" it maximizes the ToolWindow?
Under Help->Form (wfxForm)->Events , maybe add a small note about activating Events in the designer before trying to use them in the code. Its a bit embarrassing, but the first time I wanted to test the events I tried to create the event functions manually in the form code =)
Under Help->Form (wfxForm)->During form creation, there is two events called "FormLoad" and "FormFormActivated", that should probably be just "Load" and "Activated" ?
Thanks for the feedback! I'll work through them tomorrow and get the corrections made.
