WinFormsX
Started by Jim Dunn, June 01, 2022, 06:57:28 PM
Jim Dunn
Paul, do you have any examples of using WinFormsX other than looking thru the WinFBE code??
Sorry, I do not. That library could be used standalone (I guess) but in my opinion if you are going to use it outside of the WinFBE editor then you may as well go one step lower and use Jose's CWindow classes from WinFBX.
