WinFBE - Line Numbers In Form files
Started by SeaVipe, June 02, 2022, 05:26:08 PM
Is it possible to have a value similar to __LINE__ that would be accurate when used in Form files? Reading the form's file and subtracting the line number associated with "WINFBE_CODEGEN_END"  from __LINE__ might work but nothing I come up with is particularly elegant (or functional). :|
Category: WishList
I would first question as to why such a feature would be needed? Can you describe what it is you are doing that makes it necessary to inspect the resulting Form source file?
philbar
Seavipe, did you try this:
const lline = __LINE__
' frmMain form code file
   print "This is physical line "; __LINE__; " but virtual line "; __LINE__ - lline + 1
No need to look at the hidden code.
Quote from: Paul Squires on June 03, 2022, 07:30:00 AM
Almost exclusively for debugging, like:
On Local Error GoTo errhandler
line_num = __LINE__
errhandler:
? sNote, LCase(__FUNCTION__), __FILE__, line_num
In all but Form modules this works just fine.
Thanks @philbar your suggestion works, I'll create a unique CONST for each Form.
