ListView
Started by SeaVipe, August 27, 2022, 03:32:37 PM
I've had an Error Code 6 in my code that was hard to track down.
Some time ago you posted this to enable the top row of a ListView to be highlighted:
Function ListView_SetTopIndex( byval hLV as hwnd, byval index As Long ) As Long
    Dim rc AS RECT
    SendMessage( hLV, LVM_GETITEMRECT, 0, cast(LPARAM, @rc) )
    Dim As Long gle = GetLastError()
    If gle > 0 Then ? gle ' gle = 0
    SendMessage( hLV, LVM_SCROLL, 0, (index - GetScrollPos(hLV, SB_VERT)) * (rc.Bottom - rc.Top))
    If gle > 0 Then ? gle ' Prints 6.
    Print GetLastError() ' Clears error code.
Function = 0
This identical Function used in another app, and called exactly the same way, does not throw an error.
Odd that only one of several projects with the same code and calling method, returns an error.
