Listview Demo help
Started by Frank Bruebach, March 18, 2024, 09:26:53 AM
Frank Bruebach
Hello all
Need a little Help to fix this Listview example. Help is Welcome
Thanks in advance, Frank
' freebasic cWindow listview demo test
#define UNICODE
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "Afx/AfxGdiPlus.inc"
#INCLUDE ONCE "Afx/AfxMenu.inc"
USING Afx
' // Menu identifiers
ENUM
    IDM_UNDO = 5000   ' Undo
    IDM_REDO          ' Redo
    IDM_HOME          ' Home
    IDM_SAVE          ' Save
    IDM_EXIT          ' Exit
END ENUM
' Constants for controls
ENUM
    IDC_LISTVIEW = 1000
END ENUM
' // Forward declaration
   DIM pNmh  AS NMHDR PTR            ' // Pointer to a NMHDR structure
   DIM pLvNm AS NMLISTVIEW PTR       ' // Pointer to a NMLISTVIEW structure
   DIM pLvCd AS NMLVCUSTOMDRAW PTR   ' // Pointer to a NMLVCUSTOMDRAW structure
     SELECT CASE uMsg
         CASE WM_CREATE
         CASE WM_COMMAND
                     CASE IDCANCEL
                     CASE IDM_UNDO
                         MessageBox hwnd, "Undo option clicked", "Menu", MB_OK
                     CASE IDM_REDO
                         MessageBox hwnd, "Redo option clicked", "Menu", MB_OK
                     CASE IDM_HOME
                         MessageBox hwnd, "Home option clicked", "Menu", MB_OK
                     CASE IDM_SAVE
                         MessageBox hwnd, "Save option clicked", "Menu", MB_OK
                     CASE IDM_EXIT
         CASE WM_SIZE
         ' // Resize the ListView control and its header
            DIM hListView AS HWND, pWindow AS CWindow PTR
            pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            hListView = GetDlgItem(hwnd, IDC_LISTVIEW)
            '----------------- problem zone ---------------------------- //
            ' pWindow->MoveWindow hListView, 5, 5, pWindow->ClientWidth - 10, pWindow->ClientHeight - 10, TRUE
        CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
  ' Initialize common controls
      InitCommonControls()
   DIM pWindow AS CWindow
   pWindow.Create(NULL, " Demo ListView WinFBE", @WndProc)
   pWindow.ClassStyle = CS_DBLCLKS   ' // Change the window style to avoid flicker
   pWindow.SetClientSize(565, 420)
   pWindow.Center
' // Add a button -> but I needed here some Radiobuttons too ;)
   pWindow.AddControl("Button", , IDCANCEL, "&Close", 280, 280, 75, 23)
   ' // Adds a listview
   hListView = pWindow.AddControl("ListView", pWindow.hWindow, IDC_LISTVIEW, "") ' correct ?
   ' // Add some extended styles
   DIM dwExStyle AS DWORD
   dwExStyle = ListView_GetExtendedListViewStyle(hListView)
   dwExStyle = dwExStyle OR LVS_EX_FULLROWSELECT OR LVS_EX_GRIDLINES
   ListView_SetExtendedListViewStyle(hListView, dwExStyle)
   ' // Add the header's column names
   DIM i AS LONG, lvc AS LVCOLUMNW, wszText AS WSTRING * 260
   lvc.mask = LVCF_FMT OR LVCF_WIDTH OR LVCF_TEXT OR LVCF_SUBITEM
   FOR i = 0 TO 4
      wszText = "Column " & STR(i)
      lvc.pszText = @wszText
      lvc.cx = pWindow.ScaleX(110)
      lvc.iSubItem = i
      SendMessageW(hListView, LVM_INSERTCOLUMNW, i, CAST(LPARAM, @lvc))
   ' // Populate the ListView with some data
   DIM x AS LONG
   DIM lvi AS LVITEMW
   lvi.mask = LVIF_TEXT
   FOR i = 0 to 29
      lvi.iItem = i
      lvi.iSubItem = 0
      wszText = "Column 0 Row" + STR(i)
      lvi.pszText = @wszText
      ListView_InsertItem(hListView, @lvi)
      FOR x = 1 TO 4
         lvi.iSubItem = x
         wszText = "Column " & STR(x) & " Row" + STR(i)
         SendMessageW hListView, LVM_SETITEMTEXTW, i, CAST(LPARAM, @lvi)
   ' // Select the fist item
   ListView_SetItemState(hListView, 0, LVIS_FOCUSED OR LVIS_SELECTED, &H000F)
   ' // Set the focus in the ListView
   SetFocus hListView
PS where U can find Infos about Control wrapper functions for Afx?
How about this....
            pWindow = AfxCWindowPtr(hwnd)
             if pWindow then
QuotePS where U can find Infos about Control wrapper functions for Afx?
Check out all of the *.inc files in the \inc\Afx folder. Specifically, for ListView, look at AfxCtl.inc.
#2
Hi Frank,
Please use updated code, not code posted in the forum 8 or 9 years ago when I was writing the Afx framework and doing changes everyday.
If you had used the template available from the WinFBE editor, you wouldn't have had that problem.
This is the updated ListView example available from WinFBE:
' Microsoft Windows
' File: CW_COMMCTRL_ListView.fbtpl
' Contents: CWindow with a ListView
' Compiler: Free Basic
' Copyright (c) 2016 José Roca. Freeware. Use at your own risk.
#define UNICODE
USING Afx
#define IDC_LISTVIEW 1001
' Main
   ' // Create the main window
   pWindow.Create(NULL, "CWindow with a ListView", @WndProc)
   pWindow.SetClientSize(565, 320)
   pWindow.Center
   hListView = pWindow.AddControl("ListView", , IDC_LISTVIEW)
   DIM lvc AS LVCOLUMNW, wszText AS WSTRING * 260
   FOR i AS LONG = 0 TO 4
      lvc.iSubItem = i
      ListView_InsertColumn(hListView, i, @lvc)
   DIM lvi AS LVITEMW
   FOR i AS LONG = 0 to 29
      lvi.iItem = i
      lvi.iSubItem = 0
      wszText = "Column 0 Row" + WSTR(i)
      FOR x AS LONG = 1 TO 4
         wszText = "Column " & WSTR(x) & " Row" + WSTR(i)
         ListView_SetItemText(hListView, i, x, @wszText)
   ' // Select the fist item (ListView items are zero based)
   ListView_SelectItem(hListView, 0)
   SetFocus hListView
' ================================================================e========================
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
            ' // Retrieve the handle of the ListView control
            DIM hListView AS HWND = GetDlgItem(hwnd, IDC_LISTVIEW)
            ' // Move the ListView control
            IF pWindow THEN pWindow->MoveWindow hListView, 5, 5, pWindow->ClientWidth - 10, pWindow->ClientHeight - 10, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
   ' // Pass unprocessed messages to DefWindowProc
Frank Bruebach
#3
Hi jose...
I would have liked to do that too, but I couldn't find a current Listview example (using Afx) other than the treeview example in the examples sample projects of WinFBE Editor
I have downloaded WinFBE suite and your winfbx master files
Thanks for your Update
Regards Frank
In the examples folder are the examples that use resources. The templates are available directly from the editor clicking the button with an arrow in the top ledt corner.
Frank Bruebach
#5
Thank you for the Tip good to know that!
I have checked a Lot of example already very good Work Jose and Paul..
Only the "notepad.bas" (visual Designer Projects) its Not running...
AfxRichEdit.inc  Line 1166 Here Error passing different Pointer types...
Thx, Frank
