tiko freebasic compatibility best practice
Started by ron77, November 12, 2026, 09:20:20 AM
ron77
hi
i apologize for the silly question -
in order to have tiko compile my old freebasic code that uses libraries such as bass lib squlite3 lib window9 gui lib libvt (made a special version that is compatible for both fb and tiko) and so on...
in order for tiko to compile my fb code i usually copy headers from my freebasic include/ subfolder into tiko inc/ subfolder i make sure that the copying skip files and headers that are already there with same names - that's how i am able to compile with tiko using fb libs
my question is is this good practice? i know tiko is suppose to be fb compatible but if so am what i'm doing is a good habit or should i just stop doing it and just use the headers and libs that tiko brings with itself?
ron77
There is absolutely nothing wrong with using the #Include approach.
Once your app is working with #Include, you can then experiment with things like #Import, #foreignlib, etc.
Tiko is compatible with #lang "fb" so porting from FB should be mostly trouble free.
ron77
another dumb question...
just tiko compile and run sdl3 audio wav example but i wonder how tiko managed to compile and run it without a header .bi for sdl3 (i installed sdl3 with 'sudo apt install libsdl3-dev') is tiko able to use c headers and libraries without a tiko header?
sorry for the silly question - i should really read the tiko book
ron77
SDL3 is a built in package in tiko.
Take a look at the "pkg" folder (short for "packages"). In there you'll find several sub folders. "std" is the standard library files; "sys" contains system files, most notably the "win" or Windows files (José is maintaining this collection); and finally "vendor" where some 3rd party packages reside like SDL3, Raylib, Sqlite, etc.
In tiko, you simply need to "#import" the package you need.
Yes, read the tiko book and browse through the tiko by-example book also. If you make it through all of that then you'll be a tiko superstar.  :)
...and also yes, tiko can use most C headers directly via the #cinclude statement. The tiko wiki has a full tutorial on using raw C headers directly with tiko.
