Multiple Compiler Support
Started by David Martin, February 21, 2005, 07:50:53 PM
David Martin
It would be nice if when you go to Project -> Compile or Build & Execute that you could choose which compiler to use if you have more than one defined.
I realize you can set the compiler in Project Properties, by the way both compilers are called PBWin.exe there, but it would be easier with a sub menu.
Also, it would be nice to support more than two.
