Resource Modules
Started by John Messingham, February 21, 2005, 08:43:05 PM
John Messingham
Hi,
I am trying to create a resource module to contain some icons for my application. When I compile I get a 'Micosoft Resource Compiler' error. Has anyone got a sample resource file I could look at.
Make sure that you are using FireFly 1.10 because previous versions had a bug regarding user defined resource files.
From the Help file:
FIX: User defined resource files were not being added to the main FireFly generated project resource file in some instances.
Do not put the #include "resource.h" line in your resource module.
Maybe you can post your file so we can take a look at what you're attempting to do?
Also, try taking a look at the .rc files that FireFly generates for a project.
John Messingham
Thanks for the reply. I looked in the files generated by FF and could see where I was going wrong. On the right path now.
