Toolbar
Started by Anonymous, March 14, 2005, 01:11:57 PM
Anonymous
I can not change the icon in the Toolbar.  :cry:
In the ForeFly IDE i can see the right icon (above),
after compiling there is still the old one (below).
If i remove the button -compiling - the Button in gone,
if i create the button again (with new icon)-  it's then same.
only the old icon (below)
Thank's for help
Rudolf Fürstauer
4th icon over looks like a different color depth (yellow/green square at connection point).  Could their be 2 different icons stored in the icon/ico file resource so that one is loaded in the IDE and when compiling the other depth is used because of display settings, etc?
Paul also is making a lot of new changes in the Toolbars that will allow you to better specify what icons to load to be sure of things, so that may fix the problem too.
Anonymous
Hi Roger!
no, there is 3 time's then same icon on the 4th and also on the 6th.
Rudolf  Fürstauer
Anonymous
If i add a new Button so i get the Button, but no Icon!!!
Thank's for help
Rudolf Fürstauer
Hi Rudolf,
Please send me an email at support@planetsquires.com so we can discuss this. I may have a solution for you.
