ActiveX DLLs
Started by Art Araya, April 26, 2005, 01:40:08 PM
Art Araya
Are ActiveX/COM DLLs supported by FireFly?  If so, where can I find information about this?
TIA
John Messingham
There is a section in the help file that explains how to use ActiveX components with Firefly.
Art Araya
Thanks for the reply John.  That help file topic seems to have to do with ActiveX controls.  My question has to do with ActiveX DLLs, not ActiveX controls.  I think the procedure must be different than what I am reading in the help file topic "Working with OCX/ActiveX Controls "
Is there some other help topic that I should be looking at instead?
John Messingham
The com section in the PowerBasic help file,
the activex/com master/god's website
http://com.it-berater.org/
I only wish I could help more, I have touched on this subject myself but other things keep me from getting to grips with it.
I can't think of why ActiveX DLL's wouldn't work.... Maybe Jose would know for sure but I can't see why they would be any different than regular ocx's.
Michael Meeks
Hi,
I use them all the time - and find no problems with ActiveX DLL's...
In fact - I prefer them over the OCX - because of other runtime/requirements.
Mike
Jose Roca
Visual controls (know as ActiveX or OCXs) need a container (FireFly uses ATL71.DLL as the container). It doesn't matter if is extension is OCX, DLL or whatever. Non visual components, such ADO, WMI, MSXML, etc., do not need a container and, therefore, must be initialized and used as shown in the PowerBASIC help file.
Art Araya
Thanks guys.  I was looking to FireFly for the answer when the keys seem to be in PB.  The last version of PB I had was several years old when there was no support for COM.  I now have version 8 of PB and need to get up to speed with all of the changes.  Thanks for pointing me in the right direction.
ARt
