About ListBox and ListView
Started by Jean-Pierre LEROY, May 09, 2005, 01:50:18 PM
Jean-Pierre LEROY
Hi,
I'm just converting a ListBox into a ListView with FireFly.
With the ListBox I've got a LBN_DBLCLK message to process the user double-clicks :
Function FORM1_LIST1_LBN_DBLCLK ( _
                               ControlIndex  As Long,  _  ' index in Control Array
                               hWndForm      As Dword, _  ' handle of Form
                               hWndControl   As Dword, _  ' handle of Control
                               idListBox     As Dword  _  ' identifier of listbox
With the ListView, I understand that the equivalent would be the LVN_ITEMACTIVATE message, but there is no LVN_ITEMACTIVATE message handler to process this message in FireFly.
1. Is-there any workaround for this one ?
2. Paul can you provide a separate message handler for LVN_ITEMACTIVATE for the ListView control ?
Here is the way that I catch double-clicks in a ListView. I respond to the %NM_DBLCLK notification that gets sent to the parent window (i.e. the Form).
Function FORM1_WM_NOTIFY ( _
                        idCtrl       As Dword,     _  ' control ID
                        ByVal pNMHDR As NMHDR Ptr  _  ' pointer to NMHDR structure
    'test to see if this is our ListView sending the message
    Select Case As Long @pNMHDR.idfrom
       Case IDC_FORM1_LISTVIEW1
            'process the double-click notification message
            If @pNMHDR.code = %NM_DBLCLK  Then
               'get the ListView row that was clicked on.
               row& = FF_ListView_GetSelectedItem (HWND_FORM1_LISTVIEW1)
               MsgBox " NM_DBLCLK on listview row:" & Str$(row&)
Jean-Pierre LEROY
Thank you for your help; I use your code and modify it to respond to %LVN_ITEMACTIVATE notifcation; it works very well.
I prefer to use the %LVN_ITEMACTIVATE instead %NM_DBLCLK because when the ListView is empty (no items in the ListView) :
%NM_DBLCLK still send a notifcation message and I don't need a message at that time.
%LVN_ITEMACTIVATE doesn't send a notification message, because there is no item selected in the ListView.
            'process the ListView Item Activate notification message
      If @pNMHDR.code = %LVN_ITEMACTIVATE  Then
               MsgBox " LVN_ITEMACTIVATE on listview row:" & Str$(row&)
