Problem with Option control.
Started by Elias Montoya, November 20, 2006, 02:18:04 AM
Hi Franck,
Right you are. The messages are getting fired during creation of the control. This problem is related to another long standing problem where the EN_CHANGE message for TextBoxes gets fired during control creation. I have built in a fix for this for FireFly 3. For FireFly 2 you need to do the following:
(1) Add a global variable to your Form/Project:
Global gFireMessages As Long
(2) In each of your Option Button BN_CLICKED message handlers put code such as the following to exit the function if the flag has not been set:
Function FORM1_OPTION1_BN_CLICKED ( _
If gFireMessages = %FALSE Then Exit Function
MsgBox "fired Option 1"
(3) The last line in the WM_CREATE message handler for the Form should set the global flag to TRUE:
Function FORM1_WM_CREATE ( _
gFireMessages = %TRUE
I hope this little workaround will help you.
Franck Stegli
Yes I prefer to use this type of workaround (while waiting for FF3 ;) ) instead of to take any risk that the result is being hazardous during dev time.
Also placing "gFireMessages = %FALSE" before any Form_SHOW is not too fastidious for a stable program  ;D
Merci .
