AfxRegExpInStr Function
Started by José Roca, April 15, 2011, 03:56:07 AM
Jose - Dude, you're amazing. Don't know what we would do without you.
As I said, dead code removal is all I needed to extend the language. I noticed that DDT had two statements, LISTVIEW FIT HEADER and LISTVIEW FIT CONTENTS, for which I had not an equivalent wrapper, and I wrote ListView_FitHeader and ListView_FitContent. Then I went beyond and added ListView_AutoSizeColumns, ListView_AutoSizeHeader and several more.
With the new ODBC class, I have made the use of ODBC as easy as ADO:
' Microsoft Windows
' File: CODBCEX_BasicSteps.bas
' Contents: CODBC class example
' Demonstrates the basic steps to use the CODBC class to connect to a database, execute a
' query and fetch the results.
' Compilers: PBWIN 10+, PBCC 6+
' Headers: Windows API headers 2.03+
' Copyright (c) 2011 Jose Roca. Freeware. Use at your own risk.
' Portions Copyright (c) Microsoft Corporation. All Rights Reserved.
' CSED_PBCC  -  Use the PBCC compiler
#COMPILE EXE
#DIM ALL
#INCLUDE "CODBC.INC"
' Main
FUNCTION PBMAIN
   LOCAL pOdbc AS IOdbc
   pOdbc = NewOdbc(%SQL_OV_ODBC3_80)
   IF ISNOTHING(pOdbc) THEN EXIT FUNCTION
   TRY
      ' // Create a connection object
      LOCAL pCon AS IOdbcConnection
      pCon = pOdbc.Connection("Connection1")
      ' // Open the database
      pCon.OpenDatabase("DRIVER={Microsoft Access Driver (*.mdb)};DBQ=biblio.mdb;UID=;PWD=;")
      ' // Allocate an statement object
      LOCAL pStmt AS IOdbcStatement
      pStmt = pCon.Statement("Statement1")
      ' // Cursor type
      pStmt.SetMultiuserKeysetCursor
      ' // Generate a result set
      pStmt.ExecDirect ("SELECT TOP 20 * FROM Authors ORDER BY Author")
      ' // Parse the result set
      LOCAL strOutput AS STRING
      DO
         ' // Fetch the record
         IF ISFALSE pStmt.Fetch THEN EXIT DO
         ' // Get the values of the columns and display them
         strOutput = ""
         strOutput += pStmt.GetDataString(1) & " "
         strOutput += pStmt.GetDataString(2) & " "
         strOutput += pStmt.GetDataString(3)
         STDOUT strOutput
         ' // Note: Instead of retrieving the data by ordinal,
         ' // you can also do it by column name.
'         strOutput = ""
'         strOutput += pStmt.GetDataString("Au_ID") & " "
'         strOutput += pStmt.GetDataString("Author") & " "
'         strOutput += pStmt.GetDataString("Year Born")
'         STDOUT strOutput
      LOOP
   CATCH
      ' // Display error information
      STDOUT OdbcOleErrorInfo(OBJRESULT)
      WAITKEY$
   END TRY
   ' // Destroy the class
   pOdbc = NOTHING
   WAITKEY$
A similar one could be written for SQLite.
