Pages: 1 [2]
Author Topic: MakeLIB - utility to create (*.a) import library from DLL (source included)  (Read 10049 times)
James Fuller
Jose,
  Try this one.
James
Thanks very much. Apparently it works. I have called one of the functions and the test compiles and runs. Will have to do a more extensive test.
But what I would like to know is what I have to do to build a library that works, instead of having to beg for it, because there are many that I will need. What have you done? I have used the .def file that you posted an run dlltool. It has created a library, but the linker doesn't like it. Why?
James Fuller
Jose,
  I don't know how you went about it so I will provide my method.
I have always used msys: http://www.mingw.org/wiki/msys for building Mingw compatible libraries.
The rage today is msys2 but it comes with it's own version of gcc/g++ and I never (spent little time) figured out how to tell it to use something else.
With msys I can edit the "msys/1.0/etc/fstab" file  to tell it which compiler/tools to use. You do have to exit and rerun after changing.
Some of the MinGW 64 bit compilers can produce 32bit executables but they are a pain to use with most of the library sources that use "configure" to set up a build of the library. I always install both the 64bit and 32bit versions so I can build 32/64 by changing the fstab entry.
For this specific case I installed both FreeBasic 32/64 along with the recommended Mingw gnu 32/64 toolchains and renamed them FbMingw32/FbMingw64 respectively.
I also have Visual Studio 2015 Community installed.
I downloaded the reimp source and built both 32 and 64 bit versions using FbMingw32/64. This is probably not necessary but... Many warnings on both builds but they both ran fine(?).
Now the search begins to find the propsys.lib files. I found them in two places:
64bit:
C:\Program Files (x86)\Windows Kits\8.1\Lib\winv6.3\um\x64
C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Lib\x64
32bit:
C:\Program Files (x86)\Windows Kits\8.1\Lib\winv6.3\um\x86
I used the ones from the Windows Kits\8.1\.
I created folders for both 32/64 and copied the respective propsys.lib files to them
I also added the 32/64 bit versions of reimp.
I fired up msys and navigated to the folders. Remember to use /c/ for the drive and edit fstab.
$ cd /c/work/propsys32
$ reimp -d propsys.lib
Note the 32/64 def files will differ but the last line in each def file I believe is for use with C##.
_WinRTPropertyValueToPropVariant@8   @436
Delete this last line before running dlltool.
$ dlltool -k -d propsys.def -l libpropsys.a
That's it.:)
James
No, that's not all.
Why if I use dlltool -k -d propsys.def -l libpropsys.a in my computer the resulting library does not work?
Are you using the dlltool.exe that comes with FB or another one?
[quote]
64bit:
32bit:
In Windows 7 you find the 64 bit one in System32, and the 32 bit one in SysWOW64 (the DLLs, not the LIBs).
« Last Edit: June 13, 2016, 02:24:34 PM by Jose Roca »
James Fuller
I am using the dlltool from the FbMingw32/64.
The 32bit one creates a 32bit library the 64 a 64 library.
The .lib files are part of the Visual C++ sdk.
James
And there is a way to get them (both 32 and 64 bit) in binary form, without having to install MinGW, learn C programming and compile the source code?
Apparently, the Linux guys think that everybody has to learn C.
James Fuller
They are included with both 32/64 FreeBasic.
Just make sure you use the right one.
James
reimp.exe is not included, and the libraries generated with dlltool.exe don't work, at least the ones that I've tried.
But it doesn't matter, I give up.
« Last Edit: June 14, 2016, 04:38:14 AM by Jose Roca »
I have tried the reimp.exe 32-bit that I have found in the web and it works.
reimp -d mCtrl.lib
dlltool -k -d mCtrl.def -l libmCtrl.dll.a
the .def file is different from the one generated by the other tools:
LIBRARY "mCtrl.dll"
EXPORTS
DllGetVersion@4
mcBeginBufferedAnimation@32
mcBeginBufferedPaint@20
mcBeginPanningFeedback@4
mcBufferedPaintClear@8
mcBufferedPaintInit@0
mcBufferedPaintRenderAnimation@8
mcBufferedPaintStopAllAnimations@4
mcBufferedPaintUnInit@0
mcButton_Initialize@0
mcButton_Terminate@0
mcChart_Initialize@0
mcChart_Terminate@0
mcCloseThemeData@4
mcCreateDialogIndirectParamA@24
mcCreateDialogIndirectParamW@24
mcCreateDialogParamA@24
mcCreateDialogParamW@24
mcDialogBoxIndirectParamA@24
mcDialogBoxIndirectParamW@24
mcDialogBoxParamA@24
mcDialogBoxParamW@24
mcDrawThemeBackground@24
mcDrawThemeBackgroundEx@24
mcDrawThemeEdge@32
mcDrawThemeIcon@28
mcDrawThemeParentBackground@12
mcDrawThemeParentBackgroundEx@16
mcDrawThemeText@36
mcDrawThemeTextEx@36
mcEnableThemeDialogTexture@8
mcEndBufferedAnimation@8
mcEndBufferedPaint@8
mcEndPanningFeedback@8
mcExpand_Initialize@0
mcExpand_Terminate@0
mcGetBufferedPaintBits@12
mcGetBufferedPaintDC@4
mcGetBufferedPaintTargetDC@4
mcGetBufferedPaintTargetRect@8
mcGetCurrentThemeName@24
mcGetThemeAppProperties@0
mcGetThemeBackgroundContentRect@24
mcGetThemeBackgroundExtent@24
mcGetThemeBackgroundRegion@24
mcGetThemeBitmap@24
mcGetThemeBool@20
mcGetThemeColor@20
mcGetThemeDocumentationProperty@16
mcGetThemeEnumValue@20
mcGetThemeFilename@24
mcGetThemeFont@24
mcGetThemeInt@20
mcGetThemeIntList@20
mcGetThemeMargins@28
mcGetThemeMetric@24
mcGetThemePartSize@28
mcGetThemePosition@20
mcGetThemePropertyOrigin@20
mcGetThemeRect@20
mcGetThemeStream@28
mcGetThemeString@24
mcGetThemeSysBool@8
mcGetThemeSysColor@8
mcGetThemeSysColorBrush@8
mcGetThemeSysFont@12
mcGetThemeSysInt@12
mcGetThemeSysSize@8
mcGetThemeSysString@16
mcGetThemeTextExtent@36
mcGetThemeTextMetrics@20
mcGetThemeTransitionDuration@24
mcGetWindowTheme@4
mcGrid_Initialize@0
mcGrid_Terminate@0
mcHitTestThemeBackground@40
mcHtml_Initialize@0
mcHtml_Terminate@0
mcImgView_Initialize@0
mcImgView_Terminate@0
mcIsAppThemed@0
mcIsCompositionActive@0
mcIsMenubarMessage@8
mcIsThemeActive@0
mcIsThemeBackgroundPartiallyTransparent@12
mcIsThemeDialogTextureEnabled@4
mcIsThemePartDefined@12
mcMditab_DefWindowProc@24
mcMditab_Initialize@0
mcMditab_Terminate@0
mcMenubar_HandleRebarChevronPushed@8
mcMenubar_Initialize@0
mcMenubar_Terminate@0
mcOpenThemeData@8
mcOpenThemeDataEx@12
mcSetThemeAppProperties@4
mcSetWindowTheme@12
mcSetWindowThemeAttribute@16
mcTable_AddRef@4
mcTable_Clear@8
mcTable_ColumnCount@4
mcTable_Create@12
mcTable_GetCellA@16
mcTable_GetCellW@16
mcTable_Release@4
mcTable_Resize@12
mcTable_RowCount@4
mcTable_SetCellA@16
mcTable_SetCellW@16
mcTheme_Initialize@0
mcTheme_Terminate@0
mcTreeList_Initialize@0
mcTreeList_Terminate@0
mcUpdatePanningFeedback@16
mcVersion@4
You would have saved me hours of headaches if you had posted reimp.exe as I requested, instead of the other tools that don't work with these visual basic libraries.
Now I need a reimp.exe for 64 bit.
« Last Edit: June 14, 2016, 07:20:40 AM by Jose Roca »
James Fuller
I must have missed your request, Sorry.
Attached find 32/64 reimp
James
Thanks very much. I have got it working.
Pages: 1 [2]
