Pages: 1 [2]
Author Topic: CWindow RC01 - Tab Control  (Read 6960 times)
Re: CWindow RC01 - IPAddress
« Reply #15 on: April 08, 2016, 04:02:23 PM »
IPAddress control example.
' Microsoft Windows
' File: CW_IPAddress.fbtpl - Template
' Contents: Demonstrates the use of the IPAddress control.
' Remarks: An Internet Protocol (IP) address control allows the user to enter an IP address
' in an easily understood format. This control also allows the application to obtain the
' address in numeric form rather than in text form.
#define unicode
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
CONST IDC_IPADDRESS = 1001
' Window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            CASE IDC_IPADDRESS
               IF HIWORD(wParam) = EN_CHANGE THEN
                  ' *** Put your code here ***
'                  Sample code: Get the address in string form
'                  DIM wszText AS WSTRING * 260
'                  GetWindowTextW(GetDlgItem(hwnd, IDC_IPADDRESS), @wszText, 260)
'                  OutputDebugStringW wszText
      CASE WM_NOTIFY
         DIM ptnmhdr AS NMHDR PTR = CAST(NMHDR PTR, lParam)
         SELECT CASE ptnmhdr->idFrom
            CASE IDC_IPADDRESS
               IF ptnmhdr->code = IPN_FIELDCHANGED THEN
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "IPAddress", @WndProc, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT)
   pWindow.Center
   ' // Add an IPAddress control
   DIM hCtl AS HWND = pWindow.AddControl("IPAddress", pWindow.hWindow, IDC_IPADDRESS, "", 120, 50, 120, 23)
   SetFocus hCtl
Re: CWindow RC01 - TreeView example
« Reply #16 on: April 09, 2016, 07:35:06 PM »
' Microsoft Windows
' File: CW_TreeView.fbtpl
' Contents: Template - CWindow with a TreeView
' Compiler: Free Basic
#define unicode
#define IDC_TREEVIEW 1001
' Inserts a new item in a tree-view control.
FUNCTION TreeView_AddItemW (BYVAL hwndTV AS HWND, BYVAL hParent AS HTREEITEM, BYVAL hInsertAfter AS HTREEITEM, BYVAL iImage AS LONG, BYVAL iSelectedImage AS LONG, BYREF wszText AS WSTRING) AS HTREEITEM
   DIM tvinsert AS TVINSERTSTRUCTW
   tvinsert.hParent             = hParent
   tvinsert.hInsertAfter        = hInsertAfter
   tvinsert.Item.iImage         = iImage
   tvinsert.Item.iSelectedImage = iSelectedImage
   tvinsert.Item.mask           = TVIF_TEXT OR TVIF_IMAGE OR TVIF_SELECTEDIMAGE
   tvinsert.Item.pszText        = @wszText
   tvinsert.Item.cchTextMax     = LEN(wszText)
   FUNCTION = CAST(HTREEITEM, SendMessageW(hwndTV, TVM_INSERTITEM, 0, CAST(LPARAM, @tvinsert)))
' Window procedure
' ================================================================e========================
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_NOTIFY
            CASE IDC_TREEVIEW
               IF ptnmhdr->code = CULNG(NM_DBLCLK) THEN
                  ' // Retrieve the handle of the TreeView
                  DIM hTreeView AS HWND = GetDlgItem(hwnd, IDC_TREEVIEW)
                  ' // Retrieve the selected item
                  DIM hItem AS HTREEITEM = CAST(HTREEITEM, SendMessageW(hTreeView, TVM_GETNEXTITEM, TVGN_CARET, CAST(LPARAM, NULL)))
                  ' // Retrieve the text of the selected item
                  DIM tvi AS TVITEMW
                  tvi.hitem = hItem
                  tvi.mask = TVIF_TEXT
                  tvi.psztext = @wszText
                  tvi.cchtextmax = SIZEOF(wszText)
                  SendMessageW(hTreeView, TVM_GETITEMW, 0, CAST(LPARAM, @tvi))
                  MessageBox hwnd, wszText, "", MB_OK
    CASE WM_DESTROY
          ' // End the application
         PostQuitMessage(0)
   ' // Pass unprocessed messages to DefWindowProc
' Main
   pWindow.Create(NULL, "CWindow with a TreeView", @WndProc)
   pWindow.ClassStyle = CS_DBLCLKS   ' // Change the window style to avoid flicker
   pWindow.SetClientSize(320, 375)
   pWindow.Center
   ' // Add a TreeView
   hTreeView = pWindow.AddControl("TreeView", pWindow.hWindow, IDC_TREEVIEW, "")
   pWindow.SetWindowPos hTreeView, NULL, 8, 8, 300, 320, SWP_NOZORDER
   ' // Add items to the TreeView
   DIM AS HTREEITEM hRoot, hNode, hItem, hSubNode
   ' // Create the root node
   hRoot = TreeView_AddItemW(hTreeView, 0, TVI_ROOT, 0, 0, "Root")
   ' // Create a node
   hNode = TreeView_AddItemW(hTreeView, hRoot, 0, 0, 0, "Node 1")
   ' // Insert items in the node
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 1")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 2")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 3")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 4")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 5")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 1 Item 6")
   ' // Expand the node
   SendMessageW hTreeView, TVM_EXPAND, CAST(WPARAM, TVE_EXPAND), CAST(LPARAM, hNode)
   ' // Create another node
   hNode = TreeView_AddItemW(hTreeView, hRoot, 0, 0, 0, "Node 2")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 1")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 2")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 3")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 4")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 5")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 2 Item 6")
   hNode = TreeView_AddItemW(hTreeView, hRoot, 0, 0, 0, "Node 3")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 1")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 2")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 3")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 4")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 5")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 3 Item 6")
   hNode = TreeView_AddItemW(hTreeView, hRoot, 0, 0, 0, "Node 4")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 1")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 2")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 3")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 4")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 5")
   hItem = TreeView_AddItemW(hTreeView, hNode, 0, 0, 0, "Node 4 Item 6")
   ' // Expand the root node
   SendMessageW hTreeView, TVM_EXPAND, CAST(WPARAM, TVE_EXPAND), CAST(LPARAM, hRoot)
   ' // Add a cancel button
   pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Cancel", 233, 338, 75, 23)
Re: CWindow RC01 - Buffered animation
« Reply #17 on: April 10, 2016, 08:40:25 AM »
' Microsoft Windows
' File: CW_BufferedAnimation.fbtpl - Template
' Contents: Demonstrates the use of BeginBufferedAnimation.
' Note: Click the left mouse button of the mouse to start the animation.
' Remarks: Minimum operating systems: Windows Vista, Windows 7
#define unicode
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "win/uxtheme.bi"
#define ANIMATION_DURATION 500
#define IDC_LABEL 1001
' Paints the icon
SUB PaintIt (BYVAL hwnd AS HWND, BYVAL hdc AS HDC, BYVAL nState AS LONG)
   DIM rc AS RECT
   GetClientRect(hwnd, @rc)
   FillRect(hdc, @rc, GetStockObject(WHITE_BRUSH))
   LoadIcon (NULL, IDI_APPLICATION)
   DIM hIcon AS HICON = LoadIcon(NULL, IIF(nState = 1, IDI_APPLICATION, IDI_ERROR))
   IF hIcon THEN
      DrawIcon(hdc, 10, 10, hIcon)
      DestroyIcon(hIcon)
' Window procedure
   DIM hdc AS HDC                              ' // Device context handle
   DIM ps AS PAINTSTRUCT                       ' // PAINTSTRUCT structure
   DIM animParams AS BP_ANIMATIONPARAMS        ' // Animation parameters
   DIM hbpAnimation AS HANIMATIONBUFFER        ' // Handle to the buffered paint animation
   DIM hdcFrom AS HDC                          ' // Handle of the DC where the application should paint the initial state of the animation
   DIM hdcTo AS HDC                            ' // Handle of the DC where the application should paint the final state of the animation
   DIM rc AS RECT                              ' // Coordinates of the window's client area
   STATIC fCurrentState AS LONG                ' // Boolean flag
   STATIC fNewState AS LONG                    ' // Boolean flag
   SELECT CASE uMsg
      CASE WM_CREATE
         fCurrentState = CTRUE
         fNewState = CTRUE
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_LBUTTONDOWN
         ' // Start animation
         fNewState = NOT fCurrentState
         InvalidateRect(hwnd, NULL, CTRUE)
      CASE WM_PAINT
         hdc = BeginPaint(hwnd, @ps)
         IF hdc THEN
            ' // See if this paint was generated by a soft-fade animation
            IF BufferedPaintRenderAnimation(hwnd, hdc) = 0 THEN
               animParams.cbSize = SIZEOF(BP_ANIMATIONPARAMS)
               animParams.style = BPAS_LINEAR
               ' // Check if animation is needed. If not set dwDuration to 0
               animParams.dwDuration = IIF(fCurrentState <> fNewState, ANIMATION_DURATION, 0)
               hbpAnimation = BeginBufferedAnimation(hwnd, hdc, @rc, _
                  BPBF_COMPATIBLEBITMAP, NULL, @animParams, @hdcFrom, @hdcTo)
               IF hbpAnimation THEN
                  IF hdcFrom THEN
                     PaintIt(hwnd, hdcFrom, fCurrentState)
                  IF hdcTo THEN
                     PaintIt(hwnd, hdcTo, fNewState)
                  fCurrentState = fNewState
                  EndBufferedAnimation(hbpAnimation, CTRUE)
                  PaintIt(hwnd, hdc, fCurrentState)
            EndPaint hwnd, @ps
      CASE WM_CTLCOLORSTATIC
         ' // Return the handle of the brush used to paint background
         IF GetDlgCtrlID(CAST(HWND, lParam)) = IDC_LABEL THEN
            FUNCTION = CAST(LRESULT, GetStockObject(WHITE_BRUSH))
      CASE WM_SIZE
         ' // Stops the buffered animation
         BufferedPaintStopAllAnimations hwnd
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Required: Initialize buffered painting for the current thread.
   IF FAILED(BufferedPaintInit) THEN EXIT FUNCTION
   pWindow.Create(NULL, "Buffered animation", @WndProc, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT)
   pWindow.Center
   ' // Add a label
   pWindow.AddControl("Label", pWindow.hWindow, IDC_LABEL, "  Click the icon with the mouse left button", 70, 10, 235, 23)
   ' // Process events
   ' // Required: Closes down buffered painting for the current thread.
   BufferedPaintUnInit
« Last Edit: April 10, 2016, 04:51:39 PM by Jose Roca »
Re: CWindow RC01 - Label Control
« Reply #18 on: April 10, 2016, 09:24:25 AM »
' Microsoft Windows
' File: CW_Label.fbtpl - Template
' Contents: Demonstrates the use of the Label control.
#define unicode
CONST IDC_LABEL = 1001
' Window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
            ' // Set the background and text colors
            SetBkColor CAST(HDC, wParam), &h00ED9564
            SetTextColor CAST(HDC, wParam), &h00FFFFFF
            ' // Return handle of brush used to paint background
            FUNCTION = CAST(LRESULT, GetPropW(CAST(HWND, lParam), "BRUSH"))
    CASE WM_DESTROY
         ' // Destroy custom brush
         DeleteObject CAST(HGDIOBJ, RemovePropW(GetDlgItem(hwnd, IDC_LABEL), "BRUSH"))
         PostQuitMessage(0)
' Main
   ' // Create the main windows
   pWindow.Create(NULL, "CWindow with a label control", @WndProc, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT)
   pWindow.Center
   ' // Add a label control
   DIM hLabel AS HWND = pWindow.AddControl("Label", pWindow.hWindow, IDC_LABEL, "This is a label", 100, 50, 150, 23)
   ' // Create custom brush for the label
   DIM tlb AS LOGBRUSH
   tlb.lbStyle = BS_SOLID
   tlb.lbColor = &h00ED9564
   DIM hBrush AS HBRUSH = CreateBrushIndirect(@tlb)
   SetPropw hLabel, "BRUSH", hBrush
   ' // Process events
Re: CWindow RC01 - Menu
« Reply #19 on: April 10, 2016, 09:54:41 AM »
' Microsoft Windows
' File: CW_Menu.fbtpl
' Contents: CWindow with a menu
#define unicode
' // Menu identifiers
#define IDM_NEW      1001   ' New file
#define IDM_OPEN     1002   ' Open file...
#define IDM_SAVE     1003   ' Save file
#define IDM_SAVEAS   1004   ' Save file as...
#define IDM_EXIT     1005   ' Exit
#define IDM_UNDO     2001   ' Undo
#define IDM_CUT      2002   ' Cut
#define IDM_COPY     2003   ' Copy
#define IDM_PASTE    2004   ' Paste
#define IDM_TILEH    3001   ' Tile hosizontal
#define IDM_TILEV    3002   ' Tile vertical
#define IDM_CASCADE  3003   ' Cascade
#define IDM_ARRANGE  3004   ' Arrange icons
#define IDM_CLOSE    3005   ' Close
#define IDM_CLOSEALL 3006   ' Close all
' Build the menu
FUNCTION BuildMenu () AS HMENU
   DIM hMenu AS HMENU
   DIM hPopUpMenu AS HMENU
   hMenu = CreateMenu
   hPopUpMenu = CreatePopUpMenu
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&File"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_NEW, "&New" & CHR(9) & "Ctrl+N"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_OPEN, "&Open..." & CHR(9) & "Ctrl+O"
         AppendMenuW hPopUpMenu, MF_SEPARATOR, 0, ""
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVE, "&Save" & CHR(9) & "Ctrl+S"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVEAS, "Save &As..."
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_EXIT, "E&xit" & CHR(9) & "Alt+F4"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Edit"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_UNDO, "&Undo" & CHR(9) & "Ctrl+Z"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CUT, "Cu&t" & CHR(9) & "Ctrl+X"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_COPY, "&Copy" & CHR(9) & "Ctrl+C"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_PASTE, "&Paste" & CHR(9) & "Ctrl+V"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Window"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEH, "&Tile Horizontal"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEV, "Tile &Vertical"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CASCADE, "Ca&scade"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_ARRANGE, "&Arrange &Icons"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSE, "&Close" & CHR(9) & "Ctrl+F4"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSEALL, "Close &All"
   FUNCTION = hMenu
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDM_NEW   ' IDM_OPEN, IDM_SAVE, etc.
               MessageBox hwnd, "New option clicked", "Menu", MB_OK
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   pWindow.Create(NULL, "CWindow with a menu", @WndProc)
   pWindow.SetClientSize(400, 250)
   pWindow.Center
   ' // Add a button
   pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Close", 280,180, 75, 23)
   ' // Create the menu
   DIM hMenu AS HMENU = BuildMenu
   SetMenu pWindow.hWindow, hMenu
Re: CWindow RC01 - Context menu
« Reply #20 on: April 10, 2016, 10:21:28 AM »
' Microsoft Windows
' File: CW_ContextMenu.fbtpl
' Contents: CWindow with a context menu
#define unicode
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_CONTEXTMENU
         ' // Build the context menu
         DIM hPopUpMenu AS HMENU = CreatePopUpMenu
         DIM pt AS POINT
         GetCursorPos @pt
         TrackPopupMenu hPopupMenu, 0, pt.x, pt.y, 0, hwnd, NULL
         DestroyMenu hPopupMenu
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   pWindow.Create(NULL, "CWindow with a context menu", @WndProc)
   pWindow.SetClientSize(400, 230)
   pWindow.Center
   ' // Add a label
   pWindow.AddControl("Label", pWindow.hWindow, IDC_LABEL, " Click the mouse right button", 110, 20, 175, 23)
   ' // Add a button
Re: CWindow RC01 - Tab Control
« Reply #21 on: April 10, 2016, 04:54:24 PM »
After installing the latest version of the compiler, the BufferedPaint example stopped working.
It happens that they have changed the value of True from 1 to -1.
Now we have to use CTrue.
Re: CWindow RC01 - Duplicate equates
« Reply #22 on: April 11, 2016, 07:53:12 AM »
The following equates are duplicated and must be remmed.
WinNT.bi
const JOB_OBJECT_LIMIT_RESERVED3 = &h00008000
const JOB_OBJECT_LIMIT_RESERVED4 = &h00010000
const JOB_OBJECT_LIMIT_RESERVED5 = &h00020000
const JOB_OBJECT_LIMIT_RESERVED6 = &h00040000
WinGdi.bi
const DM_UPDATE = 1
const DM_COPY = 2
const DM_PROMPT = 4
const DM_MODIFY = 8
#define DM_IN_BUFFER DM_MODIFY
#define DM_IN_PROMPT DM_PROMPT
#define DM_OUT_BUFFER DM_COPY
#define DM_OUT_DEFAULT DM_UPDATE
const DC_FIELDS = 1
const DC_PAPERS = 2
const DC_PAPERSIZE = 3
const DC_MINEXTENT = 4
const DC_MAXEXTENT = 5
const DC_BINS = 6
const DC_DUPLEX = 7
const DC_SIZE = 8
const DC_EXTRA = 9
const DC_VERSION = 10
const DC_DRIVER = 11
const DC_BINNAMES = 12
const DC_ENUMRESOLUTIONS = 13
const DC_FILEDEPENDENCIES = 14
const DC_TRUETYPE = 15
const DC_PAPERNAMES = 16
const DC_ORIENTATION = 17
const DC_COPIES = 18
WinUser.bi
const MF_END = &h00000080
imm.bi
const MOD_ALT = &h0001
const MOD_CONTROL = &h0002
const MOD_SHIFT = &h0004
commctrl.bi
const TBNRF_HIDEHELP = &h1
const TBNRF_ENDCUSTOMIZE = &h2
Re: CWindow RC01 - Ownerdraw button with just an image
« Reply #23 on: April 11, 2016, 05:03:01 PM »
' Microsoft Windows
' File: CW_ButtonOwnerdraw2.fbtpl - Template
' Contents: Ownerdraw button with just an image.
#define unicode
CONST IDC_BUTTON = 1001
' Window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_BUTTON
                  MessageBoxW hwnd, "Button clicked", "", MB_OK
      CASE WM_DRAWITEM
         SCOPE
            DIM pWindow AS CWindow PTR = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            DIM pDis AS DRAWITEMSTRUCT PTR = CAST(DRAWITEMSTRUCT PTR, lParam)
            IF pDis->CtlId <> IDC_BUTTON THEN EXIT FUNCTION
            ' Icon identifiers in User32.dll. Hacked with ResourceHacker.
            ' IDI_APPLICATION = 100, IDI_WARNING = 101, IDI_QUESTION = 102, IDI_ERROR = 103
            ' IDI_INFORMATION = 104, IDI_WINLOGO = 105, IDI_SHIELD = 106
            ' Used here to make the example simpler.
            ' Normally, you will load an icon or bitmap from a file or resource.
            DIM hIcon AS HICON = LoadImageW(GetModuleHandle("User32"), MAKEINTRESOURCEW(103), IMAGE_ICON, _
               pWindow->ScaleX(50), pWindow->ScaleY(50), LR_DEFAULTCOLOR)
            IF hIcon THEN
               DrawStateW pDis->hDC, NULL, NULL, CAST(LPARAM, hIcon), 0, 0, 0, 0, 0, DST_ICON
               DestroyIcon hIcon
         END SCOPE
         FUNCTION = CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   pWindow.Create(NULL, "CWindow with ownerdraw button", @WndProc, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT)
   pWindow.Center
   DIM hButton AS HWND = pWindow.AddControl("CUSTOMBUTTON", pWindow.hWindow, IDC_BUTTON, "&Ownerdraw button", 150, 50, 50, 50)
'  Alternate way:
'   DIM hButton AS HWND = pWindow.AddControl("Button", pWindow.hWindow, IDC_BUTTON, "&Ownerdraw button", 150, 50, 50, 50, BS_OWNERDRAW)
   SetFocus hButton
Re: CWindow RC01 - Ownerdraw button with "normal" and "hot" images
« Reply #24 on: April 11, 2016, 07:47:10 PM »
' Microsoft Windows
' File: CW_ButtonOwnerdraw3.fbtpl - Template
' Contents: Ownerdraw button with "normal" and "hot" images.
' When the mouse enters the button, the image changes to "hot",
' and when it leaves the normal image is restored.
#define unicode
' Window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_DRAWITEM
         SCOPE
            DIM hIcon AS HICON
            IF GetPropW(GetDlgItem(hwnd, IDC_BUTTON), "HOT") = 0 THEN
               hIcon = LoadImageW(GetModuleHandle("User32"), MAKEINTRESOURCEW(102), IMAGE_ICON, _
               hIcon = LoadImageW(GetModuleHandle("User32"), MAKEINTRESOURCEW(103), IMAGE_ICON, _
            IF hIcon THEN
               DestroyIcon hIcon
         END SCOPE
         FUNCTION = CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Processes messages for the subclassed Button window.
FUNCTION Button_SubclassProc ( _
   BYVAL hwnd   AS HWND, _                 ' // Control window handle
   BYVAL uMsg   AS UINT, _                 ' // Type of message
   BYVAL wParam AS WPARAM, _               ' // First message parameter
   BYVAL lParam AS LPARAM _                ' // Second message parameter
   ) AS LRESULT
   SELECT CASE uMsg
      CASE WM_GETDLGCODE
         ' // All keyboard input
         FUNCTION = DLGC_WANTALLKEYS
      CASE WM_LBUTTONDOWN
         MessageBoxW(GetParent(hwnd), "Click", "FreeBasic", MB_OK)
      CASE WM_KEYDOWN
            CASE VK_ESCAPE
               SendMessageW(GetParent(hwnd), WM_CLOSE, 0, 0)
      CASE WM_MOUSEMOVE
         ' // Tracks the mouse movement and stores the hot state
         DIM trackMouse AS TRACKMOUSEEVENT
         IF GetPropW(hwnd, "HOT") = 0 THEN
            trackMouse.cbSize = SIZEOF(trackMouse)
            trackMouse.dwFlags = TME_LEAVE
            trackMouse.hwndTrack = hwnd
            trackMouse.dwHoverTime = 1
            TrackMouseEvent(@trackMouse)
            SetPropW hwnd, "HOT", CAST(HANDLE, CTRUE)
            InvalidateRect hwnd, NULL, 0
            UpdateWindow hwnd
      CASE WM_MOUSELEAVE
         ' // Removes the hot state and redraws the button
         RemovePropW hwnd, "HOT"
         UpdateWindow hwnd
      CASE WM_DESTROY
         ' // REQUIRED: Remove control subclassing
         SetWindowLongPtrW hwnd, GWLP_WNDPROC, CAST(LONG_PTR, RemovePropW(hwnd, "OLDWNDPROC"))
   FUNCTION = CallWindowProcW(GetPropW(hwnd, "OLDWNDPROC"), hwnd, uMsg, wParam, lParam)
' Main
   pWindow.Center
   ' // Add a subclassed ownerdraw button
   DIM hButton AS HWND = pWindow.AddControl("CustomButton", pWindow.hWindow, IDC_BUTTON, "", 150, 50, 50, 50, 0, 0, 0, CAST(WNDPROC, @Button_SubclassProc))
   SetFocus hButton
Pages: 1 [2]
