Author Topic: CWindow RC02  (Read 2601 times)
JosÚ Roca
CWindow RC02
« on: April 25, 2016, 07:15:29 PM »
CWindow class, release candidate n║ 2.
JosÚ Roca
CWindow RC02 - Rebar control example
« Reply #1 on: April 25, 2016, 07:17:15 PM »
' Microsoft Windows
' File: CW_Rebar.fbtpl
' Contents: CWindow with a rebar control
#define unicode
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
CONST IDC_TOOLBAR = 1001
CONST IDC_CBBOX = 1002
CONST IDC_REBAR = 1003
enum
   IDM_CUT = 28000
   IDM_COPY, IDM_PASTE, IDM_UNDO, IDM_REDOW, IDM_DELETE, IDM_FILENEW, IDM_FILEOPEN
   IDM_FILESAVE, IDM_PRINTPRE, IDM_PROPERTIES, IDM_HELP, IDM_FIND, IDM_REPLACE, IDM_PRINT
end enum
' Adds a button to the toolbar
FUNCTION ToolBar_AddButtonW (BYVAL hToolBar AS HWND, BYVAL idxBitmap AS LONG, BYVAL idCommand AS LONG, _
   BYVAL fsState AS UBYTE = 0, BYVAL fsStyle AS UBYTE = 0, BYVAL dwData AS DWORD_PTR = 0, _
   BYVAL pwszText AS WSTRING PTR = NULL) AS LONG
   DIM tb AS TBBUTTON, idxString AS INT_PTR
   IF fsState = 0 THEN fsState = TBSTATE_ENABLED
   IF pwszText <> NULL THEN
      IF LEN(*pwszText) = 0 THEN idxString = -1 ELSE idxString = CAST(INT_PTR, pwszText)
   tb.iBitmap = idxBitmap : tb.idCommand = idCommand : tb.fsState = fsState
   tb.fsStyle = fsStyle : tb.dwData = dwData : tb.iString = idxString
   FUNCTION = SendMessageW(hToolBar, TB_ADDBUTTONSW, 1, CAST(WPARAM, @tb))
' Adds a separator to the toolbar
FUNCTION ToolBar_AddSeparatorW (BYVAL hToolBar AS HWND, BYVAL nWidth AS LONG = 0) AS LONG
   DIM tb AS TBBUTTON
   tb.iBitmap = nWidth : tb.idCommand = 0 : tb.fsState = TBSTATE_ENABLED
   tb.fsStyle = TBSTYLE_SEP : tb.dwData = 0 : tb.iString = -1
   FUNCTION = SendMessageW(hToolBar, TB_ADDBUTTONSW, 1, CAST(LPARAM, @tb))
' Create the toolbar
FUNCTION CreateToolbar (BYVAL pWindow AS CWindow PTR) AS HWND
   ' // Add a tooolbar
   DIM hToolBar AS HWND = pWindow->AddControl("Toolbar", pWindow->hWindow, IDC_TOOLBAR, "", 0, 0, 0, 0, _
      WS_CHILD OR WS_VISIBLE OR TBSTYLE_TOOLTIPS OR TBSTYLE_FLAT OR CCS_NODIVIDER OR CCS_NORESIZE OR CCS_NOPARENTALIGN)
   ' // Allow drop down arrows
   SendMessageW hToolBar, TB_SETEXTENDEDSTYLE, 0, TBSTYLE_EX_DRAWDDARROWS
   ' // Add a bitmap with the button images
   DIM ttbab AS TBADDBITMAP
   ttbab.hInst = HINST_COMMCTRL
   IF AfxIsProcessDPIAware THEN
      ttbab.nId = IDB_STD_LARGE_COLOR
      ttbab.nId = IDB_STD_SMALL_COLOR
   SendMessageW(hToolBar, TB_ADDBITMAP, 0, CAST(LPARAM, @ttbab))
   ' // Add buttons to the toolbar
   Toolbar_AddButtonW hToolBar, STD_CUT, IDM_CUT
   Toolbar_AddButtonW hToolBar, STD_COPY, IDM_COPY
   Toolbar_AddButtonW hToolBar, STD_PASTE, IDM_PASTE
   Toolbar_AddButtonW hToolBar, STD_DELETE, IDM_DELETE
   ToolBar_AddSeparatorW hToolBar
   Toolbar_AddButtonW hToolBar, STD_UNDO, IDM_UNDO
   Toolbar_AddButtonW hToolBar, STD_REDOW, IDM_REDOW
   Toolbar_AddButtonW hToolBar, STD_FILENEW, IDM_FILENEW, 0, BTNS_DROPDOWN
   Toolbar_AddButtonW hToolBar, STD_FILEOPEN, IDM_FILEOPEN
   Toolbar_AddButtonW hToolBar, STD_FILESAVE, IDM_FILESAVE
   Toolbar_AddButtonW hToolBar, STD_PRINTPRE, IDM_PRINTPRE
   Toolbar_AddButtonW hToolBar, STD_FIND, IDM_FIND
   Toolbar_AddButtonW hToolBar, STD_REPLACE, IDM_REPLACE
   Toolbar_AddButtonW hToolBar, STD_PROPERTIES, IDM_PROPERTIES
   Toolbar_AddButtonW hToolBar, STD_PRINT, IDM_PRINT
   Toolbar_AddButtonW hToolBar, STD_HELP, IDM_HELP
   ' // Size the toolbar
   SendMessageW hToolBar, TB_AUTOSIZE, 0, 0
   ' // Return the toolbar handle
   FUNCTION = hToolbar
' Window procedure
   DIM pWindow AS CWindow PTR
   DIM rc AS RECT
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
'            CASE IDM_CUT   ' etc.
'               MessageBoxW hwnd, "You have clicked the Cut button", "Toolbar", MB_OK
'               EXIT FUNCTION
      CASE WM_NOTIFY
         ' Notification messages are handled here.
         ' The TTN_GETDISPINFO message is sent by a ToolTip control
         ' to retrieve information needed to display a ToolTip window.
         DIM ptnmhdr AS NMHDR PTR              ' // Information about a notification message
         DIM ptttdi AS NMTTDISPINFO PTR       ' // Tooltip notification message information
         DIM wszTooltipText AS WSTRING * 260   ' // Tooltip text
         ptnmhdr = CAST(NMHDR PTR, lParam)
         SELECT CASE ptnmhdr->code
            ' // The height of the rebar has changed
            CASE RBN_HEIGHTCHANGE
               ' // Get the coordinates of the client area
               GetClientRect hwnd, @rc
               ' // Send a WM_SIZE message to resize the controls
               SendMessageW hwnd, WM_SIZE, SIZE_RESTORED, MAKELONG(rc.Right - rc.Left, rc.Bottom - rc.Top)
            ' // Toolbar tooltips
            CASE TTN_GETDISPINFO
               ptttdi = CAST(NMTTDISPINFO PTR, lParam)
               ptttdi->hinst = NULL
               wszTooltipText = ""
               SELECT CASE ptttdi->hdr.hwndFrom
                  CASE SendMessageW(GetDlgItem(GetDlgItem(hwnd, IDC_REBAR), IDC_TOOLBAR), TB_GETTOOLTIPS, 0, 0)
                     SELECT CASE ptttdi->hdr.idFrom
                        CASE IDM_CUT        : wszTooltipText = "Cut"
                        CASE IDM_COPY       : wszTooltipText = "Copy"
                        CASE IDM_PASTE      : wszTooltipText = "Paste"
                        CASE IDM_UNDO       : wszTooltipText = "Undo"
                        CASE IDM_REDOW      : wszTooltipText = "Redo"
                        CASE IDM_DELETE     : wszTooltipText = "Delete"
                        CASE IDM_FILENEW    : wszTooltipText = "File New"
                        CASE IDM_FILEOPEN   : wszTooltipText = "File Open"
                        CASE IDM_FILESAVE   : wszTooltipText = "File Save"
                        CASE IDM_PRINTPRE   : wszTooltipText = "Print Preview"
                        CASE IDM_PROPERTIES : wszTooltipText = "Properties"
                        CASE IDM_HELP       : wszTooltipText = "Help"
                        CASE IDM_FIND       : wszTooltipText = "Find"
                        CASE IDM_REPLACE    : wszTooltipText = "Replace"
                        CASE IDM_PRINT      : wszTooltipText = "Print"
                     IF LEN(wszTooltipText) THEN ptttdi->lpszText = @wszTooltipText
         CASE TBN_DROPDOWN
            DIM ptbn AS TBNOTIFY PTR = CAST(TBNOTIFY PTR, lParam)
            SELECT CASE ptbn->iItem
               CASE IDM_FILENEW
                  DIM rc AS RECT
                  SendMessageW(ptbn->hdr.hwndFrom, TB_GETRECT, ptbn->iItem, CAST(LPARAM, @rc))
                  MapWindowPoints(ptbn->hdr.hwndFrom, HWND_DESKTOP, CAsT(LPPOINT, @rc), 2)
                  DIM hPopupMenu AS HMENU = CreatePopUpMenu
                  AppendMenuW hPopupMenu, MF_ENABLED, 10001, "Option 1"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10002, "Option 2"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10003, "Option 3"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10004, "Option 4"
                  AppendMenuW hPopupMenu, MF_ENABLED, 10005, "Option 5"
                  TrackPopupMenu(hPopupMenu, 0, rc.Left, rc.Bottom, 0, hwnd, NULL)
                  DestroyMenu hPopupMenu
      CASE WM_SIZE
            ' // Update the size and position of the Rebar control
            SendMessageW GetDlgItem(hwnd, IDC_REBAR), WM_SIZE, wParam, lParam
            ' // Resize the button
            pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 95, pWindow->ClientHeight - 35, 75, 23, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "CWindow with a rebar", @WndProc)
   ' // Disable background erasing
   pWindow.ClassStyle = CS_DBLCLKS
   ' // Set the client size
   pWindow.SetClientSize(600, 250)
   ' // Center the window
   pWindow.Center
   ' // Add a button
   DIM hButton AS HWND = pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Close")
   ' // Create a rebar control
   DIM hRebar AS HWND = pWindow.AddControl("Rebar", pWindow.hWindow, IDC_REBAR)
   DIM hToolbar AS HWND = CreateToolbar(@pWindow)
   ' // Add the band containing the toolbar control to the rebar
   ' // The size of the REBARBANDINFO is different in Vista/Windows 7
   DIM rc AS RECT, wszText AS WSTRING * 260
   DIM rbbi AS REBARBANDINFO
   IF AfxWindowsVersion >= 600 AND AfxComCtlVersion >= 600 THEN
      rbbi.cbSize  = REBARBANDINFO_V6_SIZE
      rbbi.cbSize  = REBARBANDINFO_V3_SIZE
   ' // Insert the toolbar in the rebar control
   rbbi.fMask      = RBBIM_STYLE OR RBBIM_CHILD OR RBBIM_CHILDSIZE OR _
                     RBBIM_SIZE OR RBBIM_ID OR RBBIM_IDEALSIZE OR RBBIM_TEXT
   rbbi.fStyle     = RBBS_CHILDEDGE
   rbbi.hwndChild  = hToolbar
   rbbi.cxMinChild = 250 * pWindow.rxRatio
   rbbi.cyMinChild = HIWORD(SendMessageW(hToolBar, TB_GETBUTTONSIZE, 0, 0))
   rbbi.cx         = 250 * pWindow.rxRatio
   rbbi.cxIdeal    = 250 * pWindow.rxRatio
   wszText = "Toolbar"
   rbbi.lpText = @wszText
   '// Insert band into rebar
   SendMessageW hRebar, RB_INSERTBAND, -1, CAST(LPARAM, @rbbi)
   ' // Insert a combobox in the rebar control
   DIM hCbBox AS HWND = pWindow.AddControl("ComboBox", pWindow.hWindow, IDC_CBBOX, "", 0, 0, 0, 50 * pWindow.rxRatio)
   GetWindowRect hCbBox, @rc
   rbbi.fStyle     = RBBS_FIXEDSIZE OR RBBS_CHILDEDGE
   rbbi.hwndChild  = hCbBox
   rbbi.cxMinChild = 200 * pWindow.rxRatio
   rbbi.cyMinChild = rc.Bottom - rc.Top
   rbbi.cx         = 200 * pWindow.rxRatio
   rbbi.cxIdeal    = 200 * pWindow.rxRatio
   wszText = "Combobox"
   ' // Process event messages
« Last Edit: April 25, 2016, 07:44:41 PM by Jose Roca »
JosÚ Roca
Re: CWindow RC02 - XpButton control
« Reply #2 on: April 27, 2016, 04:07:03 PM »
I have adapted my XpButton control to FreeBasic using a class. This technique makes it somewhat easier to use the control and will allow me to extend the functionality of CWindow without adding bloat to that class.
JosÚ Roca
Re: CWindow RC02 - XpButton example
« Reply #3 on: April 27, 2016, 04:08:13 PM »
' Microsoft Windows
' File: CW_XpButton.fbtpl
' Contents: CWindow XpButton example
#define unicode
#INCLUDE ONCE "Afx/CXpButton.inc"
USING Afx.CXpButtonClass
CONST IDC_BUTTON1 = 1001
CONST IDC_BUTTON2 = 1002
CONST IDC_BUTTON3 = 1003
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   pWindow.Create(NULL, "XpButton example", @WndProc)
   pWindow.SetClientSize(215, 142)
   pWindow.Center
   DIM pXpButton1 AS CXpButton = CXpButton(@pWindow, IDC_BUTTON1, "&Ok", 50, 20, 114, 26)
   pXpButton1.SetIconFromFile ExePath & "\16_OK.ICO", XPBI_NORMAL
   pXpButton1.SetIconFromFile ExePath & "\16_OKHOT.ICO", XPBI_HOT
   pXpButton1.SetToggle CTRUE
   pXpButton1.SetCursor LoadCursor(NULL, IDC_CROSS)
   pXpButton1.SetImageMargin 10
   DIM pXpButton2 AS CXpButton = CXpButton(@pWindow, IDC_BUTTON2, "&Cancel", 50, 55, 114, 26)
   pXpButton2.SetIconFromFile ExePath & "\16_CANCEL.ICO", XPBI_NORMAL
   pXpButton2.SetIconFromFile ExePath & "\16_CANCELDISABLED.ICO", XPBI_DISABLED
   pXpButton2.SetImagePos XPBI_RIGHT OR XPBI_VCENTER
   pXpButton2.SetTextFormat DT_RIGHT OR DT_VCENTER OR DT_SINGLELINE
   EnableWindow pXpButton2.hWindow, FALSE   ' Disable the button
   DIM pXpButton3 AS CXpButton = CXpButton(@pWindow, IDC_BUTTON3, "&Classic Button", 50, 90, 114, 26)
   SetFocus pXpButton1.hWindow
