Pages: 1 [2]
Author Topic: CWindow RC03  (Read 5729 times)
Re: CWindow RC03
« Reply #15 on: May 01, 2016, 09:17:43 AM »
Don't know. I have used dim because of this thread: How to Create Dim Background Images? ( http://forum.powerbasic.com/forum/user-to-user-discussions/powerbasic-for-windows/54850-how-to-create-dim-background-images?t=53493 ), from which I have taken the idea. Just wanted to know if dimPercent = Percent of dimming (1-99) makes sense to English speaking people or not.
Re: CWindow RC03
« Reply #16 on: May 01, 2016, 09:20:38 AM »
And this is the function to load .png icons from resources.
' Loads an image from a resource, converts it to an icon using GDI+ and returns the icon handle.
' Parameter:
' - hInstance = [in] A handle to the module whose portable executable file or an accompanying
'               MUI file contains the resource. If this parameter is NULL, the function searches
'               the module used to create the current process.
' - wszImage  = [in] Name of the image in the resource file (.RES). If the image resource uses
'               an integral identifier, wszImage should begin with a number symbol (#)
'               followed by the identifier in an ASCII format, e.g., "#998". Otherwise,
'               use the text identifier name for the image. Only images embedded as raw data
'               (type RCDATA) are valid. These must be icons in format .png, .jpg, .gif, .tiff.
' Return Value:
'   If the function succeeds, the return value is the handle of the created icon.
'   If the function fails, the return value is NULL.
FUNCTION AfxGdipIconFromRes (BYVAL hInstance AS HINSTANCE, BYREF wszImage AS WSTRING) AS HICON
   DIM hStatus AS GpStatus, token AS ULONG_PTR
   DIM hRes AS HRSRC, wID AS WORD, dwID AS DWORD, imageSize AS DWORD
   DIM pImage AS GpImage PTR, hIcon AS HICON
   DIM pResData AS HRSRC
   DIM pImageStream AS IStream PTR, hGlobal AS HGLOBAL, pGlobalBuffer AS LPVOID
   ' // Initialize Gdiplus
   token = AfxGdipInit
   IF token = NULL THEN EXIT FUNCTION
   ' // Find the resource
   IF LEFT(wszImage, 1) = "#" THEN
      wID = VAL(MID(wszImage, 2))
      dwID = MAKELONG(wID, 0)
      hRes = FindResourceW(hInstance, MAKEINTRESOURCEW(dwID), CAST(LPCWSTR, RT_RCDATA))
      hRes = FindResourceW(hInstance, wszImage, CAST(LPCWSTR, RT_RCDATA))
   IF hRes THEN
      ' // Retrieve the size of the image
      imageSize = SizeofResource(hInstance, hRes)
      IF imageSize THEN
         ' // Load the resource and get a pointer to the resource data.
         ' // Note: LockResource does not actually lock memory; it is just used
         ' // to obtain a pointer to the memory containing the resource data.
         pResData = LockResource(LoadResource(hInstance, hRes))
         IF pResData THEN
            ' // Allocate memory to hold the image
            hGlobal = GlobalAlloc(GMEM_MOVEABLE, imageSize)
            IF hGlobal THEN
               ' // Lock the memory
               pGlobalBuffer = GlobalLock(hGlobal)
               IF pGlobalBuffer THEN
                  ' // Copy the image from the binary string file to global memory
                  CopyMemory(pGlobalBuffer, pResData, imageSize)
                  ' // Create an stream in global memory
                  IF CreateStreamOnHGlobal(hGlobal, FALSE, @pImageStream) = S_OK THEN
                     IF pImageStream THEN
                        ' // Create a bitmap from the data contained in the stream
                        hStatus = GdipCreateBitmapFromStream(pImageStream, @pImage)
                        ' // Crete icon from image
                        hStatus = GdipCreateHICONFromBitmap(CAST(GpBitmap PTR, pImage), @hIcon)
                        ' // Free the image
                        IF pImage THEN GdipDisposeImage pImage
                        pImageStream->lpVtbl->Release(pImageStream)
                  ' // Unlock the memory
                  GlobalUnlock pGlobalBuffer
               ' // Free the memory
               GlobalFree hGlobal
   ' // Shut down Gdiplus
   GdiplusShutdown token
   ' // Return the handle of the icon
   FUNCTION = hIcon
In the resource file, we need to use the RCDATA statement, e.g.
// Manifest
1 24 "WThemes.xml"
// Toolbar icons
// Toolbar, normal
IDI_ARROW_LEFT_48       RCDATA "arrow_left_48.png"
IDI_ARROW_RIGHT_48      RCDATA "arrow_right_48.png"
IDI_HOME_48             RCDATA "home_48.png"
IDI_SAVE_48             RCDATA "save_48.png"
// Toolbar, disabled
IDI_ARROW_LEFT_48_D     RCDATA "arrow_left_48_d.png"
IDI_ARROW_RIGHT_48_D    RCDATA "arrow_right_48_d.png"
IDI_HOME_48_D           RCDATA "home_48_d.png"
IDI_SAVE_48_D           RCDATA "save_48_d.png"
Re: CWindow RC03
« Reply #17 on: May 01, 2016, 09:21:58 AM »
Usage example:
   ' // Add a tooolbar
   DIM hToolBar AS HWND = pWindow.AddControl("Toolbar", pWindow.hWindow, IDC_TOOLBAR)
   ' // MOdule instance handle
   DIM hInst AS HINSTANCE = GetModuleHandle(NULL)
   ' // Create an image list for the toolbar
   DIM hImageList AS HIMAGELIST
   hImageList = ImageList_Create(48, 48, ILC_COLOR32 OR ILC_MASK, 4, 0)
   IF hImageList THEN
      ImageList_ReplaceIcon(hImageList, -1, AfxGdipIconFromRes(hInst, "IDI_ARROW_LEFT_48"))
      ImageList_ReplaceIcon(hImageList, -1, AfxGdipIconFromRes(hInst, "IDI_ARROW_RIGHT_48"))
      ImageList_ReplaceIcon(hImageList, -1, AfxGdipIconFromRes(hInst, "IDI_HOME_48"))
      ImageList_ReplaceIcon(hImageList, -1, AfxGdipIconFromRes(hInst, "IDI_SAVE_48"))
   SendMessageW hToolBar, TB_SETIMAGELIST, 0, CAST(LPARAM, hImageList)
   ' // Add buttons to the toolbar
   AfxToolbarAddButtonW hToolBar, 0, IDM_LEFTARROW
   AfxToolbarAddButtonW hToolBar, 1, IDM_RIGHTARROW
   AfxToolbarAddButtonW hToolBar, 2, IDM_HOME
   AfxToolbarAddButtonW hToolBar, 3, IDM_SAVEFILE
   ' // Size the toolbar
   SendMessageW hToolBar, TB_AUTOSIZE, 0, 0
« Last Edit: May 01, 2016, 09:38:41 AM by Jose Roca »
Re: CWindow RC03
« Reply #18 on: May 01, 2016, 10:27:04 AM »
I have modified all the functions to create an icon or a bitmap. It defaults to icon, but there are two optional parameters imageType (IMAGE_ICON or IMAGE_BITMAP) and clrBackground )the background color of the bitmap). The names of the functions now begin with AfxImage instead of AfxIcon.
This is the new include file so far:
' Microsoft Windows
' File: AfxGdiplus.bas
' Content: Gdi Plus wrapper functions
' Compiler: Free Basic
' Freeware. Use at your own risk.
' Copyright (c) 2016 Jose Roca. All Rights Reserved.
#pragma once
#ifdef __FB_64BIT__
    #inclib "gdiplus"
    #include "win/gdiplus-c.bi"
#else
    #include once "win/gdiplus.bi"
    using gdiplus
#endif
NAMESPACE Afx.Gdiplus
UNION GDIP_BGRA
   color AS DWORD
   TYPE
      blue  AS UBYTE
      green AS UBYTE
      red   AS UBYTE
      alpha AS UBYTE
   END TYPE
END UNION
' Returns an ARGB color value initialized with the specified values for the alpha, red,
' green, and blue components.
FUNCTION GDIP_ARGB (BYVAL a AS UBYTE, BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE) AS DWORD
   DIM clr AS GDIP_BGRA
   clr.alpha = a : clr.red   = r : clr.green = g : clr.blue  = b
   FUNCTION  = clr.color
' Returns an XRGB color value initialized with the specified values for the red, green,
' and blue components.
FUNCTION GDIP_XRGB (BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE) AS DWORD
   FUNCTION = GDIP_ARGB(&HFF, r, g, b)
' Returns a BGRA color value initialized with the specified values for the  blue, green,
' red and alpha components.
FUNCTION GDIP_BGRA (BYVAL b AS UBYTE, BYVAL g AS UBYTE, BYVAL r AS UBYTE, BYVAL a AS UBYTE) AS DWORD
   clr.blue  = b : clr.green = g : clr.red   = r : clr.alpha = a
' Returns an RGBA color value initialized with the specified values for the red, green,
' blue and alpha components.
FUNCTION GDIP_RGBA (BYVAL r AS UBYTE, BYVAL g AS UBYTE, BYVAL b AS UBYTE, BYVAL a AS UBYTE) AS DWORD
   FUNCTION = GDIP_ARGB(a, r, g, b)
' Returns the version of Gdiplus.dll, e.g. 601 for version 6.01.
FUNCTION AfxGdipDllVersion () AS LONG
   DIM pvsffi AS VS_FIXEDFILEINFO PTR
   DIM pVerInfo AS HANDLE, dwHandle AS DWORD, dwVersion AS DWORD
   DIM cbLen AS DWORD, wMajor AS WORD, wMinor AS WORD
   cbLen = GetFileVersionInfoSizeW("GDIPLUS.DLL", @dwHandle)
   IF cbLen = 0 THEN RETURN NULL
   pVerInfo = HeapAlloc(GetProcessHeap, HEAP_ZERO_MEMORY, cbLen)
   IF pVerInfo = NULL THEN RETURN NULL
   IF GetFileVersionInfoW("GDIPLUS.DLL", dwHandle, cbLen, pVerInfo) THEN
      IF VerQueryValueW(pVerInfo, "\", @pvsffi, @cbLen) THEN
         wMajor = HIWORD(pvsffi->dwFileVersionMS)
         wMinor = LOWORD(pvsffi->dwFileVersionMS)
   HeapFree GetProcessHeap, 0, pVerInfo
   FUNCTION = (wMajor + wMinor / 100) * 100
' Initilizes GDI+
' Returns a token. Pass the token to GdiplusShutdown when you have finished using GDI+.
FUNCTION AfxGdipInit (BYVAL version AS UINT32 = 1) AS ULONG_PTR
   DIM hStatus AS GpStatus, token AS ULONG_PTR, StartupInput AS GdiplusStartupInput
   StartupInput.GdiplusVersion = version
   hStatus = GdiplusStartup(@token, @StartupInput, NULL)
   FUNCTION = token
' Loads an image from a file using GDI+, converts it to an icon or bitmap and returns the handle.
' Parameters:
' - wszFileName   = [in] Path of the image to load and convert.
' - dimPercent    = Percent of dimming (1-99)
' - bGrayScale    = TRUE or FALSE. Convert to gray scale.
' - imageType     = IMAGE_ICON or IMAGE_BITMAP.
' - clrBackground = [in] The background color. This parameter is ignored if the image type
'                   is IMAGE_ICON or the bitmap is totally opaque.
' Return Value:
'   If the function succeeds, the return value is the handle of the created icon or bitmap.
FUNCTION AfxGdipImageFromFileEx (BYREF wszFileName AS WSTRING, _
   BYVAL dimPercent AS LONG = 0, BYVAL bGrayScale AS LONG = FALSE, _
   BYVAL imageType AS LONG = IMAGE_ICON, BYVAL clrBackground AS ARGB = 0) AS HANDLE
   DIM token AS ULONG_PTR, pImage AS GpImage PTR, hImage AS HANDLE
   DIM ImageWidth AS LONG, ImageHeight AS LONG, x AS LONG, y AS LONG
   DIM pixColor AS GDIP_BGRA, iColor AS LONG, rFactor AS SINGLE
   token = AfxGdipInit
   ' // Load the image from file
   GdipLoadImageFromFile(wszFileName, @pImage)
   IF pImage = NULL THEN EXIT FUNCTION
   ' // Get the image width and height
   GdipGetImageWidth(pImage, @ImageWidth)
   GdipGetImageHeight(pImage, @ImageHeight)
   ' // Dim or/and gray the image
   IF dimPercent > 0 AND dimPercent < 100 THEN rFactor = dimPercent / 100
   IF rFactor <> 0 OR bGrayScale <> 0 THEN
      FOR y = 0 TO ImageWidth - 1
         FOR x = 0 TO ImageHeight - 1
            ' // Get the pixel color
            GdipBitmapGetPixel(CAST(GpBitmap PTR, pImage), x, y, @pixColor.color)
            IF dimPercent > 0 THEN
               pixColor.red   = (255 - pixColor.red) * rFactor + pixColor.red
               pixColor.green = (255 - pixColor.green) * rFactor + pixColor.green
               pixColor.blue  = (255 - pixColor.blue) * rFactor + pixColor.blue
            IF bGrayScale THEN
               ' Note: The sum of the percentages for the three colors should add tp up 1
               iColor = 0.299 * pixColor.red + 0.587 * pixColor.green + 0.114 * pixColor.blue
               pixColor.Color = GDIP_BGRA (iColor, iColor, iColor, pixColor.alpha)
               pixColor.color = GDIP_ARGB(pixColor.alpha, pixColor.red, pixColor.green, pixColor.Blue)
            ' // Set the modified pixel color
            GdipBitmapSetPixel(CAST(GpBitmap PTR, pImage), x, y, pixColor.color)
   IF imageType = IMAGE_ICON THEN
      GdipCreateHICONFromBitmap(CAST(GpBitmap PTR, pImage), @hImage)
      GdipCreateHBITMAPFromBitmap(CAST(GpBitmap PTR, pImage), @hImage, clrBackground)
   ' // Free the image
   FUNCTION = hImage
' Converts an image stored in a buffer into an icon or bitmap and returns the handle.
' Parameters:
' - pBuffer       = [in] Pointer to the buffer
' - bufferSize    = Size of the buffer
' Return Value:
' Usage example:
'   DIM wszFileName AS WSTRING * MAX_PATH
'   wszFileName = ExePath & "\arrow_left_256.png"
'   DIM bufferSize AS SIZE_T_
'   DIM nFile AS LONG
'   nFile = FREEFILE
'   OPEN wszFileName FOR BINARY AS nFile
'   IF ERR THEN EXIT FUNCTION
'   bufferSize = LOF(nFile)
'   DIM pBuffer AS UBYTE PTR
'   pBuffer = CAllocate(1, bufferSize)
'   GET #nFile, , *pBuffer, bufferSize
'   CLOSE nFile
'   IF pBuffer THEN
'      ImageList_ReplaceIcon(hImageList, -1, AfxGdipImageFromBuffer(pBuffer, ImageSize))
'      DeAllocate(pBuffer)
'   END IF
FUNCTION AfxGdipImageFromBuffer (BYVAL pBuffer AS ANY PTR, BYVAL bufferSize AS SIZE_T_, _
   token = AfxGdipInit
   hGlobal = GlobalAlloc(GMEM_MOVEABLE, bufferSize)
   IF hGlobal THEN
         CopyMemory(pGlobalBuffer, pBuffer, bufferSize)
               GdipCreateBitmapFromStream(pImageStream, CAST(GpBitmap PTR PTR, @pImage))
               ' // Free the image
      GlobalFree hGlobal
   FUNCTION = hImage
' Loads an image from a file, converts it to an icon or bitmap and returns the handle.
' Parameters:
' Return Value:
FUNCTION AfxGdipImageFromFile (BYREF wszFileName AS WSTRING, _
   BYVAL imageType AS LONG = IMAGE_ICON, BYVAL clrBackground AS ARGB = 0) AS HICON
   DIM fd AS WIN32_FIND_DATAW
   DIM hFind AS HANDLE
   ' // Check for the existence of the file
   IF LEN(wszFileName) = 0 THEN EXIT FUNCTION
   hFind = FindFirstFileW(@wszFileName, @fd)
   IF hFind = INVALID_HANDLE_VALUE THEN EXIT FUNCTION
   FindClose hFind
   ' // Make sure that is not a directory or a temporary file
   IF (fd.dwFileAttributes AND FILE_ATTRIBUTE_DIRECTORY) = FILE_ATTRIBUTE_DIRECTORY OR _
      (fd.dwFileAttributes AND FILE_ATTRIBUTE_TEMPORARY) = FILE_ATTRIBUTE_TEMPORARY THEN
   ' // Open the file and store its contents into a buffer
   DIM nFile AS LONG, bufferSize AS SIZE_T_
   nFile = FREEFILE
   CLOSE nFile
   IF pBuffer THEN
      FUNCTION = AfxGdipImageFromBuffer(pBuffer, bufferSize, imageType, clrBackground)
      DeAllocate(pBuffer)
' Loads an image from a resource, converts it to an icon or bitmap and returns the handle.
' Parameter:
' Return Value:
FUNCTION AfxGdipImageFromRes (BYVAL hInstance AS HINSTANCE, BYREF wszImage AS WSTRING, _
   DIM hRes AS HRSRC, pResData AS HRSRC, wID AS WORD, dwID AS DWORD, imageSize AS DWORD
   token = AfxGdipInit
   IF hRes THEN
      IF imageSize THEN
         IF pResData THEN
            IF hGlobal THEN
                        ' // Free the image
               GlobalFree hGlobal
   FUNCTION = hImage
END NAMESPACE
« Last Edit: May 01, 2016, 11:06:39 AM by Jose Roca »
Re: CWindow RC03
« Reply #19 on: May 03, 2016, 12:19:44 PM »
Hi Jose, can you post an attachment with the "WThemes.xml" file and the png's that you are using?
Re: CWindow RC03
« Reply #20 on: May 03, 2016, 01:51:18 PM »
This attachment includes the testing code that I have used for toolbars. Requires version RC05.
Pages: 1 [2]
