CWindow RC06
Started by José Roca, May 08, 2016, 02:51:23 AM
We can do string concatenation without memory leaks using
DIM bs3 AS CBStr = **bs1 & " " & **bs2
A little weird syntax, but...
No wonder the CComBstr class of Microsoft Fundation Classes does not have string concatenation.
Only the compiler can deal with the intermediate temporary strings.
#46
I have added the operator @. It allows to pass the address of the BSTR pointer (m_bstr) to a function (OUT parameter). As the address is manipulated directly, we must first set it to empty if it has contents to avoid memory leaks. To set it to empty, just assign an empty string to it, i.e. bs = "".
' Returns the address of the BSTR
OPERATOR CBStr.@ () AS AFX_BSTR PTR
   OPERATOR = @m_bstr
END OPERATOR
Usage example:
SUB Foo (BYVAL b AS AFX_BSTR PTR)
   *b = SysAllocString("xxxxx")
DIM bs AS CBStr
Foo @bs
print **bs
Well, I think that now the class is fully usable. We still need to use double indirection to print the contents of the BSTR (**bs) because the current version of the compiler does not support the * operator as a member of the class. It is in the TODO list.
#47
We can declare "A" and "W" functions as follows:
' Returns the path of the program that is currently executing.
' Contrarily to the Free Basic ExePath function, it includes a trailing "\".
PRIVATE FUNCTION AfxGetExePathA () AS STRING
   DIM buffer AS STRING * MAX_PATH + 1
   GetModuleFileNameA NULL, STRPTR(buffer), LEN(buffer)
   DIM p AS LONG = INSTRREV(buffer, ANY ":/\")
   FUNCTION = LEFT(buffer, p)
PRIVATE FUNCTION AfxGetExePathW () AS AFX_BSTR
   DIM buffer AS WSTRING * MAX_PATH
   GetModuleFileNameW NULL, @buffer, SIZEOF(buffer)
   DIM bs AS AFX_BSTR = SysAllocString(LEFT(buffer, p))
   FUNCTION = bs
#ifndef UNICODE
   #define AfxGetExePath AfxGetExePathA
#else
   #define AfxGetExePath AfxGetExePathW
#endif
Usage of the "W" version:
DIM bs AS CBStr = AfxGetExePathW
print **bs
Usage example without assigning the returned handle to an instance of the class.
DIM b AS AFX_BSTR = AfxGetExePathW
print *b
SysFreeString b
Quote from: Petrus Vorster on May 10, 2016, 01:51:43 PM
Will you consider adding some of these controls soon to the Firefly for FB interface, because I really suck at placing controls manually.
Some of the stuff you posted here really is starting to make Freebasic look like a good move, but many of us would love just to click and place.
PLEASE...
I think what I will do as an interim step will be to create a small utility that will read a FireFly frm file and create the necessary cWindow code. Allow that code to be copied to the clipboard so that you can paste it into your editor. This will allow us to use FireFly to visually create a form while still be able to have access to the underlying cWindow code that could be used to create that form.
EDIT: Added - this utility is just about complete. Just need to do some testing and then I will post it.
EDIT: Added - utility is now available at: http://www.planetsquires.com/protect/forum/index.php?topic=3834.msg28038
aloberr
josé
for CBSTR ,I have to add a constructor, operator let and cast for the BSTR
your method is not badly, but there is simpler with my method
to see widestring.bi and its test
#pragma once
#include once "win/ole2.bi"
#Include once "win/shlwapi.bi"
#ifndef AFX_BSTR
   #define AFX_BSTR WSTRING PTR
#endif
NAMESPACE Afx.CBStrClass
' CBStr - OLE strings class
TYPE CBStr
   Private:
      m_bstr AS AFX_BSTR
   Public:
      DECLARE CONSTRUCTOR (BYREF wszStr AS CONST WSTRING = "")
      DECLARE CONSTRUCTOR (BYREF szStr AS STRING = "")
      DECLARE CONSTRUCTOR (BYREF pCBStr AS CBStr)
      DECLARE CONSTRUCTOR (BYREF bstrHandle AS AFX_BSTR = NULL)
      DECLARE CONSTRUCTOR (BYVAL pCBStr AS BSTR)
      DECLARE DESTRUCTOR
      DECLARE OPERATOR Let (BYREF szStr AS STRING)
      DECLARE OPERATOR Let (BYREF wszStr AS CONST WSTRING)
      DECLARE OPERATOR Let (BYREF pCBStr AS CBStr)
      DECLARE OPERATOR Let (BYREF bstrHandle AS AFX_BSTR)
      DECLARE OPERATOR Let (BYVAL pBStr AS BSTR)
      DECLARE OPERATOR += (BYREF wszStr AS CONST WSTRING)
      DECLARE OPERATOR += (BYREF pCBStr AS CBStr)
      DECLARE OPERATOR &= (BYREF wszStr AS CONST WSTRING)
      DECLARE OPERATOR &= (BYREF pCBStr AS CBStr)
      DECLARE PROPERTY Handle () AS AFX_BSTR
      DECLARE SUB Append (BYREF wszStr AS CONST WSTRING)
      DECLARE FUNCTION Concat (BYREF wszStr2 AS CONST WSTRING, BYREF wszStr2 AS CONST WSTRING) AS AFX_BSTR
      DECLARE OPERATOR cast() AS String
      DECLARE OPERATOR cast() AS BSTR
END TYPE
' CBStr class constructor
CONSTRUCTOR CBStr (BYREF wszStr AS CONST WSTRING = "")
   m_bstr = SysAllocString(wszStr)
END CONSTRUCTOR
CONSTRUCTOR CBStr (BYREF szStr AS STRING = "")
   m_bstr = SysAllocString(WSTR(szStr))
END CONSTRUCTOR
CONSTRUCTOR CBStr (BYREF pCBStr AS CBStr)
   m_bstr = SysAllocString(*pCBStr.Handle)
END CONSTRUCTOR
CONSTRUCTOR CBStr (BYREF bstrHandle AS AFX_BSTR = NULL)
   IF bstrHandle = NULL THEN
      m_bstr = SysAllocString("")
      ' Detect if the passed handle is an OLE string
      ' If it is an OLE string it must have a descriptor; otherwise, don't
      ' Get the length looking at the descriptor
      DIM res AS INTEGER = PEEK(DWORD, CAST(ANY PTR, bstrHandle) - 4) \ 2
      ' If the retrieved length if the same that the returned by LEN, then it must be an OLE string
      IF res = .LEN(*bstrHandle) THEN
         ' Free the current OLE string and attach the passed handle to the class
         m_bstr = bstrHandle
         ' Allocate an OLE string with the contents of the string pointer by bstrHandle
         m_bstr = SysAllocString(*bstrHandle)
END CONSTRUCTOR
CONSTRUCTOR CBStr(BYVAL pCBStr AS BSTR)
    m_bstr =Cast(WString Ptr,pCBStr)
End Constructor
' CBStr class destructor
DESTRUCTOR CBStr
   IF m_bstr THEN SysFreeString m_bstr
END DESTRUCTOR
' Assigns new text to the BSTR
' Note: We can also pass a FB ansi string (the conversion to Unicode is automatic)
OPERATOR CBStr.Let (BYREF wszStr AS CONST WSTRING)
   IF m_bstr THEN SysFreeString(m_bstr)
END OPERATOR
OPERATOR CBStr.Let (BYREF szStr AS STRING)
END OPERATOR
OPERATOR CBStr.Let (BYREF pCBStr AS CBStr)
END OPERATOR
OPERATOR CBStr.Let (BYREF bstrHandle AS AFX_BSTR)
   IF bstrHandle = NULL THEN EXIT OPERATOR
      ' Attach the passed handle to the class
      m_bstr = bstrHandle
END OPERATOR
OPERATOR CBStr.Let (BYVAL szStr AS BSTR)
   m_bstr = Cast(WString Ptr,szStr)
END Operator
  OPERATOR CBStr.cast() AS String
    Return *m_bstr
  End Operator
  OPERATOR CBStr.cast() AS BSTR
    Return  Cast(BSTR,m_bstr)
  End Operator
' Returns the handle of the BSTR
PROPERTY CBStr.Handle () AS AFX_BSTR
   PROPERTY = m_bstr
END PROPERTY
' Appends a string to the BSTR. The string can be a literal or a FB STRING or WSTRING variable.
' To append another BSTR:
' DIM bs1 AS CBStr = "1st string"
' DIM bs2 AS CBStr = "2nd string"
' bs1.Append *bs2.Handle
' -or-
' bs1.Append **bs2
SUB CBStr.Append (BYREF wszStr AS CONST WSTRING)
   DIM n1 AS UINT = SysStringLen(m_bstr)
   DIM nLen AS UINT = .LEN(wszStr)
   IF nLen = 0 THEN EXIT SUB
   DIM b AS AFX_BSTR = SysAllocStringLen(NULL, n1+nLen)
   IF b = NULL THEN EXIT SUB
   memcpy(b, m_bstr, n1 * SIZEOF(WSTRING))
   memcpy(b+n1, @wszStr, nLen * SIZEOF(WSTRING))
   m_bstr = b
OPERATOR CBStr.+= (BYREF wszStr AS CONST WSTRING)
   this.Append(wszStr)
END OPERATOR
' Appends a BSTR to the BSTR.
OPERATOR CBStr.+= (BYREF pCBStr AS CBStr)
   this.Append(*pCBStr.Handle)
END OPERATOR
OPERATOR CBStr.&= (BYREF wszStr AS CONST WSTRING)
   this.Append(wszStr)
END OPERATOR
OPERATOR CBStr.&= (BYREF pCBStr AS CBStr)
END OPERATOR
' Returns vbTrue (-1) if the two BSTRings are equal; FALSE, otherwise.
OPERATOR = (BYREF pCBStr1 AS CBStr, BYREF pCBStr2 AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr1.Handle, *pCBStr2.Handle) = 0
END OPERATOR
OPERATOR = (BYREF pCBStr AS CBStr, BYREF wszStr AS CONST WSTRING) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr.Handle, wszStr) = 0
END OPERATOR
OPERATOR = (BYREF wszStr AS CONST WSTRING, BYREF pCBStr AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(wszStr, *pCBStr.Handle) = 0
END OPERATOR
' Returns vbTrue (-1) if the two BSTRings are not equal; FALSE, otherwise.
OPERATOR <> (BYREF pCBStr1 AS CBStr, BYREF pCBStr2 AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr1.Handle, *pCBStr2.Handle) <> 0
END OPERATOR
OPERATOR <> (BYREF pCBStr AS CBStr, BYREF wszStr AS CONST WSTRING) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr.Handle, wszStr) <> 0
END OPERATOR
OPERATOR <> (BYREF wszStr AS CONST WSTRING, BYREF pCBStr AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(wszStr, *pCBStr.Handle) <> 0
END OPERATOR
' Returns vbTrue (-1) if the the first BSTR is greater than the 2nd BSTR; FALSE, otherwise.
OPERATOR > (BYREF pCBStr1 AS CBStr, BYREF pCBStr2 AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr1.Handle, *pCBStr2.Handle) > 0
END OPERATOR
OPERATOR > (BYREF pCBStr AS CBStr, BYREF wszStr AS CONST WSTRING) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr.Handle, wszStr) > 0
END OPERATOR
OPERATOR > (BYREF wszStr AS CONST WSTRING, BYREF pCBStr AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(wszStr, *pCBStr.Handle) > 0
END OPERATOR
' Returns vbTrue (-1) if the the first BSTR is less than the 2nd BSTR; FALSE, otherwise.
OPERATOR < (BYREF pCBStr1 AS CBStr, BYREF pCBStr2 AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr1.Handle, *pCBStr2.Handle) < 0
END OPERATOR
OPERATOR < (BYREF pCBStr AS CBStr, BYREF wszStr AS CONST WSTRING) AS INTEGER
   OPERATOR = StrCmpW(*pCBStr.Handle, wszStr) < 0
END OPERATOR
OPERATOR < (BYREF wszStr AS CONST WSTRING, BYREF pCBStr AS CBStr) AS INTEGER
   OPERATOR = StrCmpW(wszStr, *pCBStr.Handle) < 0
END OPERATOR
' Returns vbTrue (-1) if the the first BSTR is greater or equal than the 2nd BSTR; FALSE, otherwise.
OPERATOR >= (BYREF pCBStr1 AS CBStr, BYREF pCBStr2 AS CBStr) AS INTEGER
   DIM nResult AS LONG
   nResult = StrCmpW(*pCBStr1.Handle, *pCBStr2.Handle)
   IF nResult > 0 OR nResult = 0 THEN OPERATOR = -1 ELSE OPERATOR = 0
END OPERATOR
OPERATOR >= (BYREF pCBStr AS CBStr, BYREF wszStr AS CONST WSTRING) AS INTEGER
   DIM nResult AS LONG
   nResult = StrCmpW(*pCBStr.Handle, wszStr)
END OPERATOR
OPERATOR >= (BYREF wszStr AS CONST WSTRING, BYREF pCBStr AS CBStr) AS INTEGER
   DIM nResult AS LONG
   nResult = StrCmpW(wszStr, *pCBStr.Handle)
aloberr
test.bas
#Include Once "cbstr.bi"
Using  Afx.CBStrClass
Dim cs As CBStr=CBStr("Une string dans Com String")
Dim cs2 As CBStr
Dim bs As BSTR =cs
Print cs
Print *Cast(WString Ptr,bs)
Print
cs2=cs
Print  cs2
Print
Print
Dim wz As WString*45="Une BSTR dans CCOMBSTR"
cs2=sysallocstring(@wz)
Print  cs2
DIM b1 AS CBStr = "1st string"
DIM b2 AS CBStr = " 2nd string"
b1.Append *b2.Handle
'-or-
'b1.Append **b2
Print **b1
DIM bss AS CBStr = "Test string"
PRINT **bss '(notice the double indirection)
DIM bs1 AS CBStr = "Test string 1"
DIM wsz AS WSTRING * 250 = " - concatenated string"
DIM bs2 AS CBStr
bs2 = bs1 & wsz
Print **bs2
Sleep
aloberr
widestring.bi
#Include Once "windows.bi"
#Include Once "win/ole2.bi"
type WideString
Private:
    Public:
      m_bstr As BSTR
      m_str  As ZString Ptr
  Public:
   Declare Constructor()
   Declare Constructor(mbstr As BSTR )
   Declare Constructor(mstr As String )
   Declare Constructor(byref mwstr As WideString )
   Declare Operator Let(mbstr As BSTR )
   Declare Operator Let(mstr As String )
   Declare Operator Let(ByRef mstr As WideString )
   Declare Operator +=(byref s  as  WideString )
Declare Operator &=(byref s  as  WideString )
   Declare Operator +=(byref s  as  String )
Declare Operator &=(byref s  as  String )
   Declare Operator +=(byref s  as  BSTR )
Declare Operator &=(byref s  as  BSTR )
   Declare Operator Cast() As BSTR
   Declare Operator Cast() As String
   Declare Operator Cast() As BSTR Ptr
   Declare Operator Cast() As String Ptr
   Declare Destructor()
End Type
Constructor WideString()
   m_str=NULL
   m_bstr=NULL
End Constructor
Constructor WideString(mbstr As BSTR )
    if (0=mbstr) Then
    m_str = NULL
    Else
    Dim s As String=*Cast(WString Ptr,mbstr)
      m_str=New Byte[Len(s)+1]
      *m_str= s
    m_bstr=mbstr
End Constructor
Constructor WideString(mstr As String )
    if Len(mstr)=NULL Then
    m_str = NULL
    m_bstr=NULL
    Else
      m_str=New Byte[Len(mstr)+1]
      *m_str= mstr
      m_bstr=SysAllocString(WStr(mstr))
    End if
End Constructor
Constructor WideString(byref mwstr As WideString )
  'if mwstr.m_str  Then  m_str  = mwstr.m_str       ' erratique  m_str non instancié
  'if mwstr.m_bstr Then  m_bstr = mwstr.m_bstr
  if mwstr.m_str  Then
    this.constructor(*mwstr.m_str)
    Exit Constructor
  Else
  if mwstr.m_bstr Then  this.constructor(mwstr.m_bstr)
  EndIf
End Constructor
Operator WideString.let(mbstr As BSTR )
    if m_str  Then  Delete [] m_str :m_str = NULL
    if m_bstr  Then  sysfreestring(m_bstr) :m_bstr = NULL
    this.constructor(mbstr)
End Operator
Operator WideString.let(mstr As String )
    this.constructor(mstr)
End Operator
Operator WideString.let(byref mwstr As WideString )
    this.constructor(mwstr)
End Operator
Operator WideString.Cast() As BSTR
if m_bstr=NULL  Then
   Return SysAllocString(WStr(*m_str))
Else
   Return m_bstr
End Operator
Operator WideString.Cast() As String
if m_str=NULL  Then
   '*m_str=*Cast(WString Ptr,m_bstr) ' mauvais car m_str non initialisé
   this.constructor(m_bstr)
   Return *m_str
Else
   Return  *m_str
End Operator
Operator WideString.Cast() As BSTR Ptr
if m_bstr=NULL  Then
    m_bstr=SysAllocString(WStr(*m_str))
    Return cptr(BSTR Ptr,m_bstr)
Else
End Operator
Operator WideString.Cast() As String Ptr
if m_str=NULL  Then
     Return  Cast(String Ptr,m_str)
Else
End Operator
  Destructor WideString()
    If m_str Then Delete [] m_str : m_str=NULL
End Destructor
Operator WideString.+=(byref s As  WideString )
'If Len(*m_str) And Len(*s.m_str) Then    ' on ne peut pas ajouter un " " /
     Dim temp As String =*m_str
  temp=temp & *s.m_str
           If m_bstr  Then  sysfreestring(m_bstr) :m_bstr = NULL
           this.constructor(temp)
'Else
'End If
End Operator
Operator WideString.&=(byref s  as  WideString )
'Else
'End If
End Operator
   Operator WideString.+=(byref s  as  String )
    'If m_str<>NULL And Len(s)<>NULL Then
  temp=temp & s
  ' Else
  ' End If
   End Operator
Operator WideString.&=(byref s As  String )
    temp=temp & s
    If m_str  Then  Delete [] m_str :m_str = NULL
     ' Else
   '   End If
End Operator
   Operator WideString.+=(byref s  as  BSTR )
   ' If sysstringLen(m_bstr) Then
         Dim As BSTR mbstr
     VarBstrCat(m_bstr,s,@mbstr)
'  Else
'  End If
   End Operator
  Operator WideString.&=(byref s  as  BSTR )
     Dim As BSTR mbstr
' Else
' End If
  End Operator
Operator + OverLoad ( byref s1 As  ZString Ptr , byref  s2 As  WideString ) As WideString
    Dim As String s =  *s1 + Cast(String,s2)
Operator= (s)
  End Operator
  Operator +( byref  s2 As  WideString, byref s1 As  ZString Ptr  ) As WideString
     Dim s As String= Cast(String,s2) + *s1
  Return s
  End Operator
  Operator +( byref s1 As  BSTR , byref  s2 As  WideString ) As WideString
Dim s As BStr
VarBstrCat(s1,Cast(BSTR,s2),@s)
Operator= s
  End Operator
  Operator +( byref  s2 As  WideString, byref s1 As  BSTR  ) As WideString
Dim s As BStr
VarBstrCat(Cast(BSTR,s2),s1,@s)
Operator= s
  End Operator
  Operator & OverLoad ( byref s1 As  ZString Ptr , byref  s2 As  WideString ) As WideString
Dim As String s =  *s1 & Cast(String,s2)
Return (s)
  End Operator
  Operator &( byref  s2 As  WideString, byref s1 As ZString Ptr  ) As WideString
  Dim s As String= Cast(String,s2) & *s1
  Return (s)
  End Operator
Operator &( byref s1 As  BSTR , byref  s2 As  WideString ) As WideString
Dim s As BStr
Return s
  End Operator
  Operator &( byref  s2 As  WideString, byref s1 As  BSTR  ) As WideString
Dim s As BStr
Return s
  End Operator
Operator Not OverLoad ( ByRef lhs As WideString)  As  boolean
Return (Cast(String,lhs) = "") And (Cast(BSTR,lhs) = NULL)
End Operator
Operator = OverLoad  ( ByRef lhs As WideString, ByRef rhs As  ZString Ptr )  As  boolean
Return (Cast(String,lhs) = *rhs)
End Operator
Operator = OverLoad  (ByRef rhs As  ZString Ptr, ByRef lhs As WideString)  As  boolean
End Operator
Operator <> OverLoad ( ByRef lhs As WideString, ByRef rhs As  ZString Ptr ) As  boolean
  Return (Cast(String,lhs) <> *rhs)
End Operator
Operator <> OverLoad (ByRef rhs As  ZString Ptr , ByRef lhs As WideString) As  boolean
End Operator
Operator = ( ByRef lhs As WideString, ByRef rhs As  BSTR )  As  boolean
Return (Cast(BSTR,lhs) = rhs)
End Operator
Operator = (  ByRef rhs As  BSTR,ByRef lhs As WideString )  As  boolean
End Operator
Operator <> ( ByRef lhs As WideString, ByRef rhs As  BSTR ) As  boolean
Return (Cast(BSTR,lhs) <> rhs)
End Operator
Operator <> (ByRef rhs As  BSTR, ByRef lhs As WideString ) As  boolean
End Operator
testw.bas
#Define UNICODE   ' OR NOT
#Include Once "widestring.bi"
'Using  Afx.CBStrClass
#Define CBStr WideString
Dim cs2 As CBStr
Dim bs As BSTR =cs
Print cs
Print
cs2=cs
Print  cs2
Print
Print
Print  cs2
b1 +=b2
'-or-
'b1.Append **b2
Print b1
PRINT bss '(notice the double indirection)
DIM bs2 AS CBStr
bs2 = bs1 & wsz
Print bs2
Sleep
But with
Print cs
You're printing an ansi string, not an unicode one.
When you use Print cs, it calls this casting operator
if m_str=NULL  Then
   Return *m_str
Else
   Return  *m_str
End Operator
#53
Unicode is not just converting ansi to utf-16 adding a CHR(0) to any character. This will work with languages that use the ANSI Latin 1; Western European (Windows), but not for Russian, for example.
Using this code, where 1251 is the code page for ANSI Cyrillic; Cyrillic (Windows):
#define unicode
#INCLUDE ONCE "windows.bi"
#INCLUDE ONCE "Afx/CBStr.inc"
using Afx.CBStrClass
DIM s AS STRING = CHR(209, 229, 236, 229, 237)
DIM wsz AS WSTRING * 260
MultiByteToWidechar(1251, MB_PRECOMPOSED,STRPTR(s), -1, @wsz, SIZEOF(wsz))
DIM bs AS CBStr = wsz
MessageBoxW 0, **bs, "", MB_OK
print
print "press esc"
sleep
The message box correctly displays семен
Using your class:
#define unicode
#Include Once "Afx/widestring.bi"
DIM bs AS WideString = wsz
MessageBoxW 0, bs, "", MB_OK
print
print "press esc"
sleep
It displays ?????
#54
New version of CbStr.inc. I have removed the leaky concatenation operators and added support to set the code page, as the FreeBasic WSTR function has not a parameter to especify the code page to be used (it should).
We can use:
DIM bs AS CBStr = 1251  ' Sets the Russian code page
bs = CHR(209, 229, 236, 229, 237)
or
DIM bs AS CBStr = CBStr(CHR(209, 229, 236, 229, 237), 1251)
this one uses the Russian code page to do the translation but does not set it permanenty.
You can also use the CodePage property:
dim bs AS CBStr
bs.CodePage = 1251   ' Sets the Russian code page
We may need to set the code page because we can't use an additional parameter to sepecify it when using the Let operator to assign an ansi string.
aloberr
you are right but this is resolved by puting operator cast() byref as wstring
update one
widestring.bi
type WideString
Private:
    Public:
      m_bstr As BSTR
  Public:
   Declare Constructor(mstr As WString Ptr )
   Declare Operator Let(mstr As WString Ptr )
   Declare Operator Cast() ByRef As WString
End Type
   m_str=NULL
   m_bstr=NULL
End Constructor
    if (0=mbstr) Then
    m_str = NULL
    Else
      *m_str= s
    m_bstr=mbstr
End Constructor
    m_str = NULL
    m_bstr=NULL
    Else
      *m_str= mstr
    End if
End Constructor
Constructor WideString(mstr As WString Ptr )
     this.constructor(Cast(BSTR,mstr))
End Constructor
  if mwstr.m_str  Then
    Exit Constructor
  Else
  EndIf
End Constructor
End Operator
End Operator
Operator WideString.Let(mstr As WString Ptr )
this=(Cast(BSTR,mstr))
End Operator
End Operator
if m_bstr=NULL  Then
Else
   Return m_bstr
End Operator
if m_str=NULL  Then
   '*m_str=*Cast(WString Ptr,m_bstr) ' pas bon car m_str non initialisé
   Return *m_str
Else
   Return  *m_str
End Operator
Operator WideString.Cast() ByRef As WString
if m_str=NULL  Then
     Return  peek(WString,m_str)
Else
End Operator
End Destructor
'Else
'End If
End Operator
'Else
'End If
End Operator
  temp=temp & s
  ' Else
  ' End If
   End Operator
    temp=temp & s
     ' Else
   '   End If
End Operator
         Dim As BSTR mbstr
'  Else
'  End If
   End Operator
     Dim As BSTR mbstr
' Else
' End If
  End Operator
Operator= (s)
  End Operator
  Return s
  End Operator
Dim s As BStr
Operator= s
  End Operator
Dim s As BStr
Operator= s
  End Operator
Return (s)
  End Operator
  Return (s)
  End Operator
Dim s As BStr
Return s
  End Operator
Dim s As BStr
Return s
  End Operator
End Operator
End Operator
End Operator
End Operator
End Operator
End Operator
End Operator
End Operator
End Operator
If I use that change, the program GPFs when it ends.
#define unicode
MultiByteToWidechar(1251, MB_PRECOMPOSED, STRPTR(s), -1, @wsz, SIZEOF(wsz))
#57
I have rewritten the AfxUcode/Acode functions:
' Translates ansi bytes to unicode bytes
FUNCTION AfxUcode (BYREF ansiStr AS CONST STRING, BYVAL nCodePage AS LONG = 0) AS BSTR
   DIM pbstr AS BSTR = SysAllocString(WSTR(ansiStr))
   IF nCodePage <> 0 THEN MultiByteToWideChar(nCodePage, MB_PRECOMPOSED, STRPTR(ansiStr), -1, pbstr, LEN(ansiStr) * 2)
   FUNCTION = pbstr
' Translates unicode bytes to ansi bytes
FUNCTION AfxAcode (BYVAL pbstr AS BSTR, BYVAL nCodePage AS LONG = 0) AS STRING
   DIM ansiStr AS STRING = SPACE(SysStringLen(pbstr))
   DIM hr AS LONG = WideCharToMultiByte(nCodePage, 0, pbstr, SysStringLen(pbstr), STRPTR(ansiStr), LEN(ansiStr), NULL, NULL)
   FUNCTION = ansiStr
this allows to use the assignment operator without setting the code page first:
Dim bs AS CBStr
bs = AfxUcode(CHR(209, 229, 236, 229, 237), 1251)
Of course, if WSTR had an optional CodePage parameter, we could do this: bs = WSTR(CHR(209, 229, 236, 229, 237), 1251). In PowerBASIC, that optional CodePage parameter was added by my suggestion.
aloberr
QuoteIf I use that change, the program GPFs when it ends.
curious operator cast() byref as wstring was not the only change
#59
I have copied all the code you have posted in #55. It GPFs after I click "OK" in the message box. Test it by yourself.
