AfxOpenFileDialogW
Started by Paul Squires, June 06, 2016, 03:26:50 PM
And then another for the IFileSaveDialog, with these additional methods:
ApplyProperties
Applies a set of properties to an item using the Shell's copy engine.
GetOptions
Gets the current flags that are set to control dialog behavior.
GetProperties
Retrieves the set of property values for a saved item or an item in the process of being saved.
SetCollectedProperties
Specifies which properties will be collected in the save dialog.
SetOptions
Sets flags to control the behavior of the dialog.
SetProperties
Provides a property store that defines the default values to be used for the item being saved.
SetSaveAsItem
Sets an item to be used as the initial entry in a Save As dialog.
I don't have plans to write FFC (FreeBASIC Foundation Classes).
#16
> I'm afraid my Fb and COM are lacking (and no COM SaveAs example) to attempt this myself.
The save file dialog is very similar to the one for the single selection open file dialog.
' Microsoft Windows
' File: COM_IFileSaveDialog.fbtpl
' Contents: Demonstrates the use of the IFileSaveDialog interface.
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "win/shobjidl.bi"
USING Afx.CWindowClass
CONST IDC_OFD = 1001
' Displays the FileSaveDialog
' The returned pointer must be freed with CoTaskMemFree
FUNCTION AfxIFileSaveDialog (BYVAL hwndOwner AS HWND, BYVAL pwszFileName AS WSTRING PTR, _
BYVAL pwszDefExt AS WSTRING PTR, BYVAL sigdnName AS SIGDN = SIGDN_FILESYSPATH) AS WSTRING PTR
   ' // Create an instance of the IFileSaveDialog interface
   DIM hr AS LONG
   DIM psfd AS IFileSaveDialog PTR
   hr = CoCreateInstance(@CLSID_FileSaveDialog, NULL, CLSCTX_INPROC_SERVER, @IID_IFileSaveDialog, @psfd)
   IF psfd = NULL THEN RETURN NULL
   ' // Set the file types
   DIM rgFileTypes(1 TO 3) AS COMDLG_FILTERSPEC
   rgFileTypes(1).pszName = @WSTR("FB code files")
   rgFileTypes(2).pszName = @WSTR("Text files")
   rgFileTypes(3).pszName = @WSTR("All files")
   rgFileTypes(1).pszSpec = @WSTR("*.bas;*.inc;*.bi")
   rgFileTypes(2).pszSpec = @WSTR("*.txt")
   rgFileTypes(3).pszSpec = @WSTR("*.*")
   psfd->lpVtbl->SetFileTypes(psfd, 3, @rgFileTypes(1))
   ' // Set the title of the dialog
   hr = psfd->lpVtbl->SetTitle(psfd, "File Save Dialog")
   ' // Set the file name
   hr = psfd->lpVtbl->SetFileName(psfd, pwszFileName)
   ' // Set the extension
   hr = psfd->lpVtbl->SetDefaultExtension(psfd, pwszDefExt)
   ' // Display the dialog
   hr = psfd->lpVtbl->Show(psfd, hwndOwner)
   ' // Set the default folder
   DIM pFolder AS IShellItem PTR
   SHCreateItemFromParsingName (CURDIR, NULL, @IID_IShellItem, @pFolder)
   IF pFolder THEN
      psfd->lpVtbl->SetDefaultFolder(psfd, pFolder)
      pFolder->lpVtbl->Release(pFolder)
   ' // Get the result
   DIM pItem AS IShellItem PTR
   DIM pwszName AS WSTRING PTR
   IF SUCCEEDED(hr) THEN
      hr = psfd->lpVtbl->GetResult(psfd, @pItem)
         hr = pItem->lpVtbl->GetDisplayName(pItem, sigdnName, @pwszName)
         FUNCTION = pwszName
   ' // Cleanup
   IF pItem THEN pItem->lpVtbl->Release(pItem)
   IF psfd THEN psfd->lpVtbl->Release(psfd)
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            CASE IDC_OFD
                  ' // Display the Save File Dialog
                  DIM pwszName AS WSTRING PTR = AfxIFileSaveDialog(hwnd, "test", "bas")
                  ' // Display the selected name
                  IF pwszName THEN
                     MessageBoxW(hwnd, *pwszName, "IFileSaveDialog", MB_OK)
                     CoTaskMemFree(pwszName)
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Initialize the COM library
   CoInitialize(NULL)
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "IFileOpenDialog example", @WndProc)
   pWindow.Center
   ' // Add a button
   pWindow.AddControl("Button", , IDC_OFD, "File &Save Dialog", 350, 250, 110, 23)
   ' // Process event messages
   ' // Uninitialize the COM library
   CoUninitialize
The major problem for low-level COM programming with FB is the lack of native support for BSTRs. Without it, any attempt to make it easier to use is futile.
And then the first question posted will be: "Is there an easy way to center the dialog?" :)
