Pages: 1 [2]
Author Topic: WinFBE using CWindow #8  (Read 7927 times)
James Fuller
Re: WinFBE using CWindow #8
« Reply #15 on: June 30, 2016, 08:00:22 PM »
This sounds like a candidate for  a static array of temps.
With BCX;bc9 many library routines return a bcx string -> a c char array.
This is how it is done. Shown is the mid$ function.
You could use a CBstr class or just a bstr??
James
char *mid (const char *S, int start, int length)
    char *strtmp;
    register int tmplen = strlen(S);
    if(start > tmplen || start < 1) return BCX_TmpStr(1, 1, 1);
    if (length < 0 || length > (tmplen - start) + 1)
        length = (tmplen - start) + 1;
    strtmp = BCX_TmpStr(length, 1, 1);
    return (char*)memcpy(strtmp, &S[start - 1], length);
#ifndef BCXTmpStrSize
#define BCXTmpStrSize  2048
#endif
char *BCX_TmpStr (size_t Bites, size_t  iPad, int iAlloc)
    static int   StrCnt;
    static char *StrFunc[BCXTmpStrSize];
    StrCnt = (StrCnt + 1) & (BCXTmpStrSize - 1);
    if(StrFunc[StrCnt]) {
        free (StrFunc[StrCnt]);
        StrFunc[StrCnt] = NULL;
#if defined BCX_MAX_VAR_SIZE
    if(Bites * sizeof(char) > BCX_MAX_VAR_SIZE)
        printf("Buffer Overflow caught in BCX_TmpStr - requested space of %d EXCEEDS %d\n", (int)(Bites * sizeof(char)), BCX_MAX_VAR_SIZE);
        abort();
#endif
    if(iAlloc) StrFunc[StrCnt] = (char*)calloc(Bites + iPad + 1, sizeof(char));
    return StrFunc[StrCnt];
James Fuller
« Reply #16 on: June 30, 2016, 08:50:57 PM »
On further investigation I see the variable in question was a WSTRING.
WSTRING is a native data type and I assumed the compiler was smart enough to do the copy.
Now with BSTR or CBStr that would be a different story.
James
JosÚ Roca
« Reply #17 on: June 30, 2016, 11:09:50 PM »
The editor always displays the compiler results, which can be annoying.
In CSED I have the following options (checkboxes):
Compiler results:
- Display results
- Delete log file
- Beep on completion
- Display warnings
Errors are always displayed, of course.
« Reply #18 on: June 30, 2016, 11:22:00 PM »
Good idea. In the FireFly program I have the following option which I will also build into this editor:
[ ] Suppress results if no errors occur during the compile.
JosÚ Roca
« Reply #19 on: July 01, 2016, 12:50:10 AM »
Some code to add autoindentation:
In Scintilla_OnNotify add
      CASE SCN_CHARADDED
         IF pNSC->ch = 13 THEN
            IF gConfig.AutoIndentation THEN
               DIM pDoc AS clsDocument PTR = gTTabCtl.GetActiveDocumentPtr()
               IF pDoc THEN
                  hEdit = pDoc->hWindow
                  ' // Current position
                  DIM curPos AS LONG = SendMessage(hEdit, SCI_GETCURRENTPOS, 0, 0)
                  ' // Current line
                  nLine = SendMessage(hEdit, SCI_LINEFROMPOSITION, curPos, 0)
                  ' // Line length of the previous line
                  DIM LineLen AS LONG = SendMessage(hEdit, SCI_LINELENGTH, nLine - 1, 0)
                  IF LineLen < 1 THEN EXIT FUNCTION
                  ' // Get the text of the previous line
                  DIM buffer AS STRING = SPACE(LineLen)
                  SendMessage(hEdit, SCI_GETLINE, nLine - 1, cast(LPARAM, STRPTR(buffer)))
                  ' // Get the tab width
                  DIM TabSize AS LONG = SendMessage(hEdit, SCI_GETTABWIDTH, 0, 0)
                  ' // Calculate the number of spaces to fill on the left
                  DIM nSpaces AS LONG, i AS LONG
                  FOR i = 1 TO LEN(buffer)
                     IF MID(buffer, i, 1) <> " " THEN
                        IF MID(buffer, i, 1) = CHR(9) THEN
                           nSpaces = nSpaces + TabSize
                           EXIT FOR
                        nSpaces = nSpaces + 1
                  DIM strFill AS STRING = ""
                  ' // Remove $CRLF
                  buffer = FF_Remove(buffer, CHR(13))
                  buffer = FF_Remove(buffer, CHR(10))
                  ' // Remove spaces and tabs and convert to uppercase
                  buffer = TRIM(UCASE(buffer), ANY CHR(32, 9))
                  IF (LEFT$(buffer, 3) = "IF " AND RIGHT$(buffer, 5) = " THEN") OR _
                     LEFT$(buffer, 4) = "ELSE" OR _
                     LEFT$(buffer, 7) = "SELECT " OR _
                     LEFT$(buffer, 5) = "CASE " OR _
                     LEFT$(buffer, 4) = "FOR " OR _
                     LEFT$(buffer, 3) = "DO " OR _
                     buffer = "DO" OR _
                     LEFT$(buffer, 6) = "WHILE " OR _
                     buffer = "WHILE" THEN
                     ' // Indentation size
                     DIM IndentSize AS LONG = SendMessage(hEdit, SCI_GETINDENT, 0, 0)
                     ' // Add spaces to indent the line
                     strFill = SPACE(nSpaces + IndentSize)
                     ' Add the same spaces on the left that the line above
                     strFill = SPACE(nSpaces)
                  ' *** TODO: If using tabs, replace spaces with tabs
                  ' // Indents the line
                  SendMessage(hEdit, SCI_ADDTEXT, LEN(strFill), cast(LPARAM, STRPTR(strFill)))
JosÚ Roca
« Reply #20 on: July 01, 2016, 01:15:24 AM »
Some PB code to replace spaces with tabs:
' Replaces spaces with tabs
' Based on code originally written by Steve Miltiadous
FUNCTION SCIP_SpacesToTabs (BYVAL pSci AS DWORD, BYVAL strIn AS STRING) AS STRING
   LOCAL i       AS LONG     ' // Loop counter
   LOCAL TabSize AS LONG     ' // Size of the tab
   LOCAL strSpc  AS STRING   ' // Spaces
   LOCAL strTab  AS STRING   ' // Tabs
   LOCAL strOut  AS STRING   ' // Output string
   IF ISNULL(strIn) THEN EXIT FUNCTION
   ' // Retrieve the tab size
   TabSize = SCIP_GetTabWidth(pSci)
   IF TabSize < 1 THEN
      FUNCTION = strIn
   ' // Calculate the number of spaces and tabs needed
   FOR i = 1 TO LEN(strIn)
      IF INSTR(MID$(strIn, i, 1), CHR$(32))  THEN
         strSpc += MID$(strIn, i, 1)
      ELSEIF INSTR(MID$(strIn, i, 1), CHR$(9) ) THEN
         strTab += MID$(strIn, i, 1)
         EXIT FOR
   ' // Replace spaces with tabs
   IF LEN(strSpc) >= TabSize THEN
      REPLACE SPACE$(TabSize) WITH $TAB IN strSpc
      strOut = strTab & strSpc & MID$(strIn, i)
      strOut = strIn
   ' // Return the resulting string
   FUNCTION = strOut
JosÚ Roca
« Reply #21 on: July 01, 2016, 02:27:31 AM »
If the user selects the Russian charset, he can use the following code to set the text in Russian:
   ' // Adds a button
   DIM cb AS CBSTR = AfxUcode("&Отмена", 1251)
   DIM hButton AS HWND = pWindow.AddControl("Button", , IDCANCEL, cb, 350, 250, 75, 23)
Same for the other charsets supported by Scintilla.
We have to use AfxUcode("&Отмена", 1251) because although we are seeing "&Отмена" in the editor, in reality it is an ansi string, "&╬˛ýňÝÓ".
« Last Edit: July 01, 2016, 02:44:30 AM by Jose Roca »
JosÚ Roca
« Reply #22 on: July 01, 2016, 02:40:04 AM »
If we declare the parameter as BYREF WSTRING, instead of BYVAL WSTRING PTR, we can pass the CBSTR variable directly, without having to deference it with *.
So if the parameter is BYREF WSTRING, we can pass cb, else *cb.
JosÚ Roca
« Reply #23 on: July 01, 2016, 02:48:31 AM »
This can be used for functions in which we want to return an string. We will return a BSTR that will be assigned to a CBSTR. What we should not do is to pass the returned string directly to a function because it won't be freed.
It's not perfect, but that is what we have. Only the compiler can ascertain if a string is temporary and free it.
If WSTR had a an optional codepage parameter, we coud use:
DIM hButton AS HWND = pWindow.AddControl("Button", , IDCANCEL, WSTR("&Отмена", 1251), 350, 250, 75, 23)
We must request to the developers of the compiler to modify WSTR to allow this optional codepage parameter.
« Last Edit: July 01, 2016, 03:00:36 AM by Jose Roca »
JosÚ Roca
« Reply #24 on: July 01, 2016, 01:00:17 PM »
Or better yet, to request the addition to the language of UCODE and ACODE, with support for the optional CodePage parameter. The big advantage of implementing it in the language is that the compiler will take care of freeing the temporary WSTRINGs.
« Reply #25 on: July 02, 2016, 08:20:04 PM »
      CASE SCN_CHARADDED
               IF pDoc THEN
                  ' // Current line
                           EXIT FOR
                  ' // Remove $CRLF
                     buffer = "DO" OR _
Thanks Jose! and you already converted it to FB, awesome! I have just implemented this into the editor. It makes code editing so much better.
I will upload new code later tonight. Just finishing some code in the project management sections.
JosÚ Roca
« Reply #26 on: July 02, 2016, 08:43:43 PM »
That code has let me to know that something was wrong with the 64-bit DLL, because it does work if compiled with 32-bit but not with 64-bit. As the 64-bit DLL that I found is for a .NET project, maybe they have changed the way notifications work.
« Reply #27 on: July 02, 2016, 10:08:05 PM »
I have been able to get the notifications to work on 64 bit. I modified your Scintilla include file as follows:
Type Sci_NotifyHeader Field = 4
  ' /* Compatible with Windows NMHDR.
  ' // code should be DWORD, but it is defined as LONG in PBWin 9 built-in NMHDR structure.
  '  * hwndFrom is really an environment specific window handle or pointer
  '  * but most clients of Scintilla.h do not have this type visible. */
'  hwndFrom As uLong   ' void *hwndFrom
'  idfrom   As uLong   ' uptr_t idFrom
'  code     As Long    ' unsigned int code
hwndFrom as HWND
idFrom As UINT_PTR
code As UINT
End Type
Type SCNotification Field = 4
   hdr                  As Sci_NotifyHeader
   position             As Integer
   ch                   As Integer
   modifiers            As Integer
   modificationType     As Integer
   lpText               As ZString Ptr
   length               As Integer
   linesAdded           As Integer
   message              As uInteger   ' must be DWORD, not LONG
   wParam               As uInteger
   lParam               As Integer
   nLine                As Integer
   foldLevelNow         As Integer
   foldLevelPrev        As Integer
   margin               As Integer
   listType             As Integer
   x                    As Integer
   y                    As Integer
   token                As Integer
   annotationLinesAdded As Integer
   updated              As Integer
End Type
I expect that the other TYPE's may also need to be updated to change Long and ULong to the compiler dependent Integer and UInteger.
Pages: 1 [2]
