WinFBE on GitHub (July 6, 2016)
Started by Paul Squires, July 06, 2016, 03:32:42 PM
.... I have now switched from JellyFB to WinFBE for actually writing WinFBE. This now means that WinFBE is used to write itself. I now remember the feeling I had the first time that I used FireFly to compile FireFly.  :)
We write tools to make programming easier, but we could not do it if we weren't able to write these tools by hand.
Something weird has happened with the .lang files, e.g.
' WinFBE localization file for ENGLISH language
' The first element to exist must be called "MAXIMUM" and needs to be set to
਍✀ 琀栀攀 瘀愀氀甀攀 漀昀 琀栀攀 氀愀猀琀 欀攀礀 椀渀 琀栀椀猀 昀椀氀攀⸀ ഀഀ
਍✀ 吀栀椀猀 昀椀氀攀 猀栀漀甀氀搀 戀攀 挀爀攀愀琀攀搀 愀渀搀 猀愀瘀攀搀 甀猀椀渀最 唀吀䘀ⴀ㄀㘀 攀渀挀漀搀椀渀最 ⠀甀渀椀挀漀搀攀⤀⸀ഀഀ
਍✀ 䔀愀挀栀 氀椀渀攀 爀攀瀀爀攀猀攀渀琀猀 愀 欀攀礀⼀瘀愀氀甀攀 瀀愀椀爀 搀攀猀挀爀椀戀椀渀最 琀栀攀 瀀漀猀椀琀椀漀渀 琀漀 猀琀漀爀攀 琀栀攀ഀഀ
' localized word/phrase into the localization array used by winFBE. Simple.
MAXIMUM:230
00000:&OK
਍    ㄀㨀☀䌀愀渀挀攀氀ഀഀ
00002:&File
਍    ㌀㨀☀一攀眀ഀഀ
#18
WinFBE 64 bit as GPFed one after cheking the option "Confine caret to text" and clicking OK. Can't reproduce it again. Maybe something wrong in the packaged .ini file?
Yes, I noticed a corruption in the files yesterday when I changed GitHub's default line ending setting for the text files to be CRLF. I fixed it last night and re-uploaded. You must have a version prior to today? I also added several new uploads today to reduce flicker in the editor. Looks smoother and more polished now.
I have just downloaded it again, and the .lang files are corrupted.
That is strange. They view okay from the GitHub website but when you download the zip they show corrupted. Looks like it must be because they are unicode files (*.lang, *.ini). I will remove those types from the .gitattributes file and see if it makes a difference.
Yes, that was exactly the problem. Download is working okay now.
