Author Topic: Default font name problem  (Read 1783 times)
« on: July 11, 2016, 07:26:18 PM »
Hi Jose,
Looks like a problem with the default font name (I think). If I leave the font name blank in a call to CWindow.SetFont or CWindow.CreateFont then the class should use the default face name for the class. You are testing with this code:
   IF VARPTR(wszFacename) THEN wstrFaceName = wszFaceName ELSE wstrFaceName = m_wszDefaultFontName
I had assumed that if I passed a Null string as the face name that the class would use the default name.
pWindow->SetFont( "", 10, FW_BOLD)
This fails because a Null string still has an address(?)
Calling the function with a ByVal Null seems to work:
   pWindow->SetFont( byval null, 9, FW_BOLD)
Maybe also add a test to the incoming string for it's length? If the length is zero (null string) then also use the default font name.
Re: Default font name problem
« Reply #1 on: July 11, 2016, 11:44:01 PM »
This is another thing where FB differs from PB.
It is like they wanted me to use BYVAL PTR instead of BYREF.
« Last Edit: August 31, 2016, 11:45:44 PM by Jose Roca »
