CXpButton
Started by Paul Squires, June 15, 2018, 11:44:53 PM
#45
I have added:
      CASE BM_CLICK
         .SendMessageW hwnd, WM_LBUTTONDOWN, 0, 0
         .SendMessageW hwnd, WM_LBUTTONUP, 0, 0
Not tested yet, but it should work.
I doubt that will work because LBUTTONDOWN and LBUTTONUP do hit testing based on the cursor position to determine if the user has clicked the button. When I get home this evening I will work up some code and post it here for you to include in the button class.
Thanks, Paul
You're right. I had no time for testing it. Let's see if this works:
      CASE BM_CLICK
         IF .IsWindowEnabled(hwnd) = FALSE THEN EXIT FUNCTION
         ' // Redraws the button in pushed state
         pButton = CAST(CXpButton PTR, .GetWindowLongPtrW(hwnd, 0))
         IF pButton = NULL THEN EXIT FUNCTION
         IF pButton->m_bIsToggle THEN
            IF pButton->m_bToggled = FALSE THEN
               pButton->m_bToggled = TRUE
         pButton->m_fState = BST_PUSHED
         pButton->Redraw
         ' // Redraws the button in unpushed state
         pButton->m_fState = 0
         pButton->Redraw
         ' // Set the focus in the button
         .SetFocus hwnd
         ' // Forwards the message to the parent window
         .SendMessageW .GetParent(hwnd), WM_COMMAND, MAKELONG(GetDlgCtrlId(hwnd), BN_CLICKED), CAST(.LPARAM, hwnd)
Thanks Jose! I tested it and it seems to be working okay so far  :-)
I have added the ButtonBkColorDown properties to change the background color of the button when it is pressed or toggled.
Hi José,
Thanks for the new code. I added a new Button property called "BackColorDown". Seems to be working okay.
Hi José,
The CXpButton could use two functions similar to the ones that you have for the CImageCtx control. Currently, I have to use the GetWindowLongPtr calls directly during my WM_DESTROY to get the CXpButton pointers. For convenience and consistency it would be nice to have AfxCXpButtonPtr like the AfxCImageCtxPtr functions below.
' Returns a pointer to the class given the handle of its associated window handle.
' hCtl = Handle of the image control.
PRIVATE FUNCTION AfxCImageCtxPtr OVERLOAD (BYVAL hCtl AS HWND) AS CImageCtx PTR
   FUNCTION = CAST(CImageCtx PTR, .GetWindowLongPtrW(hCtl, 0))
' hParent = Handle of the parent window of the image control.
' cID = Identifier of the image control.
PRIVATE FUNCTION AfxCImageCtxPtr OVERLOAD (BYVAL hParent AS HWND, BYVAL cID AS LONG) AS CImageCtx PTR
   FUNCTION = CAST(CImageCtx PTR, .GetWindowLongPtrW(GetDlgItem(hParent, cID), 0))
Done.
I smile when I remember that I thought of deprecate it, and only adapted it to practice how to implement a custom control using a class :)
Excellent - thanks :-)
That button is one of the main controls in the WinFBE visual designer code output. It is very versatile.
Hi José,
I had to make a very change to the CTmageCtx.DrawImage function. I had to move the test for the pImage pointer being null down to the block where the image is actually outputted. It now looks like this:
   IF ( pGraphics ) andalso ( pImage )THEN
This enables me to draw the background normal or HOT regardless of whether an image is actually specified.
I have attached the new CImageCtx control code.
