Pages: 1 [2]
Author Topic: Keeping TAB sequence on one CHILD form  (Read 3334 times)
Re: Keeping TAB sequence on one CHILD form
« Reply #15 on: June 26, 2018, 09:42:32 PM »
Now you know why I insisted so much about the subject. Some PBer's that have begin to use 4K monitors are now looking for my posts about DPI.
« Reply #16 on: June 26, 2018, 09:47:43 PM »
You're a man who's ahead of his time  :D
« Reply #17 on: June 27, 2018, 03:09:55 PM »
Hey guys, its always good to ask here.
Thanks for the help, busy making the changes!
And as soon as the Firefly for Freebasic is there, i will most definitely enjoy using your high dpi controls!!
Thanks a million.
-Peter
« Reply #18 on: June 27, 2018, 03:42:33 PM »
Yes, a simple FF_control_disable on the forms hiding and a simple FF_control_enable on the form you see keeps the Tab sequence nicely on one form.
Seems logical now.... :-[
thanks for the advice.
Pages: 1 [2]
