Author Topic: Tapatalk and PlanetSquires forum  (Read 618 times)
« on: December 30, 2018, 07:35:03 AM »
The PlanetSquires forum has installed the Tapatalk plugin and is now registered with the Tapatalk network. If you are using Tapatalk then simply search for "PlanetSquires" in the app and you should find this forum. Enter your forum log in details and you should be good to go. It is much easier to interact with the forum on a mobile device using Tapatalk than it is to use a mobile web browser and try to navigate and read messages on the forum.
https://www.tapatalk.com/tapatalk_mobile
Tapatalk is an application to allow access to Internet forums on mobile devices, developed by Tapatalk, Inc.
Tapatalk is primarily designed to provide improved forum access for mobile platforms over access provided by the forum software itself. The application was originally designed for Android but now also supports iOS and Windows Phone. Tapatalk allows the user to have a unified interface to access multiple forums at the same time.
Forum software systems supported by Tapatalk are: phpBB3, vBulletin, xenForo, IPBoard, Simple Machines Forum, MyBB, bbPress, Kunena, Vanilla Forums, ASP Playground, and Drupal. In addition, 'Conversr' (the integrated forum of Composr CMS) allows for Tapatalk support via the installation of an official addon.
