AfxGetWindowSize
Started by Paul Squires, January 02, 2019, 01:17:48 PM
Hi Jose,
While working on some resize code, I noticed that there is not a AfxGetWindowSize function. There are separate functions for AfxGetWindowWidth and AfxGetWindowHeight and also a AfxSetWindowSize. It would be convenient to have a AfxSetWindowSize and including such a function would also help parallel the AfxGetWindowLocation and AfxSetWindowLocation functionality.
I know that you can easily code such a function but for convenience I have it below based other code from your library.
' Gets the width and height of the window, in pixels.
PRIVATE SUB AfxGetWindowSize (BYVAL hwnd AS HWND, BYREF nWidth AS LONG, BYREF nHeight AS LONG)
   DIM rc AS RECT
   ' // Get the dimensions of the window
   GetWindowRect(hwnd, @rc)
   ' // Return the width and height values
   nWidth = rc.Right - rc.Left
   nHeight = rc.Bottom - rc.Top
