Pages: 1 [2]
Author Topic: Are you adventurous? WinFBE 1.8.8 draft is ready....  (Read 1589 times)
Re: Are you adventurous? WinFBE 1.8.8 draft is ready....
« Reply #15 on: January 20, 2019, 03:19:06 PM »
I wonder if the following may be the problem (issue with the font?) because I am using a unicode edit control (from CWindow). I will try setting a different font and see what happens......
https://stackoverflow.com/questions/7153340/russian-characters-not-showing-up-correctly-in-mfc-unicode-list-box
https://stackoverflow.com/questions/8742882/display-arabic-unicode-in-mfc-view?rq=1
« Last Edit: January 20, 2019, 03:20:52 PM by Paul Squires »
« Reply #16 on: January 20, 2019, 03:48:52 PM »
is the options - build configurations - working properly? It seems stuck on win32 console (release)
« Reply #17 on: January 20, 2019, 04:01:33 PM »
I fixed that yesterday if I remember correctly.... it was not saving between sessions. I will upload another package tonight if I get this Russian font thing figured out.
« Reply #18 on: January 20, 2019, 04:14:23 PM »
When I switch to Russian and restart WinFBE, the entire application shows "??????" for text. I am wondering if it will require being on a Russian version of Windows. I do have #Define UNICODE defined for the compiled version of WinFBE.
« Reply #19 on: January 21, 2019, 03:13:17 AM »
No. It works in this test:
' Microsoft Windows
' Contents: Demonstrates the use of the Edit control.
' Copyright (c) 2016 José Roca. Freeware. Use at your own risk.
#define UNICODE
#INCLUDE ONCE "Afx/CTextStream.inc"
USING Afx
CONST IDC_EDIT1 = 1001
' // Forward declaration
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "Edit controls", @WndProc)
   pWindow.SetClientSize 400, 200
   pWindow.Center
   ' // Add an Edit control
   DIM hEdit AS HWND = pWindow.AddControl("Edit", , IDC_EDIT1, "", 20, 15, 305, 23)
   ' // Set the focus in the first edit control
   SetFocus hEdit
dim idx as long
   ' // Create an instance of the CTextStream class
DIM pTxtStm AS CTextStream
' // Open file as a text stream
DIM cbsFile AS CBSTR = ExePath & $"\russian.lang"
DIM cbs AS CBSTR
IF pTxtStm.OpenUnicode(cbsFile) = S_OK THEN
   ' // Read the file sequentially
   DO UNTIL pTxtStm.EOS
      cbs = pTxtStm.ReadLine
      idx = idx + 1
      if idx > 20 then exit do
   LOOP
   pTxtStm.Close
DIM i as long
i = Instr(cbs, ":")
cbs = Mid(**cbs, i+1)
SetWindowText hEdit, cbs
cbs = rtrim(AfxStrParse(cbs, 1, ";"), any chr(9,32))
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
    CASE WM_DESTROY
         ' // End the application
         PostQuitMessage(0)
« Reply #20 on: January 21, 2019, 03:15:03 AM »
I remember that it worked in a much older version. Don't know in which version started happening.
« Last Edit: January 21, 2019, 09:22:05 AM by José Roca »
« Reply #21 on: January 21, 2019, 03:55:15 AM »
The Chinese.lang file that comes with this package is bad. It is full of ???.
« Reply #22 on: January 21, 2019, 08:43:58 AM »
Yes, your demo works on my system as well. Strange, because in WinFBE I am using the same type of code as you are to open and read the file. I am using the CTextStream class and CBSTR's. You can see this in the LoadLocalizationFile function in the modRoutines.inc file.
During startup, I load the "English.lang" into a global array gLangEnglish() and whatever localized file into the LL() array. The only difference being that the arrays are WSTRING * MAX_PATH rather than CBSTR but the conversion from CBSTR to WSTRING shouldn't make a difference, should it? I am a little perplexed by this problem so far.
« Reply #23 on: January 21, 2019, 11:27:50 AM »
I have found the problem. The intrinsic FB string functions don't work with languages like Chinese and Russian if you rely in automatic conversion. I warned you about it regarding MID, but it also happens with other functions.
The only reliable way with the current versions of FB is to use ** because this way you access the string buffer directly, without conversions (and it is faster too).
So, instead of
use
cbs = rtrim(**AfxStrParse(cbs, 1, ";"), any chr(9,32))
So get used to ** whem using FB intrinsic string functions.
« Last Edit: January 21, 2019, 11:36:16 AM by José Roca »
« Reply #24 on: January 21, 2019, 11:33:44 AM »
The problem appears to be when I apply RTRIM.
' FAIL
      gLocalPhrases(pp) = rtrim(AfxStrParse(wData, 1, ";"), any chr(9,32))
      AfxSetWindowText( GetDlgItem(HWND_FRMOPTIONSLOCAL, IDC_FRMOPTIONSLOCAL_CMDLOCALIZATION), gLocalPhrases(pp) )
' SUCCESS
      gLocalPhrases(pp) = AfxStrParse(wData, 1, ";")
      AfxSetWindowText( GetDlgItem(HWND_FRMOPTIONSLOCAL, IDC_FRMOPTIONSLOCAL_CMDNEW), gLocalPhrases(pp) )
' SUCCESS
      gLocalPhrases(pp) = wData
      AfxSetWindowText( GetDlgItem(HWND_FRMOPTIONSLOCAL, IDC_FRMOPTIONSLOCAL_CMDEDIT), gLocalPhrases(pp) )
« Reply #25 on: January 21, 2019, 11:35:06 AM »
LOL, we posted the same time  :-)
Thanks for researching it Jose. I will make sure to use ** with the FB intrinsic functions.
« Reply #26 on: January 21, 2019, 03:00:19 PM »
Hi Paul, Looking Good!
1.
Testing various items on the Version 1.8.8 list copied from GitHub. I like Snippets; nice and simple and works very well.
2.
F6 works on my machine but only after the subject file has been loaded into the editor.
Close the file(s) and F6 works okay with no need to perform the same file open/close on subsequent runnings of WinFBE.
Example: In an #Include file, this line functioned correctly when called from my test program:
? "Last Error: " + toStringFBerrorCodes( GetLastError() ) However, highlighting toStringFBerrorCodes and pressing F6 only popped up a file not found msgbox. Load the (#included) file (.bi) into the editor and then close it (the file now appears in Explorer/Header) and F6 opens the file and moves the cursor to the beginning of the function. I'm not sure if this is by design or not.
3.
Is there a way to set the colours for the 3 combo boxes to windows default or the Explorer panel or my choice? See the attached image.
Thanks.
« Reply #27 on: January 21, 2019, 04:16:31 PM »
Hi Clive,
The F6 functionality is designed to only work if the source code containing the sub/function being searched for is actually loaded in WinFBE (either in an open Tab, or as part of a Project).
I will change the colors for those comboboxes. I set them to equal the same color as the edit window (background/foreground/highlight) because I thought that people using different theme colors would like to have those comboboxes reflect the same type of colors. Personally, like you, I prefer the standard Windows colors. Maybe in the future I will allow a setting to color them different or a setting to toggle their visibility (show/hide).
Thanks for testing. I will upload a new test version shortly that has a new PictureBox control for the visual designer along with a few minor fixes I came across since the last draft upload. If this next draft goes okay then I will post a formal release in the next few days.
« Reply #28 on: January 21, 2019, 04:48:41 PM »
Thanks, Paul,
I assumed that all the includes would be searched when F6 was pressed but that could slow down the editor if there were a lot of files to search.
When you get to working on colour settings, any chance of special colours for user defined functions/types, WinAPI etc. I've manually added key words like GetTickCount and GetLastError to freebasic_keywords.txt which sort of works. I guess I got used to FF3's colouring scheme.
Pages: 1 [2]
