Author Topic: Mutex and Firefly  (Read 1677 times)
Richard Marchessault
Mutex and Firefly
« on: January 31, 2019, 09:23:01 AM »
What code would you recommend to determine if a program is already and switch to the running program instead of starting it up again? I can see examples of using CreateMutex on the PowerBasic forums but wonder how best to implement this with FireFly.
Dick
Pierre Bellisle
Re: Mutex and Firefly
« Reply #1 on: January 31, 2019, 11:26:16 AM »
Sadly, I'm not a FireFly user, but still, here is the same Mutex & GW_HWNDNEXT approach I had in PowerBASIC...
#Define JumpCompiler "<D:\Free\64\fbc.exe>" 'Compiler to use "< = left delimiter, >" = right delimiter
#Define JumpCompilerCmd "<-s gui -w pedantic "D:\Free\bas\~~Default.rc">" 'Command line to send to compiler (gui or console)
#define UniCode
#Include Once "windows.bi"
#Include Once "win\shellapi.bi"
#Define AppName "Mutex demo"
#Define StaticInfo 101
#Define CrLf Chr(13, 10)
#Define dwMutex 1901310955 '[YYMMDDHHMM] - 10 digits - Max is 4,294,967,295, I use current time
Dim Shared As HINSTANCE hInstance : hInstance = GetModuleHandle(NULL)
Function WndProc(ByVal hWnd As HWND, ByVal uMsg As UINT, ByVal wParam As WPARAM, ByVal lParam As LPARAM) As Integer
 Dim    hStaticInfo        As HWND
 Static hWindowDefaultFont As HFONT
 Function = 0
 Select Case (uMsg)
   Case WM_CREATE
     Dim As NONCLIENTMETRICS NotClientMetrics
     NotClientMetrics.cbSize = SizeOf(NONCLIENTMETRICS)
     SystemParametersInfo(SPI_GETNONCLIENTMETRICS, NotClientMetrics.cbSize, @NotClientMetrics, 0)
     hWindowDefaultFont = CreateFontIndirect(@NotClientMetrics.lfMessageFont)
     hStaticInfo = CreateWindowEx(0, "Static", "Try to run another self instance" & CRLF & "(Minimize me before)", _
                                  WS_CHILD Or WS_VISIBLE Or SS_CENTER Or SS_NOTIFY, _
                                  10, 30, 200, 30, _
                                  hWnd, Cast(HMENU, StaticInfo), _
                                  hInstance, NULL)
    SendMessage(hStaticInfo, WM_SETFONT, Cast(UInteger, hWindowDefaultFont), TRUE)
   Case WM_DESTROY
     DeleteObject(hWindowDefaultFont) 'Clean up
     PostQuitMessage(0) 'Ask message loop to end
     Exit Function
 Function = DefWindowProc(hWnd, uMsg, wParam, lParam)
Function WinMain(ByVal hInstance As HINSTANCE, ByVal hPrevInst As HINSTANCE, _
                 ByVal CmdLine As WString Ptr, ByVal CmdShow As Integer) As UINT
 Dim WinClass   As WNDCLASS
 Dim wMsg       As MSG
 Dim hWnd       As HWND
 Dim hIco       As HICON
 Dim WindowSize As SIZEL
 Dim wsAppName  As WString * 128
 wsAppName              = AppName
 WindowSize.cx          = 230
 WindowSize.cy          = 120
 hIco                   = ExtractIcon(GETMODULEHANDLE(""), "Shell32.dll", 294) 'o
 WinClass.style         = CS_HREDRAW Or CS_VREDRAW
 WinClass.lpfnWndProc   = ProcPtr(WndProc)
 WinClass.cbClsExtra    = 0
 WinClass.cbWndExtra    = 0
 WinClass.hInstance     = hInstance
 WinClass.hIcon         = hIco
 WinClass.hCursor       = LoadCursor(NULL, IDC_ARROW)
 WinClass.hbrBackground = Cast(HGDIOBJ, COLOR_BTNFACE + 1) 'Default color
 WinClass.lpszMenuName  = NULL
 WinClass.lpszClassName = @wsAppName
 Dim hTry        As HWND
 Dim hMutex      As HWND
 Dim zMutex      As ZString * 16
 zMutex  = "MyUniqueMutex" 'MaxStringLen is %MAX_PATH, no "\", case sensitive
 hMutex  = CreateMutex(ByVal NULL, 0, zMutex)
 If GetLastError = ERROR_ALREADY_EXISTS Then
   Beep()
   'Optionnal: MessageBox(HWND_DESKTOP, AppName & " is already running!", AppName, MB_TOPMOST Or MB_OK)
   hTry =  GetForegroundWindow()
   Do While hTry
     If  GetWindowLongPtr(hTry, GWLP_USERDATA) = dwMutex Then
       If IsIconic(hTry) Then ShowWindow(hTry, SW_RESTORE) 'Unminimize exe
       SetForegroundWindow(hTry)
       Exit Do
     hTry = GetWindow(hTry, GW_HWNDNEXT)
   Loop
   If hTry = 0 Then 'Can't find it!!!
     MessageBox(HWND_DESKTOP, AppName & " is running hidden in background!", AppName, MB_TOPMOST Or MB_OK)
   End IF
   End
 If (RegisterClass(@WinClass)) Then
   hWnd = CreateWindowEx(WS_EX_WINDOWEDGE, _
                         wsAppName, wsAppName, _
                         WS_OVERLAPPED OR WS_CLIPCHILDREN Or WS_DLGFRAME Or WS_BORDER Or WS_VISIBLE Or WS_CAPTION Or _
                         WS_MAXIMIZEBOX Or WS_MINIMIZEBOX Or WS_SYSMENU , _
                         (GetSystemMetrics(SM_CXSCREEN) - WindowSize.cx) / 2, _ 'PosX
                         (GetSystemMetrics(SM_CYSCREEN) - WindowSize.cy) / 2, _ 'PosY
                         WindowSize.cx, WindowSize.cy, _ 'Width, height
                         NULL, NULL, hInstance, NULL)
   SetWindowLongPtr(hWnd, GWLP_USERDATA, dwMutex) 'Set window mutex
   ShowWindow(hWnd, SW_SHOW)
   UpdateWindow(hWnd)
   While GetMessage(@wMsg, ByVal NULL, 0, 0) > 0
     If IsDialogMessage(hWnd, @wMsg) = 0 Then
       TranslateMessage(@wMsg)
       DispatchMessage(@wMsg)
   Wend
 DestroyIcon(hIco)
 CloseHandle(hMutex)
 Function = wMsg.message
End WinMain(hInstance, NULL, Command(), SW_NORMAL) 'Call main() and return the error code to the OS
« Reply #2 on: January 31, 2019, 12:13:39 PM »
Pierre,
Firefly uses PowerBasic, not Freebasic.
« Last Edit: January 31, 2019, 03:45:40 PM by José Roca »
Pierre Bellisle
« Reply #3 on: January 31, 2019, 03:27:48 PM »
This was my impression, so I double checked with a quick search and got FireFly for FreeBASIC v3.78 uploaded... by Paul and then because the PowerBASIC's answers where quite explicit I thought Richard was adapting code, I guess that it was kind of a redundant variant of the same question.
In any case, for easy find, the PB equivalent of the above code is at Mutex and GWL_USERDATA
« Last Edit: January 31, 2019, 07:53:31 PM by Pierre Bellisle »
« Reply #4 on: January 31, 2019, 03:51:20 PM »
Sorry, I forgot that there was a version of Firefly for FreeBasic. I wonder why somebody will want to use it, since it was deprecated long time ago.
Klaas Holland
« Reply #5 on: January 31, 2019, 06:27:15 PM »
I do use FireFly for FreeBasic and I am pleased with it.
That was my way to learn FreeBasic.
Now I am waiting for WinFBE to become as good and easy as FireFly.
Marc Pons
« Reply #6 on: February 01, 2019, 07:39:49 AM »
@José, I also use Firefly for freebasic and with the extension i have done arround , it is totally usable,
i use it still with freebasic from 0.24  to 1.06 on 32bits and 1.05 or 1.06 on 64bits
in my understanding it is a vey interresting tool to create simple windowed app , I even can make windowed dll with it.
Even COM app using my old axsuite3 adaptation...
until the new Paul's visual editor is not totally done it is a very simple solution for people not wanting to write all sdk stuff.
As a nostalgic of vb6, it was the closest i've found, and hope to find the same simplicity with the new Paul's visual editor (sorry still not tested)
I take here alse the opportunity to thank you again Paul and you José for the great features of your contributions
kind regards
Marc
Paul:  i did not make the evolution on the French translation for your last ide version, (was travelling in your countrie in Montréal)
is it some changes in the existing I have to check or just adding new translations?
« Last Edit: February 01, 2019, 07:46:50 AM by Marc Pons »
David Kenny
  • Windows 7 & 10
« Reply #7 on: February 03, 2019, 05:04:59 AM »
Dick,
This code is the entire FF_WinMain in one of my old programs. You can get to FF_WinMain from the Firefly Workspace dialog (F9 to activate the dialog). On the Explorer tab, under Special Functions.
Function FF_WINMAIN(ByVal hInstance     As Dword, _
                    ByVal hPrevInstance As Dword, _
                    ByVal lpCmdLine     As Asciiz Ptr, _
                    ByVal iCmdShow      As Long) As Long
Local hWin      As   Dword
Local ProgName   As   String
'If this function returns TRUE (non-zero) then the actual WinMain will exit
'thus ending the program. You can do program initialization in this function.
Dim DrSelFlag(5)
ProgName="User Copy"
If FF_PrevInstance Then
   hWin = FindWindow(ByVal %Null, ByVal StrPtr(ProgName))
   OpenIcon hWin                       '-- Activate the first instance
   SetForegroundWindow hWin
   Function = %True    'return %TRUE if you want the program to end.
Else
   Function = %False
Just change the ProgramName from "User Copy" to your program name.  The mutex is handled by the FF routine FF_PrevInstance (in the Functions Library - Hit F8 - in the General branch). The rest I got from the PB forums.
It does exactly what you are asking for.
David
« Last Edit: February 03, 2019, 05:11:46 AM by David Kenny »
Klaas Holland
« Reply #8 on: March 14, 2019, 07:01:26 AM »
This is the FreeBasic version
Function FF_WINMAIN ( ByVal hInstance     as HINSTANCE, _
                      ByVal hPrevInstance as HINSTANCE, _
                      ByRef lpCmdLine     as String,    _
                      ByVal iCmdShow      as Long       ) as Long
        Dim hWin   as Long  =  FindWindow(gFLY_AppID, ByVal 0)
        Function = True
    Else
        Function = False    'return TRUE if you want the program to end.
Wilko Verweij
  • PB10 - FF3.7 User; Win 10
    • CHEAQS
« Reply #9 on: March 15, 2019, 05:23:04 PM »
Hi, I doubt if this actually works. See : https://docs.microsoft.com/en-us/windows/desktop/api/winbase/nf-winbase-winmain
Type: HINSTANCE
A handle to the previous instance of the application. This parameter is always NULL. If you need to detect whether another instance already exists, create a uniquely named mutex using the CreateMutex function.
So I think this code does not work for modern Windows versions. It should have worked under older versions. See https://stackoverflow.com/questions/7458436/why-does-previnstance-exist-in-winmain-and-wwinmain-if-it-is-always-null
Sorry for spoiling...
The FindWindow / OpenIcon / SetForeGroundWindow is still a useful suggestion (did not test).
Wilko
« Reply #10 on: March 15, 2019, 06:03:46 PM »
I suggest that you reread the post. It is not checking the hPrevInstance parameter, but calling the FF_PrevInstance function, that in turn calls FindWindow.
Wilko Verweij
    • CHEAQS
« Reply #11 on: March 15, 2019, 06:07:02 PM »
You are right, of course. I overlooked the difference between hPrevInstance and FF_PrevInstance. Sorry for the confusion.
