Pages: 1 [2]
Author Topic: some basic filing stuff  (Read 3980 times)
Re: some basic filing stuff
« Reply #15 on: August 16, 2019, 01:40:22 PM »
LOL - yup, use Jose's Afx code  :)
James Fuller
« Reply #16 on: August 17, 2019, 06:52:22 AM »
In this link I describe an issue with gcc and dates on Windows with msvcrt.dll.
https://www.oxygenbasic.org/forum/index.php?topic=1947.0
Josť; are there API calls that will produce the correct results??
James
James Fuller
« Reply #17 on: August 17, 2019, 01:09:11 PM »
Josť,
 The line in question is:
strftime (buffer, SIZE, "ISO week day is %GW%V%u.\n", loctime);
 fputs (buffer, stdout)
msvcrt.dll version of strftime  lacks the format characters.
How would you print the ISO week day with an API call??
James
« Reply #18 on: August 17, 2019, 02:04:32 PM »
When there is not a suitable API function, use Afx code.
In AfxTime.inc there is a function called AfxWeekNumber.
Pages: 1 [2]
