Pages: 1 [2]
Author Topic: WinFBE 2.03 Tab Control  (Read 1163 times)
James Klutho
Re: WinFBE 2.03 Tab Control
« Reply #15 on: February 22, 2020, 01:37:33 PM »
I must have something else going on.  Here is the exe you sent me.  Maybe there is something weird with my computer.
« Last Edit: February 22, 2020, 01:39:59 PM by James Klutho »
« Reply #16 on: February 22, 2020, 01:46:12 PM »
What version of Windows is that? The application does not look like it is Themed.
« Reply #17 on: February 22, 2020, 01:47:42 PM »
Attached is what it looks like on my Windows 10 machine.
James Klutho
« Reply #18 on: February 22, 2020, 02:22:29 PM »
This laptop is Windows 7 which is probably the problem.  I ran your exe on another laptop with Windows 10 and there was no problem.  Also I created a new project with buttons a tab controls and everything worked fine.  Any hope for windows 7?
« Reply #19 on: February 22, 2020, 08:41:07 PM »
Hmmmm.... that is odd. It should work on all Windows versions from Vista onwards. I will create some test cases for you (I will also see if I still have a laptop with Windows 7 installed!).
I am pretty sure that Jose used Windows 7 most of the time while he was writing the WinFBX library. WinFBE uses the CxpButton control for all buttons that the visual designer outputs. So, the problem could be how I am interfacing to the CxpButton control.
« Reply #20 on: February 23, 2020, 11:43:33 AM »
Hi Jim,
I fired up Windows 7 in a virtual box and was able to run the exe (see screenshot attached). Everything seemed to look okay. Actually, my version ran with themes active. I am still not sure why your version did have themes active. When you create a new project there is a little checkbox on the dialog that allows the application to automatically create a resource file and manifest file that is needed for theme support.
James Klutho
« Reply #21 on: February 23, 2020, 05:08:36 PM »
I don't know.  I switched over to the Windows 10 computer as my development computer and everything seems to be working now.  Thanks for your time Paul. This is a pretty slick product.
Pages: 1 [2]
