type mismatch, before ')'
Started by jermy, December 05, 2020, 12:45:08 PM
jermy
Dear people
why can I compile this code in 32 bits but not in 64 bits?
#INCLUDE Once "windows.bi"
#INCLUDE Once "win/commdlg.bi"
#INCLUDE Once "win/commctrl.bi"
#INCLUDE Once "crt.bi"
Dim Shared  hCodegen      As HWND
Dim Shared  lpCodegenProc As WNDPROC
Declare Function CodegenProc(Byval hWnd   As HWND, _
                     Byval wMsg    As UINT, Byval wParam As  WPARAM, _
                     Byval lParam As LPARAM) As LRESULT
'error 20: type mismatch, before ')' in lpCodegenProc = Cast(WNDPROC,SetWindowLongPtr(hCodegen, GWLP_WNDPROC, Cast(Long,@CodegenProc)))
                     Byval Msg    As UINT, Byval wParam As  WPARAM, _
    Function = CallWindowProc(lpCodegenProc, hWnd, Msg, wParam, lParam)
Thanks in advance for your help
Hi,
Instead of Long, I believe you need to use LONG_PTR according to the documentation.
https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-setwindowlongptrw
  lpCodegenProc = Cast(WNDPROC, SetWindowLongPtr(hCodegen, GWLP_WNDPROC, cast(LONG_PTR,@CodegenProc)))
jermy
Thanks that helps compile.
Long   LONG_PTR
DWORD   DWORD_PTR
and so on for different data types
