Dear people
What is wrong in this code causing strange characters on the form?
it also displays half buttons
#define UNICODE
USING Afx
' // Menu identifiers
ENUM
IDM_NEW = 1001
IDC_ITEM1 = 1002
IDC_ITEM2 = 1003
END ENUM
Dim Shared lpToolbarProc As WNDPROC
Dim Shared hTBtoolbar As HWND
' // Forward declaration
declare FUNCTION ToolBox_WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
Declare Sub ToolbarAddButton( hwndOwner As HWND, idCommand As UInteger, lpTitle As LPSTR, dwStyle As Byte )
' Main
' // Set process DPI aware
AfxSetProcessDPIAware
' // Create the main window
DIM pToolBox AS CWindow
pToolbox.Create( Null, "Toolbox", @ToolBox_WndProc, 125, 20, 150, 450, _
WS_OVERLAPPEDWINDOW OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS, WS_EX_CONTROLPARENT OR WS_EX_WINDOWEDGE or WS_EX_TOOLWINDOW)
'// Create the toolbox
DIM hTBToolBar AS HWND = pToolBox.AddControl( TOOLBARCLASSNAME, pToolBox.hWindow, , , , 350, 150, 650, _
WS_VISIBLE Or WS_CHILD Or CCS_TOP Or TBSTYLE_LIST Or CCS_ADJUSTABLE Or TBSTYLE_WRAPABLE Or TBSTYLE_FLAT )
ToolbarAddButton(hTBtoolbar, IDC_ITEM1, "Item1", TBSTYLE_CHECKGROUP Or TBSTYLE_AUTOSIZE)
ToolbarAddButton(hTBtoolbar, IDC_ITEM2, "Item2", TBSTYLE_CHECKGROUP Or TBSTYLE_AUTOSIZE)
ShowWindow(pToolBox.hWindow, nCmdShow)
UpdateWindow(pToolBox.hWindow)
FUNCTION = pToolBox.DoEvents(nCmdShow)
SELECT CASE uMsg
CASE WM_COMMAND
Case IDC_ITEM1
? "ITEM1"
Case IDC_ITEM2
? "ITEM2"
CASE IDCANCEL
SendMessage hwnd, WM_CLOSE, 0, 0
CASE WM_SIZE
SendMessage(hTBtoolbar, TB_AUTOSIZE, 0, 0)
CASE WM_DESTROY
PostQuitMessage(0)
Sub ToolbarAddButton( Byval hWndToolbar As HWND, idCommand As UInteger, lpTitle As LPSTR, dwStyle As Byte )
Static tbb As TBBUTTON
' send the TB_BUTTONSTRUCTSIZE message, which is required for
' backward compatibility
SendMessageW( hWndToolbar, TB_BUTTONSTRUCTSIZE, Sizeof(TBBUTTON), 0)
' fill the TBBUTTON array with button information, and add the buttons to the toolbar
tbb.idCommand = idCommand
tbb.fsState = TBSTATE_ENABLED
tbb.fsStyle = dwStyle
tbb.dwData = 0
tbb.iString = SendMessage( hWndToolbar, TB_ADDSTRING, 0, Cast(LPARAM,lpTitle) )
tbb.iBitmap = -2
SendMessage ( hWndToolbar, TB_SETBUTTONSIZE, 0, MAKELONG(16, 16))
SendMessage( hWndToolbar, TB_ADDBUTTONS, 1, Cast(DWORD_PTR, @tbb))
End Sub
Thanks for the effort
