Author Topic: @Jose Header_GetItemText  (Read 317 times)
« on: January 24, 2022, 10:43:30 PM »
Hi Jose,
Small omission in Header_GetItemText in AfxCtl.inc
The nItem is always set to zero (0). Hopefully you can update the includes with the correction:
current incorrect line:
   FUNCTION = SendMessageW(hwndHD, HDM_GETITEMW, 0, cast(LPARAM, cast(HDITEMW PTR, @hdi)))
new line:
   FUNCTION = SendMessageW(hwndHD, HDM_GETITEMW, cast(WPARAM, nItem), cast(LPARAM, cast(HDITEMW PTR, @hdi)))
Also, looks like the code in ListView_GetHeaderText is correct.
Thanks!
Re: @Jose Header_GetItemText
« Reply #1 on: February 23, 2022, 02:30:11 PM »
Modified. Sorry for the delay.
« Reply #2 on: February 23, 2022, 08:12:20 PM »
Thanks Josť - appreciate it
