Pages: 1 [2]
Author Topic: WinFBE v3.0.0-BETA-1 (March 25, 2022)  (Read 707 times)
Re: WinFBE v3.0.0-BETA-1 (March 25, 2022)
« Reply #15 on: March 31, 2022, 07:12:02 PM »
I use it when I need to add a manifest.
David Roberts
  • Little Newbie
« Reply #16 on: March 31, 2022, 07:24:05 PM »
I use '#Resource "<Whatever>.rc" terminating with ' 1 24 "Theme.xml" '.
Wilko Verweij
  • PB10 - FF3.7 User; Win 10
    • CHEAQS
« Reply #17 on: April 01, 2022, 12:48:30 PM »
I tested the first beta earlier this week. Until recently I worked with 1.8.7 or so. Everything seems to compile fine. What I like about this version:
  • ability to search in all files of a project
  • the split option in the editor
What I did not like/could not get working:
  • I could not display on the left the functions per file
  • spaces in folder names are forbidden
Two observations:
  • Under environment options, two times 'Code editor' appears
  • In the 'find files'dialog, the three check boxes on the right should IMHO be option buttons, as only one can be selected at a time
I did not test the form designer as I manually create all windows and do the message handling myself too.
I do not use Freebasic a lot anymore, I now mainly work in C.
Joerg Buckel
  • FF3 and WinFBE+WinFBX User
« Reply #18 on: April 01, 2022, 01:06:04 PM »
Hello to All
When I start something new, I exclusively use the "projects" function.  :)
Greeting from Germany
Joerg
« Reply #19 on: April 01, 2022, 05:41:25 PM »
Thanks Wilko for trying out the beta. I really appreciate it!
Functions no longer display under the filenames in the Explorer. They are located on a dedication panel called Function List and can easily be brought to the visibile from by pressing F4.
This is by design because I could never find out why compiling would fail when folder spaces were involved. I think it relates to the spawning of a process and invoking the unix like gcc toolchain that traditionally has trouble with embedded spaces, or it could be related to the resource file compiling. I have tried everything I could think of including wrapping the paths in quotes.
I know, because I could find a good name to call the second entry! They bother relate to code editor options  :-)
I'll check this out.
« Reply #20 on: April 01, 2022, 05:58:31 PM »
From @Wilko Verweij:
Paul, When the left panel is displaying the Functions List, would it be possible to have the view automatically scroll to and highlight the name of the function that the cursor is in? Sometimes when I'm distracted or otherwise taken away from the monitor, I need to refocus on the programming task at hand so depending on the number of lines in a particular procedure, I may need to scroll to the top of the function to refresh my memory (maybe that's just age-related:). Or am I missing something obvious?
Update:
I added a TabControl to a form now WinFBE crashes unpredictably.
« Last Edit: April 01, 2022, 07:27:02 PM by SeaVipe »
« Reply #21 on: April 01, 2022, 07:26:30 PM »
Hi Clive, I understand what it is that you're asking for.
I am worried of two things:
(1) The constant jumping around in the Functions List that may occur by constantly repositioning the list to the current active function. I kind of like having a static listing so I can easily pick out a function that I may jump to next rather than possibly having to scroll around for it. I see your point though.
(2) The performance issue. There is code within WinFBE that can determine the name of the current function that your cursor is in, however I expect that there would be a huge performance penalty by having to do that calculation every time the cursor moves (unless maybe an elaborate array of function line start and end points is maintained).
I think that I might have to ponder a little bit more about this request. If the performance penalty is not significant then maybe just displaying the current active function's name somewhere within the main GUI (statusbar?) would be better rather than repositioning the Function List.
I'd be interested in hearing from others should they have feelings about this one way or the other.
« Reply #22 on: April 01, 2022, 07:31:52 PM »
Hi Paul, yes, StatusBar would work for me. Now that I think about it, having the left panel highlight continuously moving, aside from the overhead, would also be distracting.
Bumblebee
« Reply #23 on: April 01, 2022, 07:39:42 PM »
I use the Project option when there is more than one form.
Pages: 1 [2]
